a6000 faster than OMD E-M1, faster than most DSLR's (if not all). Good job SONY.
Started Feb 12, 2014 | Discussions
Tone Row
Tone Row Regular Member • Posts: 334
Re: a6000 faster than OMD E-M1, faster than most DSLR's (if not all). Good job SONY.
pew pew wrote:
well, this means the new A mount cameras will probably loose the translucent mirror, wich is good news, I just wonder why they didn't implemented this on the a7/a7r, maybe the extra focus points in the sensor reduces quality idk.
My guess would be that their OSPDAF R&D advances are coming so fast now that they didn't have this technology when it came time to manufacture the A7(r) sensors.
 Tone Row's gear list:Tone Row's gear list
Sony SLT-A55 NEX5R
cptobvious
cptobvious Contributing Member • Posts: 714
To me the question is whether the current E-mount lenses can focus quickly enough to match the camera.  Even if the processor is more responsive, if the motors inside the lenses take too long to move the focus elements then the point is moot.  My experience owning the NEX-6 and Sony G lenses is that some of them took longer to rack focus from one end to the other than the newer Olympus MSC/Panasonic lenses for Micro 4/3.  If the A6000 and Sony lenses can match current M4/3 focusing speeds, then there's a good chance I'll switch back to Sony.
stevo23
stevo23 Forum Pro • Posts: 10,110
EthanP99 wrote:
its 49 jpegs apparently
so about 5 seconds
Wait, that's 9.8 fps...
D4s is 10fps for 20 seconds with full resolution RAW files with full autofocus/metering/auto ISO for each shot.
Not to dampen the enthusiasm, but you get what you pay for.
 stevo23's gear list:stevo23's gear list
Sony Alpha 7 Nikon AF Nikkor 20mm f/2.8D Tamron SP AF 90mm F/2.8 Di Macro Sony FE 35mm F2.8 Sony FE 55mm F1.8 +1 more
sean lancaster
sean lancaster Veteran Member • Posts: 6,729
Re: a6000 faster than A7/A7r, Good job SONY ???
arphoto wrote:
Why a "so bad so slow" autofocus in entry level A7/r ?
I am perplexed that Sony was apparently this close to having the "fastest AF in the world" and didn't put it in their revolutionary full frame mirrorless entries released not too long ago. $1,000 more for an A7 and the AF was spotty for me in available light settings. Then again, the A6000 has yet to hit the real world.
I wonder if the extra focus points on the A6000 sensor are going to impact light reaching the sensor and, thus, DxOMark scores?
 sean lancaster's gear list:sean lancaster's gear list
Sony Alpha NEX-5N Sony Alpha 7 Sony Alpha 7R II Voigtlander 35mm F1.2 Nokton Sony FE 55mm F1.8 +4 more
stevo23
Faster for 3 seconds?
Donny out of Element here wrote:
Well, 11fps with live tracking AF is something. It's faster than OMD E-M1 and mind you it's an APS-C sensor with 24.3 Mp! Fastest AF (in the world?) 0.06s CIPA.
For 3 seconds? How long of a burst do you maintain 11fps? And how many times can you do that in a minute? How many RAW images can you rip out per second?
I honestly see no point in any further mirror usage in cameras from now on.
Because the mirrored D4s can shoot 10fps for 20 full seconds and crank out 200 full resolution RAW files with full tracking autofocus/metering/auto ISO etc. for each shot. And right away, it can turn around and do it all over again. All day long. Processor/buffer is just as important.
Not to dampen the enthusiasm, but you get what you pay for. I'm just sayin', keep it all in perspective.
