Why is FE 70-200 bigger and heavier than Canon's
Started Feb 13, 2014 | Discussions
EinsteinsGhost
Forum ProPosts: 11,977Gear list
Pro Features Included
In reply to Cheng Bao, Feb 13, 2014
The FE 70-200/4 looks like a well finished lens and includes couple of thoughtful features as well that I doubt anybody has discussed yet:
- Dual Mode optical stabilization
- Focus Hold button
And people are worried about a couple of ounces that is a bit too much for them (and an mm or two which is easily absorbed by a smaller body/flange to begin with).
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
stevo23
Veteran MemberPosts: 9,448Gear list
Re: i will not buy this lens
In reply to Erik Magnuson, Feb 14, 2014
Erik Magnuson wrote:
stevo23 wrote:
You will have to move to M43 to get any significant improvement in weight / bulk. I think it will be hard to do otherwise in full frame.
An MFT 70-200mm f/4 would be the roughly the same size weight. As would an MFT 35-100mm f/2 which would be equivalent in FOV and total light.
Panasonic's 35-100 2.8 weighs 13 oz. Not quite the same light, but close enough for a valid comparison.
Look at the filter diameter: 58mm vs. 67mm. That's enough glass diameter to make a difference. No one makes a 70-200mm f/5.6 -- the closest would be the Nikkor 55-200mm AF-S VR f/4.5-5.6 which weighs 335g. While that's a DX lens, Canon had a 55-200mm EF lens (no IS) that was about the same size, so a 70-200 f/5.6 FX is plausible except there is no demand.
The other big difference with the 35-100 is vignetting:
All designs are compromised and panasonic allowed extra vignetting to shave size.
Erik
Dude - you're taking this waaay too seriously. Most M43's owners will be more than happy with the sub-standard performance of said  lenses. Of course it's not an exact comparison.
 stevo23's gear list:stevo23's gear list
Sony Alpha 7 Nikon AF Nikkor 20mm f/2.8D Tamron SP AF 90mm F/2.8 Di Macro Sony FE 35mm F2.8 Sony FE 55mm F1.8 +1 more
stevo23
In reply to EinsteinsGhost, Feb 14, 2014
EinsteinsGhost wrote:
jamesfrmphilly wrote:
way too heavy
Yeah. I know what you mean. My 55/1.2 is 650g, and you can easily see in the photos from it that they were taken with a heavy lens.
A7 with kit lens and a number of legacy lenses (mostly Canon FD)
I wonder if one could even use a Zeiss Otus... That thing weighs 1030g on Nikon F mount.
No one can. It's actually never been photographed in use. We've only seen it's name in EXIF information.
stevo23
Re: Why is FE 70-200 bigger and heavier than Canon's
stevo23 wrote:
Since we're counting oz.'s, I wonder what the Sony weighs without the tripod collar - a collar which doesn't come on the Canon as far as I know.
840g. Companies do not typically include collars or hoods if they are removable. If you include the collar in the weight, you'd also include it in the diameter.
Seriously? Do you not get my point in any small way?
stevo23
In reply to Cheng Bao, Feb 14, 2014
Cheng Bao wrote:
At least on paper, this lens is sharper than canon 70-200 F4L IS
SONY FE 70-200G OSS F4 vs CANON 70-200 F4L IS
At 70mm, sony is shaper all round,
At 200mm full open, sony is sharper, only the extreme corner is less sharper
So that settles it, right? Sharpness. No concern for CAs, distortion or anything else? (Actually, this lens probably beats the Canon in other performan too.)
stevo23
Re: Pro Features Included
- Focus Hold button
Exactly. You're already starting out a pound lighter by using the A7. (Lighter than a 5DmkIII that is...)
Erik Magnuson
Forum ProPosts: 12,179Gear list
In reply to stevo23, Feb 14, 2014
Nope.  I assume you know that you can buy a collar for the Canon either from Canon or cheaper 3rd party knockoffs.  The collar weighs about 180g.
Erik
 Erik Magnuson's gear list:Erik Magnuson's gear list
Canon EOS 5D Mark II Canon EOS 450D Sigma SD10 Sony Alpha NEX-5 Nikon D3200 +28 more
stevo23
Yes, I know you can buy the collar for the Canon.
hellocrowley
Senior MemberPosts: 1,253
Well if anything this thread has shown me why Sony loves releasing monster zooms before compact primes, because apparently that's what many people want. I'll sit it out for a few years and see where FE goes.
spacemn
Senior MemberPosts: 1,464Gear list
I wouldn't count on that the collar weight is included in those 840g for the Sony. Nice though that the collar is included when buying the lens.
