Former Canon user moving to a77, question about lenses.
Started Feb 10, 2014 | Questions
CTR1
Contributing MemberPosts: 568Gear list
Feb 10, 2014
So I am interested to moving the a77 for various already researched reasons and comparisons.
I am trying to learn the lens compatibilities of/with the a77 and possibly later on moving to the a99 or other future Sony full frame camera.
So far all I know is that the "DT" lenses don't work on FF, but how do you tell about the rest of the lenses? Is there a Canon or Nikon like marking/numbering/lettering to indicate this?
Thanks!
Calvin
There's always a catch. Life is a catch. You better catch it while you can.
Sony SLT-A77 Sony SLT-A99
dlkeller
Veteran MemberPosts: 6,922
Re: Former Canon user moving to a77, question about lenses.
In reply to CTR1, Feb 10, 2014
Go the dyxum.com and you'll get information on all A mount lenses, both dx and ff, including old Minolta and 3rd party lenses.
As to your specific question I believe all non-dx lenses are full frame, but am not certain.
Dave
K E Hoffman
Senior MemberPosts: 4,657Gear list
DT covers APC but works on FF cropped
Main thing is SEL  / E or FE lenses are for mirrorless e-mount cameras don't buy them for a77
SAM/SAM II have internal focus motors but must be set to MF before you can turn the focus ring
SSM are faster usually guieter and you can turn focus ring at any time to manually adjust
G and Zeiss are the premium lenses optically,  but some of the non G like the 16-55 f2.8 are really great lenses,
Some of the old Sony and Most of the older Minolta lenses are screw drive where the body drives the lens focus.  If you turn on DMF direct manual focus. .. the body disengages after AF so you can like on SSM lenses tweak focus manually after AF complete s
Welcome to Sony shooting
Google "Friedman Archive" And buy his a77/a65 ebook requied good reading for any new Sony owner !!!
K.E.H. >> Shooting between raindrops in WA<<
Don't Panic!.. these are just opinions... go take some pictures..
 K E Hoffman's gear list:K E Hoffman's gear list
Canon EOS 450D Nikon 1 J1 Sony a77 II Sony a6000 Sony 70-300mm F4.5-5.6 G SSM +8 more
hajime93
Forum MemberPosts: 79Gear list
Hello there, welcome aboard (if you've already made up your mind heh)
Before I go into lenses, you might want to wait for a month or two before getting the cameras because the a79 successor is rumored to be around the corner, with the possibility of it being announced in March or April. I do hope Sony announce a cheaper full frame, or a successor to A800 though...
On the lenses, yes you're right, DT works on APS-C like the A77 you mentioned, mounting DT lenses on full frame will get you heavy vignetting. The good thing about a99 is that, is has an auto crop that gets rid of those vignetting and crop the frame like an APS-C camera would see, in the expense of losing megapixels.
But there are already a handful of full frame lenses for the alpha system out there, which have basically covered all your needs. You can also look in the old minolta lenses which is all full-frame capable, with half of the price!
There are also other letters in the alpha lens system that you should be aware of, such as SSM focusing which is super silent and faster autofocus. and the G series and Z (Zeiss) series lens, which is basically premium lenses, just like L lenses in Canon.
and yes, as stated by the previous user, check out the website for more info on that, or http://kurtmunger.com/
Hope it helps you~
 hajime93's gear list:hajime93's gear list
Sony SLT-A57 Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Sony DT 18-55mm F3.5-5.6 SAM Sony 85mm F2.8 SAM Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO +7 more
CTR1
CTR1 OP
In reply to dlkeller, Feb 10, 2014
Awesome, thanks! I'll check it out soon!
Calvin
CTR1
CTR1 OP
In reply to K E Hoffman, Feb 10, 2014
Wow, great information. Thanks for that!
Calvin
CTR1
CTR1 OP
In reply to hajime93, Feb 10, 2014
I debated on whether I should wait for the a77 replacement and for the price, reviews, etc I think I can live with having the a77 vs it's annoucement. Not to mention I just sold my camera body today and will be shipping my lenses tomorrow.
So from what I gather based on your post as well as the others' responses, I can't buy lenses that would work 100% on FF and crop sensor cameras?
Thanks!
Calvin
tqlla
Senior MemberPosts: 2,731Gear list
Thanks!
