Show me your neck straps.
Started Feb 12, 2014 | Discussions
SteveFromNY Forum Member • Posts: 57
I'm looking for one, and would love to see what you guys have.  If you can, please post pics attached to your camera.  Thanks.
 SteveFromNY's gear list:SteveFromNY's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Leica Summilux DG 25mm F1.4 Panasonic 12-35mm F2.8 Panasonic Leica DG Summilux 15mm F1.7 ASPH
Bob Tullis
Bob Tullis Forum Pro • Posts: 31,264
Re: Show me your neck straps.
Domke Gripper 1" swivel strap
I keep trying alternatives through the years, and always come back to this one.
...Bob, NYC
http://www.bobtullis.com
http://www.flickr.com/photos/bobtullis/
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Sony Alpha 7S Sony Alpha 7R II Voigtlander 28mm F2 Ultron Sony RX1R II Sony Alpha 7 II +16 more
phazelag
phazelag Veteran Member • Posts: 3,038
I use blackrapid r-Straps on all my cameras except compacts. This is the smaller lighter "metro" strap. I don't like cameras pulling on my neck. These are shoulder straps that let the camera flow freely up and down. You can easily adjust the positioning and they even make a tripod adapter mount so you can use it with a tripod adapter plate.
http://www.blackrapid.com/products/metro
 phazelag's gear list:phazelag's gear list
Panasonic Lumix DMC-LF1 Sony Cyber-shot DSC-RX100 III Panasonic Lumix DMC-FZ1000 Fujifilm XQ2 Olympus E-M1 +4 more
intruder61
intruder61 Veteran Member • Posts: 3,064
Gordy strap, 55 inches, sits on the hip.
phazelag
...Bob, NYC
Bob I keep meaning to try that one.  I may order one soon.
Elemental Photography Contributing Member • Posts: 840
I use Op/Tech straps
I use a modular Op/Tech strap.  Most of the time, I leave the neck part off and use it as a light duty hand strap:
But if needed I can clip a neoprene neck strap in as well:
A photograph is a creative interpretation of reality.
 Elemental Photography's gear list:Elemental Photography's gear list
Pentax Optio WG-2 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GH3 Panasonic Lumix G 20mm F1.7 ASPH +7 more
lambert4
lambert4 Senior Member • Posts: 1,913
iPad image apologies... Domke gripper w/swivels makes a nice wrist strap as well...
Here's to learning something new everyday, and remembering it the next.
Simple flexible when attached a couple pods attached as well for a spare battery and card as well as a lens cloth.
Same strap one attachment and swivel portion unhooked, takes 5 seconds and allows me to use my spider tripod mount of a sling for riding skiing and hiking....
Tactical rig, great for those rally active endeavors and still having it accessible.
 lambert4's gear list:lambert4's gear list
Olympus OM-D E-M5 Olympus E-M1
dv312
dv312 Veteran Member • Posts: 3,482
+1 for Op Tech
I've always used the Neoprene straps, especially Op/Tech
http://optechusa.com/straps/mirrorless-strap-1187.html
1) the Neoprene rubber helps alleviate the weight
2) feels good on your neck
3) doesn't leave abrasion like the regular straps
4) are easy to mount onto the camera and to unmount for that matter
Wish manufacturers start providing us with neoprene material and not the hard and abrasive cloth like material
Cheers
 dv312's gear list:dv312's gear list
Olympus PEN E-P5 Olympus E-M5 II Olympus PEN-F Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital 45mm F1.8 +8 more
DaveLemi
DaveLemi Regular Member • Posts: 327
Although this Lance Camera Strap (Classic Quick Connect) resides on my EM1, I bought it for my since sold EM5. It's a fashion statement at this point as the pictured set up is somewhat heavy. I also have a BlackRapid strap for times when I'll be carrying for extended periods.
