Show me your neck straps.
Started Feb 12, 2014 | Discussions
Joseph T Lewis III Senior Member • Posts: 2,875
Re: Show me your neck straps.
Bob Tullis wrote:
Joseph T Lewis III wrote:
Bob
How does the Domke strap compare length-wise, to the original E-M1 strap? I find the OEM E-M1 strap seems a bit short; shorter than the one that came with my E-M5. If the Domke strap is longer than the factory strap that came with the E-M1, that would make it very appealing to me.
Not sure - I never took the Oly strap out of its wrapper. I'll try to make the time.
In the meanwhile B&H's site says:
Adjustable length up to 42" (107cm)
...Bob, NYC
http://www.bobtullis.com
http://www.flickr.com/photos/bobtullis/
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
Hi Bob, thanks for the comeback.
I have the E-M1 strap on my camera, without much slack at all on either side.  In that configuration it measures about 40 inches (several different tries using a yardstick up from one side all the way around to the other), and rests above my navel.  I figure if I let out all the slack I could get maybe an inch more on either side at most, which would bring me to the 42" length you mention from the Domke specs.  So, that's why I asked the question...if the Domke strap is the same length as the Oly strap, I'll just stick with the one that came with the camera.
PS.  At 67 I do have a bit of a "gut", but I am not grossly obese or anything...I would just like to be able to carry the camera lower down towards my belt!!
Tom
 Joseph T Lewis III's gear list:Joseph T Lewis III's gear list
Canon PowerShot G7 X Olympus E-M1 Olympus E-PL7 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 +5 more
Paul Auclair Veteran Member • Posts: 3,868
Plastic buckles??
I thought the main reason folks were swapping out Oly's OEM straps were due to their plastic buckles (cracking/breaking)
In this thread I've seen a lot of cool/comfortable looking non-OEM strap but I've seen plenty of those with plastic buckles too.
Actually I have not seen any metalic buckles of the images at this thread (I did not look at all the posts).
I still use the OEM straps (no issues in 15 years with Oly's OEM straps) but if I did swap out I'd look for metal buckles firstly and comfort secondly.
Thanks,
Paul
Michael Meissner
Michael Meissner Forum Pro • Posts: 23,921
Re: Plastic buckles??
The Domke gripper straps have metal swivel clips.  For the larger quick release clips, I would worry that a metal clip would wind up scratching my lcd.
Note, I use my Domke strap in a slightly different method than the manufacturer suggests.  The Domke strap consists of the shoulder strap, with a fixed D-ring on each each, and two 3/8" straps that you feed through the camera's strap holders, with metal clips on the end.  I reverse it, and use the metal clips to attach to the ring you normally attach the strap to, and use the metal clips to attach to the shoulder pad.  This way, when I take off the strap, I don't have a long tail hanging off the camera.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-860 Olympus E-5 Olympus OM-D E-M5 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 +16 more
fortwodriver Regular Member • Posts: 167
I got an Artisan and Artist EasySlider strap (ACAM-E25R).  It was about 70$ on ebay.  Normally I wouldn't drop this sort of cash on a strap but I had a gift card so I decided to give it a try.
I tried my wife's BlackRapid strap but didn't really like it - and I've been looking for something similar.
It's really nice.  It's got a double buckle mechanism that you put your finger through and you can raise or lower the camera.  I wear mine over the shoulder-across the chest.  Works great!
Cheerio...
Frank...
Ron Evers
Ron Evers Senior Member • Posts: 1,383
Re: I prefer metal swivel clips.
Straps can be quickly removed or attached.
My wife likes the no-slip neoprene strap.
The wood is clear between the knots.
 Ron Evers's gear list:Ron Evers's gear list
Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GF1 Olympus PEN E-PM1 Olympus OM-D E-M5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +13 more
RGiskard Regular Member • Posts: 282
I bought a Blackrapid knockoff on Amazon for about $12 and added a small metal mounting point that screws into the tripod mount for another $5.  I like the shoulder strap idea more than a neck strap, and the pad is large and comfortable (it even has a small zip pocket, which could be useful for a lens cap or something).  I haven't used it enough to have a real opinion yet, but it seems to be a good option if you like a sling but don't want to drop $50 or $70 on a Blackrapid.
 RGiskard's gear list:RGiskard's gear list
Olympus E-M1 Panasonic Lumix DMC-GM1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +9 more
jennajenna Senior Member • Posts: 1,300
mickey all the way.
watcher1
watcher1 Regular Member • Posts: 184
Another vote for the Bosstrap
I use them for my E-m1 and E-M5. It attaches to the camera lug, not the tripod hole. Made of seat belt fabric and so folds into a very small space, but is strong. Comes in several widths and with quick-release option.
Check out this video:
http://www.youtube.com/watch?v=j9yGllu3BTM&feature=youtu.be
Highly recommended
 watcher1's gear list:watcher1's gear list
Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Panasonic Lumix G X Vario 35-100mm F2.8 OIS Sony RX1 Olympus E-M1 Olympus OM-D E-M10 +7 more
Ron Evers
Re: Another vote for the Bosstrap
Highly recommended
After having the left strap lug fall off on my E-M5, I would be very much against this strap.
