How can A6000 beat PDAF, doenst make sense?
Started Feb 12, 2014 | Questions
dpyy Contributing Member • Posts: 892
How can A6000 beat PDAF? Can someone explain the technology behind this? It doesn't matter how many points of autofocus they put on the sensor it should still be significantly slower than dedicated sensors?
Sony a6000
tomtom50 Veteran Member • Posts: 3,244
Re: How can A6000 beat PDAF, doenst make sense?
The a6000 doesn't beat PDAF. It is PDAF, on-sensor.
 tomtom50's gear list:tomtom50's gear list
Sony RX100 Canon EOS M Sony Alpha NEX-3N Sony a6000
SQLGuy Veteran Member • Posts: 4,223
Why would it have to be slower? As long as the phase detect data can be read from the embedded pixels as quickly as they could be read from dedicated sensors, and as long as the autofocus processor is as fast, there's no inherent reason why OSPDAF shouldn't work as well as dedicated AF sensors.
Add to that the benefit of no possibility of back-focus/front-focus.
A7 with kit lens and a number of legacy lenses (mostly Canon FD)
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Nikon D200 Sony Alpha NEX-7 Sony Alpha 7 II Nikon AF-S DX Nikkor 35mm f/1.8G +2 more
parallaxproblem Veteran Member • Posts: 5,334
It seems to come down to processing speed...  now the processors are (according to Sony) fast enough to perform the necessary calculations in realtime
Being based on-sensor there are potentially many benefits to this approach, not least that the distance being measured will be exactly the right one!  With a DSLR-type dedicated PDAF sensors in different location arrangement, any difference in light path between lens-to-sensor and lens-to-PDAF will be cause focus inaccuracies!
DUMP the HUMP! A5000 & A6000 success.... campaign for *REAL* NEX-5 and NEX-7 replacement bodies
* newly updated ignore list: hostile responses are probably not visible to me
 parallaxproblem's gear list:parallaxproblem's gear list
Sony Alpha DSLR-A900 NEX5R Sony a77 II
Richard Ettinger Senior Member • Posts: 1,309
It has PDAF built onto the image sensor. they are dedicated to focusing.
Canon 40D. Canon 50mm f1.4, canon 135mm 2.8/soft focus, Canon 70-200 f4L, Canon 24-105L. Sony Nex-7. Sony a7
 Richard Ettinger's gear list:Richard Ettinger's gear list
Sony Alpha 7 II Sony Alpha 7R II Leica Elmarit-M 28mm f/2.8 ASPH Leica APO-Summicron-M 90mm f/2 ASPH Canon EF 24-105mm f/4L IS USM +7 more
captura Forum Pro • Posts: 21,783
It is essentially a system introduced by Sony with the NEX-5R, and employs both phase detection pixels on the sensor, and contrast detection to achieve fast autofocus; hence the term, 'hybrid.'
Here is a short description, from Steve's Digicams:
http://www.steves-digicams.com/news/sony_announces_new_nex-5r_with_hybrid_af_system_and_suite_of_playmemories_camera_and_mobile_apps.html
"This new model contains a host of new features, including a new Hybrid Autofocus System that uses 99 phase-detection AF points arrayed on the image sensor to detect a subject's distance and quickly lock focus on it, and then uses contrast-detection AF to confirm extremely fine, precise details.
The new Hybrid AF design allows users to track rapidly moving subjects via Phase Detect AF, as you would normally find in a dSLR model versus a Mirrorless Compact Camera. Sony is not the only one to integrate the Phase Detect AF Sensors into the main Imaging Sensor, so that no separate AF Sensor is needed to provide faster Focus. This is similar to the Hybrid AF technology we saw introduced in Nikon's 1 Series cameras, like the recently announced J2, which has 73 AF points on the main imaging sensor used for Phase Detect AF.
In Speed Priority Continuous Shooting Mode, the Sony NEX-5R switches to Phase Detect AF Tracking automatically using it's 99 AF points to maintain accurate focus on a subject while taking photos at up to 10 frames per second. That's the kind of performance you normally see from a high end Professional Grade dSLR, not from a smaller Compact Camera model like the NEX-5R. The evolution of technology we're seeing in newer cameras like this is amazing."
GaryW Veteran Member • Posts: 8,192
No flappy mirror thingie.  Less lag.
Gary W.
 GaryW's gear list:GaryW's gear list
Sony Alpha NEX-6 Sony E 16-50mm F3.5-5.6 PZ OSS Sony E PZ 18-105mm F4 G OSS Sony Cyber-shot DSC-V3 Sony Alpha DSLR-A100 +9 more
Jim King
Jim King Veteran Member • Posts: 8,109
Curious about the Bionz X image processaor. Is is unique to Sony or is it made by a third party, such as Fujitsu. The Fujitsu MB86S22AA is used by several camera makers (Nikon, Pentax) in their latest 24 MP bodies, I believe.
Jim King - Retired Colormonger - Suburban Detroit, Michigan, USA; GMT -5h (EST)
Pentaxian for over 50 years.
There is hardly anything in the world that some man cannot make a little worse and sell a little cheaper, and the people who consider price only are this man's lawful prey.
- John Ruskin
A fanatic is one who can't change his mind and won't change the subject.
- Sir Winston Churchill
The difference between genius and stupidity is that genius has its limits.