SDF
SDF Senior Member • Posts: 2,131
Nikon D4 is $5000 and A6K is $650. Indeed, you get what you pay for.
stevo23 wrote:
so about 5 seconds
 SDF's gear list:SDF's gear list
Fujifilm FinePix X100 Sony RX1 Panasonic Lumix DMC-L1 Sony Alpha NEX-7 Sony Alpha NEX-6 +3 more
TrojMacReady
TrojMacReady Veteran Member • Posts: 8,683
I'm not. The sensor in the A7R is basically based on a 2 year older design. Plus, the larger the sensor, the harder it is to get fast read out speeds, which is crucial for fast on sensor PDAF.
Maybe they could have made improvements to the original 36MP sensor in this regard, but that would surely have driven up cost too and margins are what Sony needs currently.
bryanchicken
bryanchicken Regular Member • Posts: 309
stevo23 wrote:
so about 5 seconds
LOL. I just looked up the D4S, having never heard of it. Its a £4k+ camera in the UK and its blimmin' HUGE.
I'd pick the A6000 all day long thanks.
Habs Fan27
Habs Fan27 Contributing Member • Posts: 577
Re: Faster for 3 seconds?
I don't think potential A6000 buyers are cross shopping it with a D4s.  If the AF speed/accuracy/tracking is as advertised, it's probably good enough for 99% of the people out there and way better than anything remotely close to this price point.
nevercat
nevercat Senior Member • Posts: 3,193
You are right the D4 can shoot 7 times longer at (about) the same frame rate! But that speed has nothing to do with the mirror anymore. Sony could build a mirrorless  camera with the same buffer and processor and we would see the same performance.
To put the D4 in the same perspective:look here at the size difference
And take a look at the price: For the D4 you pay $5100
For the A6000 you pay$800
Indeed you get what you pay for. I know what lenses I should buy for that $4300 I save with the A6000....
KelvinHammond
KelvinHammond Regular Member • Posts: 323
Re: ok... then try using a mirrorless...
for studio portraits. it sucks.   There's no way around it either. The mirrorless system reacts just like a camcorder, which means the rear screen and evf are worthless in cave lighting. (torches, or modeling lights). What the mirror does, is let your eyes and brain see right through the glass, without electronics pre-interpreting that information. The only way they could fix it is with some sort of active rangefinder setup that had zoom or focal length auto-simulations.
 KelvinHammond's gear list:KelvinHammond's gear list
Canon EOS 50D Canon EOS 7D Sony Alpha NEX-7 Canon EOS 6D Samsung NX300 +10 more
nevercat
Well I don't see what you mean here. I just tested with my Nex 5 (first generation Nex) and was able to manual focus on a subject by using the LCD the exposure time was 8 seconds by F4! How dark is it in your studio? When you are in manual mode then:  I think you should try to read the manual of the camera as there is an option to switch off the mode that try to show what you will see when you shoot at the given apperture/shutterrtime/ISO. When there is no such option you can open the flash and you will see the immage without problem...
By the way, the A6000 is not a real professional camera and it will miss more features you use in a studio...
GaryW
GaryW Veteran Member • Posts: 8,111
I guess you should have added the caveat of, for the vast, vast majority of people, including most photographers.
How often does one need to do this?  Is this for "spray and pray" photography?  I doubt most pro photographers' cameras do this today.  Of course, if you need this, or some other feature, you should buy the camera that does it, but let's keep it in perspective.
I can understand a 1 second buffer (in my Nex-6) is a bit short, but after 2 or even 5 seconds, I can't imagine what I'm still shooting.  The action is over with.    Anything longer, and maybe I should have used video.    At least then I have 60fps for as long as I want.
And you do pay for it!  In money not just for the camera but for lenses, because you wouldn't just plop a kit lens on a $5000 camera.  And not just in money, but for the bulk. It's not exactly a good travel setup.
I think most of us are?
Gary W.
 GaryW's gear list:GaryW's gear list
Sony Alpha NEX-6 Sony E 16-50mm F3.5-5.6 PZ OSS Sony E PZ 18-105mm F4 G OSS Sony Cyber-shot DSC-V3 Sony Alpha DSLR-A100 +9 more
GaryW
Do you mean "live view"?  I think the Nex-5 always uses this -- you can't turn it off like you can with other Nex cameras.  But, yeah, it should try to brighten the view in the dark, unless it's crazy dark.  If you're doing a studio shot, you should probably add enough light to get a quality result.
