Show me your neck straps.
Started Feb 12, 2014 | Discussions
mjh04
mjh04 Regular Member • Posts: 299
Re: Show me your neck straps.
You sure couldn't sneak up on anyone wearing that strap.:-)
Mike Hedge
www.thehedgepost.com
 mjh04's gear list:mjh04's gear list
Fujifilm X100T Fujifilm X-E2 Fujifilm X-T1 Nikon D810 Fujifilm X-Pro2 +13 more
MarceloLI
MarceloLI Veteran Member • Posts: 4,917
Light, small, safe and comfortable:
http://optechusa.com/straps/compact-sling.html
 MarceloLI's gear list:MarceloLI's gear list
Olympus OM-D E-M5 Canon EOS 5D Mark III Nikon D7100 Nikon D810 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +21 more
Neurad1 Senior Member • Posts: 1,801
Ontario Gone wrote:
"Run to the light, Carol Anne. Run as fast as you can!"
Jaysus!
 Neurad1's gear list:Neurad1's gear list
Sony RX1 Sony Cyber-shot DSC-RX100 III Olympus OM-D E-M5 Olympus PEN E-PL5 Olympus E-M1 +40 more
exdeejjjaaaa
exdeejjjaaaa Veteran Member • Posts: 7,694
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Phase One Capture One Pro +23 more
berni29 Senior Member • Posts: 2,448
Hi
Easily my favourite for lighter cameras is the Crumpler Hitch. Is very comfortable and soft. These are the only pics I have that show the straps. They have quick release and you can swap amongst cameras easily. They also knot to use as a wrist strap.
Berni29
EM-5, GM1 + Pana 12-32mm, 35-100mm f2.8, 20mm, 14-45mm Oly 45mm, 50mm F2 macro, (prev GH1, E30, E510, E1, E300, LX3)
 berni29's gear list:berni29's gear list
Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Olympus OM-D E-M10 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro +5 more
AndyW17 Contributing Member • Posts: 615
If/when I move to u4/3, I will get one of these
http://www.bosstrap.com/bosstrapcamerasupportsystem-2-1-1-1.aspx
I have one for a DSLR and LOVE it.  The slider is key.
Andy
 AndyW17's gear list:AndyW17's gear list
Sony RX100 II Olympus E-M1 Nikon D750 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +6 more
SteveFromNY OP Forum Member • Posts: 57
So I almost bought the Gordy, but found it a bit thin. Then I was almost all set on one made my Luigi, but I think $100+ is crazy for a simple strap. I ended up getting this one, but I might have to mod it to make more secure as I really don't like the string attachment to the body.
http://www.ebay.com/itm/290986006668?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I'm going to try fitting the metal rings into the ends rather than using the strings loops.
 SteveFromNY's gear list:SteveFromNY's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Leica Summilux DG 25mm F1.4 Panasonic 12-35mm F2.8 Panasonic Leica DG Summilux 15mm F1.7 ASPH
Bob Tullis
Bob Tullis Forum Pro • Posts: 31,101
Yes, I was tempted by that one myself.   But I've had the Op-Tech straps using that type of nylon string.   It's tough, but exposed to the elements year-round after a year or so it starts to stiffen and fray (UV light I think plays a part).  I've never had one break, but I never left one on long enough to test it.    Just keep an eye on it.
...Bob, NYC
http://www.bobtullis.com
http://www.flickr.com/photos/bobtullis/
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Sony Alpha 7S Sony Alpha 7R II Voigtlander 28mm F2 Ultron Sony RX1R II Sony Alpha 7 II +16 more
Joseph T Lewis III Senior Member • Posts: 2,819
Bob
How does the Domke strap compare length-wise, to the original E-M1 strap?  I find the OEM E-M1 strap seems a bit short; shorter than the one that came with my E-M5.  If the Domke strap is longer than the factory strap that came with the E-M1, that would make it very appealing to me.
Thank you
Tom
 Joseph T Lewis III's gear list:Joseph T Lewis III's gear list
Canon PowerShot G7 X Olympus E-M1 Olympus E-PL7 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 +5 more
Mike_PEAT Forum Pro • Posts: 11,934
I use straps from Roots Canada, they have little air pillows!