The tripod mount is far more secure.
PurpleFringe Contributing Member • Posts: 579
Re: +2 for Op Tech and Camdapter
I've gone without a neck strap for years, using only the Camdapter hand strap modified slightly.
http://camdapter.com/handstrap.html
With the much heavier E-M1, I've found the Optech Utility strap to be pretty useful.
http://optechusa.com/straps/utility-strap.html
 PurpleFringe's gear list:PurpleFringe's gear list
Fujifilm FinePix X100 Olympus PEN E-P1 Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +5 more
cdmackay Forum Member • Posts: 64
Another vote for Gordy's straps.
For those with multiple cameras, instead of getting one strap for each, you can get Gordy's "sling strap connector" stubs - about an inch long, with a carabiner to connect your strap. Then leave the stubs on the camera, and move the straps around. The stubs optionally come with integral bumpers, to protect the camera.
I have several cameras with stubs, and just one each of Gordy's neck and wrist straps.
phazelag
phazelag Veteran Member • Posts: 3,038
Re: Neat.
Jeff Tokayer wrote:
phazelag wrote:
SteveFromNY wrote:
I'm looking for one, and would love to see what you guys have. If you can, please post pics attached to your camera. Thanks.
I use blackrapid r-Straps on all my cameras except compacts. This is the smaller lighter "metro" strap. I don't like cameras pulling on my neck. These are shoulder straps that let the camera flow freely up and down. You can easily adjust the positioning and they even make a tripod adapter mount so you can use it with a tripod adapter plate.
http://www.blackrapid.com/products/metro
Can you describe your gear? I can see the RDS, and the custom lens support.
My nickel, since the penny is being discontinued...
Jeff.
Thats a Panasonic FZ200 with a Nikon 1.5 Teleconverter and rubber hood. I have a tripod collar and grip from opteka
 phazelag's gear list:phazelag's gear list
Panasonic Lumix DMC-LF1 Sony Cyber-shot DSC-RX100 III Panasonic Lumix DMC-FZ1000 Fujifilm XQ2 Olympus E-M1 +4 more
intruder61
intruder61 Veteran Member • Posts: 3,064
SteveFromNY wrote:
intruder61 wrote:
Gordy strap, 55 inches, sits on the hip.
I was actually looking at the gordy straps. how comfy is this one?
very.....and light.
tgutgu Veteran Member • Posts: 3,627
Re: Peak Design Leash
Klarno wrote:
Neck straps are universally ergonomically awful, and the ones that are the least awful ergonomically are also the least likely to actually fit in a camera bag. Slings are the solution to world peace. You can use it as a neck strap if you really want though.
Quick release attachments visible dangling off the smaller camera.
I use the Peak Design Leash as well, and can recommend it. It fits ideally to a smaller camera (E-M1) and can be easily stuffed into a photo bag, when not needed. For me the time for big neck straps with large parts of foam are over.
Thomas
 tgutgu's gear list:tgutgu's gear list
Olympus E-M1 Olympus E-PL7 Olympus E-M5 II Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +30 more
El Chubasco
El Chubasco Contributing Member • Posts: 524
Here you go, I love mine
Red Artisan Artist
 El Chubasco's gear list:El Chubasco's gear list
Fujifilm X-Pro1 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +12 more
Elderly Regular Member • Posts: 295
Re: Optech
Is that as simple as it looks? I dislike quick release straps that convert into wrist straps, there are too many components for my liking.
In your opinion would that 'binocular' strap be suitable for an EM-1?
Mike Dobbs Senior Member • Posts: 1,086
+1 Re: I use Op/Tech straps
I've been using the Compact Cam Sling on my EM-5 and now the EM-1. Very functional and plenty strong.
I also have the SLR Wrist Strap I've been using on the EM-1 for walk about street work...very comfortable and nicely liberating.
phazelag
Does is slide around as nice as the Blackrapid or Optech?
Thomas
I like this for its small size in a camera bag, but is is awkward sliding the camera up?  I am just imagining it getting stuck on clothes or a jacket depending on the material.  Looks like the whole strap has to move around you, unlike the two in the title that stay in place but allow free movement.
I love my Blackrapid straps, but I am tired of taking the tripod lug off to change the battery or card.
Klarno
Klarno Veteran Member • Posts: 4,094
Re: Does is slide around as nice as the Blackrapid or Optech?
Thomas
The webbing this strap uses is very, very slick--like seat belt material. It doesn't really get caught on anything, I've found. And it's quick enough to disconnect from the strap as needed.
 Klarno's gear list:Klarno's gear list
Olympus PEN E-PM2 A3000 Olympus E-M1 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 II Olympus Zuiko Digital 11-22mm 1:2.8-3.5 +4 more
tobyone
tobyone Regular Member • Posts: 335
Beer cuzzy on 45-200 Panny. Camo plus no zoom creep.
Toby Armstrong