Calvin
I believe that the Full Frame A mount lenses are the only lenses without a designation. Example
  •      = Full Frame Amount.
  • DT = Crop Amount lens
  • E = Emount (not compatible with A77/A99)
  • FE = Full Frame Emount (not compatible with A77/A99)
All DT lenses work on the A99, but it will put the A99 in 10MP crop mode
All FF Minolta/Sony Amount lenses work on the A77 and A99
You can find a bunch of nice Minolta lenses for cheap. The 50mm 1.7 is also a good/cheap choice.  The Minolta 28-105mm RS lens is also good... but it may be too long for indoor shots with the A77.
 tqlla's gear list:tqlla's gear list
Sony Cyber-shot DSC-RX10 Sony SLT-A99 Sony Alpha DSLR-A850 Sony 16mm F2.8 Fisheye Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +8 more
Glenn
Veteran MemberPosts: 7,392
Thanks!
Calvin
All Sony Lenses except the E-mount lenses and all Minolta Maxxum lenses work on all Sony bodies so far. On a full frame camera the crop lenses (designated as DT) will work but the camera will switch itself to crop mode.  All the lenses on APS-C bodies will be cropped  x 1.5 whether for full frame or only for crop cameras.
dannybgoode
Contributing MemberPosts: 829Gear list
In reply to Glenn, Feb 10, 2014
The A77 is a hugely capable camera.  I moved from Canon a couple of years ago (50D) and haven't looked back.
The IQ and handling of Sony's cameras really is first class and at the time I was upgrading the 7D was starting to look long in the tooth and I have never liked Nikon's (purely subjective - I am sure they are excellent cameras).
Just a note regarding the 'kit' 1650 lens that generally comes with the A77.  I use the ' ' because this is not your usual cheapo kit lens, it is a very serious piece of glass.  f2.8 across the range, weather sealing and a 72mm diameter front element.  I shoot with it most of the time and rarely feel the need to stick a prime on.
Agree with the recommendation on the book, read it and learn all the features of the A77 and you will have a great time!
 dannybgoode's gear list:dannybgoode's gear list
Sigma DP2 Merrill Ricoh GR Digital IV Fujifilm X-Pro1 Canon EOS 5D Mark III Fujifilm XF 18mm F2 R +7 more
LSHorwitz1
Senior MemberPosts: 2,373Gear list
In reply to dannybgoode, Feb 10, 2014
+1 on moving from Canon and also sold all my Canon L glass and moved to Sony a77, NEX, and Zeiss glass. Really glad I did. Full time EVF Live View is a leap into the 21st century from old school Canon.
Larry
cplunk
Senior MemberPosts: 1,740Gear list
Um, no.  All the A mount lenses work on all the A mount cameras with near universal compatibility. No screwy software limitations, except for the lenses designed specifically for the smaller sensor not covering the whole full frame sensor, but the camera has some functions to make up for that. (the biggest exceptions to the rule is a 20 year old Sigma lens)
All of the A mount lenses will work on the A77. The full frame lenses will work just fine on the crop sensor, the only real downside is they may be heavier or larger than necessary, but there is no loss of functionality.
On the A99, all the full frame lenses will work as expected. The DT, crop frame lenses, will work in a crop mode on the camera. With Sony's lenses it will use this mode automatically when the lens is mounted, with Sigma or other 3rt party lenses there is a menu option to use the crop sensor mode.
The full frame lenses work on both, no hindrances or issues.
Sony "E" mount, SEL model lenses are made for the NEX, ILCE cameras, and won't fit the A mount A77 or A99, entirely different mount / flange distance. (there is a adapter to put the A mount on the E amount cameras, but not the other direction).
 cplunk's gear list:cplunk's gear list
Sony RX100 Sony SLT-A99 Sony Alpha DSLR-A900 Sony Alpha DSLR-A330 Sony Alpha NEX-6 +22 more
Renato1
Veteran MemberPosts: 3,324Gear list
The only thing I'd add to what the others have written, is that if you buy second hand lenses you have to be careful with Sigma A-mount lenses. Those made before the SLT cameras were introduced can be incompatible with SLTs (they might work fine in single shot mode, but not in continuous shooting) unless they've been re-chipped.
Later Sigmas work fine.
All Tamrons work fine in SLTs.
Renato
Yemble
Senior MemberPosts: 2,285Gear list
Thanks!