 DaveLemi's gear list:DaveLemi's gear list
Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +6 more
Michael Meissner
Michael Meissner Forum Pro • Posts: 23,915
My main strap is the Domke strap. I use 1.5" for the E-5, and the 1" for the Pens (http://www.tiffen.com/results.html?search_type_no=436&tablename=domke):
Olympus E-5 with Domke 1.5" gripper strap
E-PM2 with 1" Domke Gripper strap and Gariz leather case
I like the Peak Design cuff for a wrist strap. At times, I will also use their leash, but I prefer the Domke gripper straps (https://peakdesignltd.com/store/?c=straps):
E-5 with Peak Designs cuff, E-PM2 with Peak Designs Leash, TG-2 with connector + stuffed squirrels
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-860 Olympus E-5 Olympus OM-D E-M5 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 +16 more
amtberg Veteran Member • Posts: 5,538
8
Oh, you mean....
SteveFromNY OP Forum Member • Posts: 57
I was actually looking at the gordy straps. how comfy is this one?
Ron Evers
Ron Evers Senior Member • Posts: 1,383
1.5"/45mm wide & soft for weight distribution.
I also use a shoulder strap for a second or heavier camera.
The wood is clear between the knots.
 Ron Evers's gear list:Ron Evers's gear list
Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GF1 Olympus PEN E-PM1 Olympus OM-D E-M5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +13 more
Klarno
Klarno Veteran Member • Posts: 4,094
Peak Design Leash
Neck straps are universally ergonomically awful, and the ones that are the least awful ergonomically are also the least likely to actually fit in a camera bag. Slings are the solution to world peace. You can use it as a neck strap if you really want though.
Quick release attachments visible dangling off the smaller camera.
 Klarno's gear list:Klarno's gear list
Olympus PEN E-PM2 A3000 Olympus E-M1 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 II Olympus Zuiko Digital 11-22mm 1:2.8-3.5 +4 more
Neurad1 Senior Member • Posts: 1,831
All my neck straps are wrist straps
Made by Gordy, except for the one on my RX-1 which was made by Luigi Crescenzi. I like the Gordy's just as well and they cost a LOT less.
I don't like/use neck straps.
Sorry for the IQ. Ipad shot.
Here are my Olympus cameras with their wrist straps.
 Neurad1's gear list:Neurad1's gear list
Sony RX1 Sony Cyber-shot DSC-RX100 III Olympus OM-D E-M5 Olympus PEN E-PL5 Olympus E-M1 +40 more
xerophytenyc Regular Member • Posts: 424
Re: Peak Design Leash
+1 Peak Design over-the-shoulder leash sling style (and Capture clip to go with it)
 xerophytenyc's gear list:xerophytenyc's gear list
Sony RX100 II Panasonic Lumix DMC-GH4 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Olympus Tough TG-2 +6 more
tonybelding Regular Member • Posts: 281
Couch Handmade Racer-X
I got a "Racer-X" strap from Couch (http://www.couchguitarstraps.com). Check it:
Not the most high-tech, but they do look good and are comfortable, and long enough to wear over the shoulder if you wish. Also note the OP/TECH Mini Quick Disconnect loops, which are so very convenient!
Also got a Couch strap for my Pentax K-01:
 tonybelding's gear list:tonybelding's gear list
Fujifilm FinePix Real 3D W3 Fujifilm XF1 Pentax K100D Pentax Q7 Fujifilm X-T1 +8 more
murfthesurf Contributing Member • Posts: 634
Just had this one delivered today.  I hope I like it.
http://www.dsptch.com/collections/sling/products/standard-camera-sling-strap-olive
- Murf
 murfthesurf's gear list:murfthesurf's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm 1:1.8 Samyang 7.5mm F3.5 UMC Fisheye MFT +4 more
Ontario Gone
Ontario Gone Senior Member • Posts: 4,183
"Run to the light, Carol Anne. Run as fast as you can!"
 Ontario Gone's gear list:Ontario Gone's gear list
Nikon D7000 Canon EOS 70D Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 50mm f/1.8G Canon EF 40mm f/2.8 STM
DaveLemi
Re: Couch Handmade Racer-X
Showing some Couch love too-