- Albert Einstein
 Jim King's gear list:Jim King's gear list
Leica M Typ 240 Pentax K-3 Pentax MX-1 Fujifilm X30 Leica M9 +68 more
Bart Hickman Veteran Member • Posts: 7,256
No mirror blackout
The dedicated sensor may well be able to determine a focus point quicker, but it has to cope with the mirror blackout.  If a subject is moving, the SLR must calculate where it thinks the subject will be when the picture gets taken perhaps 0.1s after the last AF measurement was made and then "catch up" once the mirror flips back up to try to reacquire the subject.  Predictive AF is usually only available on the higher-end DSLR's.
With the PDAF on the sensor, the camera can continue focusing with no interruptions.  No need (or much less need) for predictive AF.
It was only a matter of time before camera processors got fast enough to take advantage of the lack of mirror blackout.
Bart
 Bart Hickman's gear list:Bart Hickman's gear list
Sony Alpha NEX-6 Sony a6000 Pentax smc FA 50mm F1.4 Sony E 55-210mm F4.5-6.3 OSS Sony E 10-18mm F4 OSS +10 more
EinsteinsGhost
- John Ruskin
- Albert Einstein
Bionz is a Sony product.
Nikon uses Expeed which is manufactured by Fujitsu. Not sure about Digic (which is used in Canon).
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
DtEW Senior Member • Posts: 2,167
5
Simple.
 DtEW's gear list:DtEW's gear list
Canon EOS 6D Sony a6000 Samyang 14mm F2.8 IF ED MC Aspherical Samyang 24mm f/1.4 ED AS UMC Sony E 50mm F1.8 OSS +17 more
viking79
viking79 Forum Pro • Posts: 14,137
Even some dedicate CDAF cameras are faster than some PDAF cameras.  There is no hard rule saying PDAF is better than CDAF.
Historically, CDAF has been slower as it takes video from the sensor, does some image processing on it, and determines where it is sharper.  Better algorithms might take too much power or require more powerful processors to perform the calculations in real time (fast enough that the processor has some idle time).
Some huge limitations are how quickly you can read out data from the sensor, how quickly you can detect edges in that data, etc.  Now with faster sensors that can refresh the video at say 120 times or 240 times a second instead of 30 times a second, lens motors designed to step through a range of values very rapidly and precisely, software calibrated to the lens that can analyze the image to see how defocused a lens is, etc, and CDAF has become very fast.
CDAF has some weak points, like low light means it has to integrate the video longer to get strong enough edges to detect, etc.  So this quickly it can step through the focus range, etc.
Eric
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
Riquez
Riquez Contributing Member • Posts: 923
Can anyone comment how the A6000 AF speed of 0.06 compares to the NEX6 speed  so we can get an idea of how much of an improvement it is?
 Riquez's gear list:Riquez's gear list
Sony Alpha NEX-6 Sony E 16mm F2.8 Pancake Sony E 30mm F3.5 Macro Sony E 55-210mm F4.5-6.3 OSS Sony E 35mm F1.8 OSS +10 more
SHood Veteran Member • Posts: 4,575
Remember the Aptina patents
I think we are now seeing the benefits of the patent cross license agreement between Sony and Aptina last March.  Aptina developed the Nikon 1 sensor that has fast on-sensor PDAF.
http://www.imaging-resource.com/news/2013/03/01/aptina-sony-agree-to-cross-license-patent-portfolios
 SHood's gear list:SHood's gear list
Sony RX100 Panasonic Lumix DMC-GH3 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko 300mm F4 IS Pro
Re: No mirror blackout
Bart
But in order to overcome these difficulties, Canon is trying new things with their DSLR, hence the dual pixel technology.
Canon develops new Dual Pixel CMOS AF technology for significantly improved autofocus performance during Live View shooting and when shooting movies
http://www.canon.com/news/2013/jul02e.html
Canon 70D with dual-pixel CMOS AF: The first DSLR that can autofocus videos
http://www.extremetech.com/electronics/160232-canon-70d-with-dual-pixel-cmos-af-the-first-dslr-that-can-autofocus-videos
Eric
It's the physics. It's much easier to get very fast CDAF with a quarter-sensor camera like an M43 Olympus or Panasonic.
Re: Remember the Aptina patents
Yes, it could be. My 1" sensored Nikon 1 is definitely faster than my NEX-5R, and probably faster than the also-1" sensored RX100. But the Aptina sensor is only part of the story. The Nikon 1 has a very-smart dual core processor.
paul1508 Regular Member • Posts: 402
Bart
The next step would be to completely eliminate the mechanical shutter (electronic activation and deactivation of image capture) so PD-pixels don't have any blackout at all.
Can't wait to see this technology to come into mobile phones. In my opinion, the camera market below 300€ is dead. You can get a NEX 3(whatever iteration is the newest one) for so cheap money and anything cheaper can't really stand out from 'good' smartphone-cameras.
FuzzyQball
FuzzyQball Senior Member • Posts: 1,369
Just a different type of PDAF
Glenn
 FuzzyQball's gear list:FuzzyQball's gear list
Sony Alpha NEX-5N Sony a6000 Sony E 18-55mm F3.5-5.6 OSS Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS +1 more
I think you'll always want to have the mechanical shutter be optional.  Electronic shutters don't completely shut off the sensor and the mechanical shutter keeps the sensor in the dark and therefore reduces noise.
Hopefully it scales to the small size.