Calvin
Sensible. I very much doubt that the A77 successor will be available to purchase before October, given Sony's past history with bringing A700, A77 & A99 to market.
As others have said, make sure you buy the A77 with the "kit" 16-50mm f2.8 lens.  Had this been a FF lens, it would have been given a G designation.
 Yemble's gear list:Yemble's gear list
Sony a77 II Sony SLT-A77 Sony Alpha DSLR-A700 Konica Minolta Maxxum 5D
thebustos
Senior MemberPosts: 2,648Gear list
If you want lenses to use on the A77 and on a ff camera later, you can buy lenses that give full game coverage. These include all the Carl Zeiss lenses (except the DT 16-80mm f/3.5-4.5 Carl Zeiss), Sony G-series lenses, Minolta AF lenses, the Sony 85mm f/2.8 SAM, 28-75mm SAM, 50mm f/1.4, and 75-300mm f/4.5-5.6.
Any lens marked DT does not provide full frame coverage and is meant to be used with APS-C cameras. You can use these on the A99, but the camera automatically applies the 1.5x crop you normally get with APS-C bodies and drops the resolution to 10mp instead of the normal 24mp because it's using a smaller part of the full frame sensor. I think you can turn that off, but you'll get vignetting because DT lenses are designed to only fully cover APS-C sized sensors.
Some lenses I'd suggest:
DT 16-50mm f/2.8 SSM
DT 35mm f/1.8 SAM
Minolta AF 50mm f/1.7 (full frame coverage)
Minolta AF 70-210mm f/4 "beercan" (full frame coverage)
Good luck and happy shooting!
 thebustos's gear list:thebustos's gear list
Sony SLT-A77 Sony DT 35mm F1.8 SAM Sony DT 50mm F1.8 SAM Sony DT 16-50mm F2.8 SSM Sony DT 30mm F2.8 Macro SAM +17 more
nandbytes
Senior MemberPosts: 5,293Gear list
Welcome to Sony (if you have made up your mind)
Well I think people have generally covered most points on how to identify lenses. One other thing I would add is you can generally guess by the specs and/or focal range of lenses.
Eg:
Sigma 12-24mm (APS-C equivalent is sigma 8-16mm)
CZ 24-70 f/2.8 (APS-C equivalent is sony 16-50 f/2.8)
Sony 28-75 (APS-C equivalent is 18-55)
CZ 16-35mm f/2.8 (APS-C doesn't really have a equivalent afaik but there is tokina 11-16 f/2.8, sigma 10-20mm or tamron 10-24mm)
So you can notice the general trend in focal ranges. If in doubt look up dyxum. The old minolta lenses will be FF.
So I would suggest investing in FF lenses from the start if you have future plans to go FF.
 nandbytes's gear list:nandbytes's gear list
Sony a6000 Sony Alpha NEX-7 Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sony E 10-18mm F4 OSS +7 more
VirtualMirage
Veteran MemberPosts: 3,625Gear list
When looking at third party lenses, keep this in mind:
Sigma Lenses:
  • Lenses labeled as DC are crop sensor lenses.
  • Lenses labeled as DG are full frame lenses.
Tamron Lenses:
  • Lenses labeled as Di are full frame lenses.
  • Lenses labeled as Di-II are crop sensor lenses.
For other, smaller third parties they may use the DX designation to indicate the lens is for crop sensors.
Paul
 VirtualMirage's gear list:VirtualMirage's gear list
Sony RX100 Sony a77 II Tokina AT-X Pro 11-16mm f/2.8 DX Tamron SP AF 90mm F/2.8 Di Macro Tamron SP 70-200mm F/2.8 Di VC USD +18 more
CTR1
CTR1 OP
Thanks for the information, I have been reading and this has come up a lot.
Calvin
CTR1
CTR1 OP
I'm glad you mention the 'kit' lens since I had a couple questions about it.
I tried an in store demo version of the a77 + kit lens and when adjusting focal length during photos or video taking, the lens was quite stiff to adjust - is there a certain mode/function/etc to enable/disable to make it smooth?
Regarding 16-50 f2.8 lens choices, is the Sony one the best to go with or is there a better/equal for less $$?
Thanks.
Calvin
CTR1
CTR1 OP
In reply to LSHorwitz1, Feb 10, 2014
Yeah even though you lose a little light to the EVF, I think it is still worth it imo. Thanks.
Calvin
