Sony A7 Flash
Started Feb 12, 2014 | Discussions
juvx
juvx Senior Member • Posts: 1,259
Sony A7 Flash
Im sure this has been asked before but what flash do you guys use for the Sony A7 or A7r? I just bought a A7. I dont mind using a non sony brand in its standard hot shoe im just looking for the best option.
 juvx's gear list:juvx's gear list
Canon EOS 5DS R Fujifilm X-Pro2 Canon EF 70-200mm f/2.8L IS II USM XF 90mm Fujifilm XF 16mm F1.4 R WR +2 more
Sony Alpha 7 Sony Alpha 7R
NicolasKL New Member • Posts: 18
Re: Sony A7 Flash
I bought a Sony 20m mainly because I don't usually need a high powered high featured flash and the small size of the A7R is one of the main selling points for me so having a flash I can fit in my shirt pocket is a big benefit.  Just got it last night so I haven't used it extensively, but it seems capable for what it is, somewhere in between a built in flash and a "real" flash.
I may also pick up a F43M if I think I'll get some use out of it, but I'm mostly a landscape photographer, I just want a flash for casual candids, so I probably don't really need anything better than the 20m.  Though if I do pick up a higher end flash, I can use the 20m to trigger it if I want, which is a bonus.
Seems to me that using a standard hot shoe would be missing out on some benefits (though probably gaining in other areas), but someone else can probably chime in better than I on that.
darkdirtydwarf
darkdirtydwarf Senior Member • Posts: 1,020
Re: Sony A7 Flash
In my opinion the best option is the HVL60FM. I have it and I'm amazed. I was already happy with the older HVL58FM, but the 60 it's even better (and comes with a diffuser too...).
Of course "best" is relative. Do you need a smaller size? How powerful should the flash be?
 darkdirtydwarf's gear list:darkdirtydwarf's gear list
Sony Alpha 7 Sony Alpha NEX-5N Sony SLT-A55 Sony Alpha NEX-5 Sony E 18-200mm F3.5-6.3 OSS +8 more
SQLGuy Veteran Member • Posts: 4,221
Re: Sony A7 Flash
Depends on what you want to do.
For most things, I think the HVL-F20M, which I bought, is pretty good. It's small, surprisingly powerful, and meters very well, even with manual lenses, adapters, etc. Two things it doesn't do are turn sideways or high speed sync. If either of these features are must-haves, then you would have to look at the higher end models. I bought this one because it's small enough to keep in my bag all the time.
For a more powerful, more flexible, but less automatic flash, I have an old Canon 299T. That unit has an auto mode, so it can be used without TTL or pre-flash.
A7 with kit lens and a number of legacy lenses (mostly Canon FD)
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Nikon D200 Sony Alpha 7 II Sony Alpha NEX-7 Nikon AF-S DX Nikkor 35mm f/1.8G +2 more
Brian_Smith
Brian_Smith Senior Member • Posts: 2,529
Re: Sony A7 Flash
The HVL-F43M is really nicely balanced and sized for the A7/A7R cameras.
zilver Contributing Member • Posts: 708
Can you please show camera pic with the 20m flash?
Can't find the picture of the A7 with the 20m flash anywhere, would like to see if's it still small.
Thank you.
 zilver's gear list:zilver's gear list
Fujifilm X100T Leica Q Sony Alpha 7R II Fujifilm X-Pro2 Nikon D500
Re: Can you please show camera pic with the 20m flash?
Thank you.
I can post a pic when I get home.  Depends on your definition of small.  It's a relatively small flash, but when mounted on the camera it still sticks up a fair amount even when it's in the down/off position.  It's not something you could leave mounted and shove in your pocket.  It is something you could leave mounted and put in a camera bag as long as the camera bag was accomodating, though I'd be a little worried that any pressure on the end of the flash would leverage quite a bit of force onto the flash mount, so I probably wouldn't ever do it.
juvx
juvx OP Senior Member • Posts: 1,259
Re: Sony A7 Flash
I was considering that but iv heard so many bad things about it overheating after a few shots....
juvx
Re: Sony A7 Flash
Thank you Brian, after doing a bit more research thats probably what im going to go with.
CraigArnold Contributing Member • Posts: 695
Another option...
I have the 20M on order for TTL fill-flash. (Very hard to get in the UK for some reason!)
For manual flash the Yongnuo wireless trigger and receivers work well, my current set:
  • RF602 trigger and one receiver
  • 560 iii flashgun (has a built in wireless receiver but will also fire directly from camera)
  • MR 58 macro ring flash (fires on receiver or directly from hotshoe)
All 3 of the Yongnuo items listed above had a combined cost (£120) of less than the 20M (£130), but I do want a small TTL solution for on-camera fill - hence the 20M.