I love these straps:
slimandy Forum Pro • Posts: 16,263
Optech
I always use an Optech neoprene strap on all of my cameras. On my FF gear I use the Optech Pro Loop, but on my lighter MFT bodies I find the Optech binocular strap is perfect and inexpensive too.
http://www.ebay.co.uk/itm/OP-TECH-E-Z-BLACK-NEOPRENE-COMFORT-CAMERA-OR-BINOCULAR-STRAP-/200984053635?pt=UK_Photography_Straps_Hand_Grips&hash=item2ecb954783
www.andrewsandersphotography.co.uk
 slimandy's gear list:slimandy's gear list
Sony RX100 II Nikon D200 Nikon D700 Fujifilm X-E1 Fujifilm X-T1
BIOEP
BIOEP Regular Member • Posts: 116
Well, I have seen all the straps above and what I find most comforting is my Nikon Strap that I received from Mr. Okada of NPS - Nikon Professional Services a at Suzuka Circuit in July 1982. It is non slip but soft and pliable and it never goes around my neck, always on my shoulder or wrapped around my hand. For me, it is the best. Two images enclosed. Regards to Everyone, Chris
My NPS Strap with some Magic Marker work.
My NPS Strap wrapped around my 20mm
Chris Rea - BIOEP = "Blind In One Eye Photography"
 BIOEP's gear list:BIOEP's gear list
Olympus OM-D E-M5
Bollox Regular Member • Posts: 359
I use this one for E-M5
Handmade vintage Leather camera strap
Link: here
www.flickr.com/photos/westergaard
 Bollox's gear list:Bollox's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-G6 Olympus E-M1 Nikon 1 AW1 Panasonic Lumix G 20mm F1.7 ASPH +15 more
Bob Tullis
Joseph T Lewis III wrote:
Bob
Not sure - I never took the Oly strap out of its wrapper. I'll try to make the time.
In the meanwhile B&H's site says:
Adjustable length up to 42" (107cm)
...Bob, NYC
nick66davis Senior Member • Posts: 2,396
My old Olympus 1970s braided strap has worn significantly so i thought i'd invest n something a bit hippyish....
 nick66davis's gear list:nick66davis's gear list
Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 14-140mm F3.5-5.6 ASPH. / Power O.I.S
phazelag
phazelag Veteran Member • Posts: 3,037
Although this Lance Camera Strap (Classic Quick Connect) resides on my EM1, I bought it for my since sold EM5. It's a fashion statement at this point as the pictured set up is somewhat heavy. I also have a BlackRapid strap for times when I'll be carrying for extended periods.
I think this a cool setup.
www.scottzinda.com
http://instagram.com/phazelag
http://motivationmachine.net/
 phazelag's gear list:phazelag's gear list
Panasonic Lumix DMC-LF1 Sony Cyber-shot DSC-RX100 III Panasonic Lumix DMC-FZ1000 Fujifilm XQ2 Olympus E-M1 +4 more
phazelag
Jeff Tokayer Veteran Member • Posts: 6,220
Neat.
phazelag wrote:
SteveFromNY wrote:
I'm looking for one, and would love to see what you guys have. If you can, please post pics attached to your camera. Thanks.
I use blackrapid r-Straps on all my cameras except compacts. This is the smaller lighter "metro" strap. I don't like cameras pulling on my neck. These are shoulder straps that let the camera flow freely up and down. You can easily adjust the positioning and they even make a tripod adapter mount so you can use it with a tripod adapter plate.
http://www.blackrapid.com/products/metro
Can you describe your gear? I can see the RDS, and the custom lens support.
My nickel, since the penny is being discontinued...
Jeff.
Lobby Ludd Senior Member • Posts: 2,262
This is a great strap and conversation piece. It is very quick to completely remove from the body. You can get rid of the dangly bits that come in the camera lugs. Saw this highly recommended in this forum, but just check the reviews online. Too much $$ for what it is, but it is very nice, very simple.
http://www.bhphotovideo.com/c/product/30496-REG/Leica_14312_Carrying_Strap_with_Anti_Slip.html
KTClown
KTClown Senior Member • Posts: 1,441
I had a good neck strap, but my wife won't shut up, so it's around her neck!
Sorry, I couldn't resist, a little humor.
 KTClown's gear list:KTClown's gear list
Olympus XZ-1 Olympus PEN E-PL5 Olympus OM-D E-M10 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +2 more