Using your test, up to about 2" of exposure, I could still see well enough through the viewfinder/LCD to frame the shot, although it was grainy and lagged if I moved.  I'm not saying it's ideal, but that kind of low light is not ideal shooting conditions anyway.  At 5", the display was too dark and faint to see anything, while I could still see objects with my eyes.
But the bottom-line is, why wouldn't the live view give you a bright (if grainy) display in any reasonable light?
Gary W.
Red G8R
Red G8R Senior Member • Posts: 1,722
Having the fastest AF amongst mirrorless cameras didn't make the Nikon 1 a success.
Peter
Ontario, Canada
 Red G8R's gear list:Red G8R's gear list
Nikon D4 Fujifilm X-T1 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +9 more
BRN KNG
BRN KNG New Member • Posts: 15
I'll wait until more reviewers are able to get their hands on the camera and test the autofocus in different situations before I crown the A6000 the king of autofocus.
Fuji claimed the X-T1 focuses in 0.05 seconds. So there's the claims under certain conditions and then there's the real world performance. I put more stock in the latter.
LTZ470
LTZ470 Forum Pro • Posts: 11,926
Re: Nope.
Tom Ames wrote:
Shall we say that DSLR speed from now on is lagging behind latest mirrorless cameras like a6000? I honestly see no point in any further mirror usage in cameras from now on.
That's not a rack focus speed.
Here' what sony said:
1.Amongst interchangeable-lens digital cameras equipped with an APS-C image sensor as of February 12, 2014. Determined with internal measurement method with E PZ 16-50mm F3.5-5.6 OSS lens mounted, Pre-AF off and viewfinder in use
Lol, still grasping onto the believe that your $1,400, smaller m43 sensor, bigger and heavier body, humped, 16Mp, E-M1 is faster?
Hint: it will be so close, it won't matter.
Your E-M1 is beaten by a $650, larger APS-C sensor, smaller and light body, hump-free, 24Mp, A6000.
I can now see the resale value of the E-M1 dropping like a rock, and dropping again, ....
I can hear the pattering of feet of the buying public already, lines form on the left ...
Henry
I had a thread just a few days ago looking for a camera in addition to my A7r. I would very much like to try the EM-1, but with fast auto focus being my main concern, I just may have to sit on the fence for a month and see what happens. Would suit me just fine if I could get a EM-1 to a very very good used price or perhaps the A6000 actually will be the better solution. I do like the layout and design of the EM-1, but it will be hard to justify, if the A6000 is better at focusing and have a larger sensor as well (important to me for indoors shooting).
Sorry Tom, but indoors the PDAF will not work and Sony CDAF will take over...it probably won't AF very fast and will struggle...same as Nex-6...
The old adage applies here since no one owns it yet...if it sounds too good to be true...probably is...
Then good AF long lens will be scarce...55-210 is nice, like the size, but all in all a not exactly stellar...even shooting in bright sun against the EM5 Oly the Nex-7 with 55-210 was too slow to capture the Blue Angels very well...the EM5 100-300 Panasonic did very very well...EM1 is even better...
--Really there is a God...and He loves you..
FlickR Photostream:
www.flickr.com/photos/46756347@N08/
Mr Ichiro Kitao, I support the call to upgrade the FZ50.
I will not only buy one but two no questions asked...
TrojMacReady
Re: Nope.
Henry
Based on which A6000 test is this claim?
This  (indoor low light), suggests otherwise.
LTZ470
Indoors it will probably struggle Donny...this is probably in bright daylight only...
FlickR Photostream:
buellom
buellom Contributing Member • Posts: 511
Re: ... and faster than all D-SLTs ...
Ooops!
www.freude-am-licht.de