I expect the 20M to work with the wireless receiver from the RF602 (I have tested it on Canon and Yongnuo flashes) so with the current set up I'll be able to have on manual both the 20 and the 560 or the ringflash and the 560, but additional receivers are £8 so I could even have all 3 going at once.
Of course with the Sony 600 you get TTL, but it costs £460 and only one light source!!
Blog ------------------------ http://craigspics.net/?tag=blog
X100 Blog ----------------- http://craigspics.net/?cat=6
X100 Quickstart Guide -- http://craigspics.net/?page_id=1345
 CraigArnold's gear list:CraigArnold's gear list
Fujifilm FinePix X100 Olympus Tough TG-4 Sony Alpha 7R Sony FE 35mm F2.8 Sony FE 55mm F1.8 +2 more
Heaven is for real
Heaven is for real Senior Member • Posts: 2,320
Thank you.
Found this on the web
 Heaven is for real's gear list:Heaven is for real's gear list
Nikon D7000 Sony Alpha 7 Sony SLT-A77 Sony FE 35mm F2.8 Sony DT 16-50mm F2.8 SSM +2 more
scotbot Senior Member • Posts: 1,192
Re: Another option...
Camera Centre in Newport have them in stock, mine arrived yesterday. They're Sony Pro dealers so a good source for hard to get kit.
darkdirtydwarf
Re: Sony A7 Flash
Don't listen to everything you hear
I did pretty intensive shootings and it NEVER overheated. It does overheat ONLY if you use it at full power repeatedly, which is never gonna happen in real life since you never need all that power for several shots in a row.
Read this post here from another dpreview user to have a better idea of what I'm talking about:
http://techandgadgets.tumblr.com/post/53109481756/does-sony-hvl-60m-overheat-part-ii
Re: Sony A7 Flash
It probably will also overheat if you're always using it for HSS. But pretty much all flashes will overheat after too much HSS use.
darkdirtydwarf
Re: Sony A7 Flash
I really did put some stress on it after reading the bad comments regarding overheating before the time to give it back would run out and I never ever had a single problem.
I think the issue has been blown out of proportion, and as you say, in some conditions every flash would have limits. Frankly I'm really happy with it (as I am with the HVL58FM) and I warmly recommend it (I get perfect exposures with it and it never misses a shot - the 58 did, once in a while).
Chad Hardy
Chad Hardy Senior Member • Posts: 1,191
Re: Sony A7 Flash
The 43 fits well on the A7, especially if you have the vertical grip.  The 20 seems like the way to go for a first flash anyway, because to use the 43 wirelessly you need a flash on camera anyway (or a PW/cable).
 Chad Hardy's gear list:Chad Hardy's gear list
Fujifilm X-T1 Fujifilm XF 56mm F1.2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Sony Cyber-shot DSC-RX100 III Sony Alpha 7R +16 more
Ken Sky Regular Member • Posts: 294
Re: Sony A7 Flash
Will the HLV-F20 with adapter for multinterface shoe on A7r work as well as the newer model?
 Ken Sky's gear list:Ken Sky's gear list
Sony RX100 Sony Alpha DSLR-A900 Sony Alpha NEX-7 Sony a6000 Sony Alpha 7R II +5 more
Re: Sony A7 Flash
Yes. Though I've heard of some problems with 3rd party adapters. Probably worth spending a few extra $$ for the Sony one.
blue_skies
blue_skies Veteran Member • Posts: 9,640
Re: Sony A7 Flash
At the risk of repeating others, I recommend getting both the HVL-F20M and HVL-F43M flash units. (Do get the M versions, not the older AM versions, for you'll need adapter sockets).
The 20M is very compact and can be used as a travel flash, as well as a wireless trigger for the 43M. They allow for HSS and TTL shooting.
If you want to go with non-TTL third party flash units, I recommend getting the Cowboy Studio adapter with external flash units. E.g. units like the TT560 or the YN560-II are very similar to the 43M, but are much cheaper, and can be set up in manual mode to behave more or less identical. The 43M works with the Cowboy Studio adapter too, but the 20M does not, as it lacks a manual mode.
If you use flashes in non-TTL mode, you have to dial in the settings, based on the scene. Even though some of these newer flashes have LCD screens, I find it easier to just install an app on your smartphone and derive the settings from there.
And do get the Gary Fong diffuser too. It is easy to use and it works, for when you have no ceiling to bounce of.
Henry
Sony Alpha NEX-6 Sony a6000 Sony a5100 Sony Alpha 7 II Carl Zeiss Biogon T* 2/35 ZM +33 more
Thank you.
This looks pretty big for travel.