When you are dealing with lenses that big 100g in either direction doesn't matter much. For $1500 I rather want supreme build quality and it seems Sony delivers on that account but tests will tell. I am really curious to know about the Af speed on this thing.
I would really want to see a comparison test between the Sony FE 70-200mm f/4 and the Latest Sigma 70-200mm f/2.8 HSM OS for A-mount.
Chengis
Forum MemberPosts: 52Gear list
In reply to pew pew, Feb 14, 2014
Well one can only make the camera small. On the other hand, the lens... one can only modify a glass or push glasses around so much to alter it's focal length.
 Chengis's gear list:Chengis's gear list
Ricoh GR Digital IV Sony RX100 Sony SLT-A65 Sony Alpha 7 Sony a6000 +13 more
EinsteinsGhost
In reply to hellocrowley, Feb 14, 2014
OTOH, people are going gags over Sony not releasing faster zooms. You think 72mm filter is too big? Try 77mm on upcoming Fuji 16-55/2.8 that people think Sony should build.
And you jave no idea how "monstrous" the 70-200/4 is. It is actually smaller and lighter than my personal compact choice for telephoto lens on NEX: Minolta 200/2.8 G APO HS. With 70-200/4, you lose a stop, the adapter and gain zoom.
I would be speaking like you, if this were a 70-200/2.8 which are much larger and nearly 2x heavier.
As for primes, I think the sizes are kept in check. The issue is mostly of perception since E-mount bodies are significantly slimmer so relatively speaking the lenses appear larger.
Steven-T
Veteran MemberPosts: 3,316Gear list
In reply to pevece, Feb 14, 2014
pevece wrote:
hellocrowley wrote:
I had high hopes for the FE system, was thinking that I'd eventually switch from Fuji, but it seems the size and weight advantage are not there?
Sony:
Filter Thread 72 mm
Dimensions (DxL) Approx. 3.15 x 6.89" (80 x 175 mm)
Weight 29.63 oz (840 g)
Canon 70-200/4 IS:
Filter Thread Front:67 mm
Dimensions (DxL) Approx. 3.0 x 6.8" (7.62 x 17.27 cm)
Weight 1.67 lb (760 g)
They should hire someone from Pentax to design the lenses.
use the canon version on a 36mp sensor and see what happens !
you want high quality , small in size, lightweight and cheap, sorry that's not feasible today
I have been using the Canon EF 70-200/4L IS on my A7R with MB3. Aperture control works, AF a bit slow, IS works, accurate focus, good IQ.
Steven
 Steven-T's gear list:Steven-T's gear list
Leica M9 Panasonic Lumix DMC-GH4 Sony Alpha 7R II +6 more
Steven-T
pevece wrote:
Sony:
Filter Thread 72 mm
Canon 70-200/4 IS:
The centre of the Canon lens has been tested on 18MP APS-C, you'd need 46MP full frame to be as demanding. Its corners on 21MP full frame are not an issue. There are some A7R user using one with an adapter, ask them.
Andrew
How much does the Canon weigh with the adapter? Dimensions added too?
You can carry one MB3 for all the EF lenses (mount the adapter on the camera A7/R), rather than adding an "adapter-tube" to each FE lens.  AF speed? Hmm . . .
Steven
EinsteinsGhost
In reply to Steven-T, Feb 14, 2014
pevece wrote:
Sony:
Filter Thread 72 mm
Canon 70-200/4 IS:
Andrew
Steven
Thats what I do (in fact, have EA2 and MBSB in my bag right now, so a lens can be used for two different FOV as well). You are already fine with a larger and heavier set up while accepting slower AF, we should expect 70-200/4G to be fast if not the fastest lens which will not be as large or as heavy set up.
Such discussions also seem to miss the point that we are talking about lens on camera and how the two setup together as a unit.
hellocrowley
In reply to EinsteinsGhost, Feb 15, 2014
Yes, that Fuji is the one lens I'd never buy. Even the 10-24 is already too big. Luckily Fuji has released smallish primes first so most users got their needs covered.
The fact that you use a 200/2.8 on NEX puts this discussion into a different perspective.
