NEW DP QUATTRO is coming!!!!!!!!!!!!!
Started Feb 9, 2014 | Discussions
Kendall Helmstetter Gelner MOD Forum Pro • Posts: 19,374
Re: NEW DP QUATTRO is coming!!!!!!!!!!!!!
That is really a surprise... but I have to say it sure seems unlikely someone would go to the trouble to fake this.
But why the Quattro name, with a True III I wonder.
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM +4 more
What you complain about needed no change
marcodadofoto wrote:
If it s true, looks like a big delusion. Orrible design, looks like a bad version of the Sony next. And, same sensor plus same focal length...
The focal lengths were great.
The sensors already slightly out-perform a D800, and have vastly better images (and handling) than the Nex cameras.  As do the lenses outperform lenses for any other camera or body.  So why SHOULD either of those things change?
There are a lot of other aspects that could be much better in the newer cameras.  Even with the same sensor, a TrueIII could improve high-ISO support.
The last things the cameras need is more resolution or improved lenses.
I won t understand the need for this replacement, seriously.
Those who have the current one understand what a new model could offer.
Re: What I see...
SigmaChrome wrote:
  • No Sigma logo on the front of the body -- very strange.
  • Obviously Photoshop-created lens.
  • Lower case 'dp2'. Unlikely.
  • Film plane indicator very close (too close?) to the front of the body.
That's the oddest part to me, I can't see how it could work as-is... but perhaps the way the lens is designed it would work.
  • The battery compartment door looks like it takes a very weird shaped battery. It has a wide groove in the middle.
Probably a three-day battery to make everyone happy at last at about batteries.
zodiacfml Contributing Member • Posts: 521
Re: +1 and it looks real to me
The images look fake since they are indeed CAD designs with some touch of Photoshop.
 zodiacfml's gear list:zodiacfml's gear list
Sigma DP2
maple Veteran Member • Posts: 3,098
Size compare: Merrill v Quattro
By referencing the 58mm filter thread. Quattro is really BIG.
Maple
SigmaChrome Veteran Member • Posts: 7,982
Re: Size compare: Merrill v Quattro
Well done, Maple.
You know, the more I look at the design, the more it blows me away. Sigma has totally re-thought the camera grip concept and at the same time have allowed for a much bigger battery. I really don't care about the extra length as I have a feeling that the camera will be quite well balanced.
So... if this whole thing is real (and I'm getting the feeling that it is), then: Bravo Sigma for thinking outside the box!
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sony RX100 Sigma DP3 Merrill Sigma SD14 +14 more
Although it's impressive you used the filter size to craft a comparison, wouldn't it have worked as well to use the hot shoe opening which has to be a fixed size between any two cameras?
I'm not sure what to make of this.  It's something that has to be seen to be believed, or understood...
Design values..
As a student of engineer, I believe in Sigma's designs and values.  For example, they are indeed the first to put a larger sensor in a compact body.   From the leaked images, the Sigma values are still the same, maximum possible IQ in a compact body which is even made smaller.
The outrageous design is from the necessity of a larger battery. Where else to put a larger battery, in the grip of course.  The flat body just shows the miniaturization and progress of the electronic components on this age of the tablets and smartphones.
The images appear to me are CAD designs with probably one existing prototype.
Sigma DP2
Petroglyph
Petroglyph Senior Member • Posts: 4,885
Re: Fixed 30mm f/2.8? Sounds familiar.
Better have IBIS in there.
Maybe an FF foveon then it doesn't need it.
 Petroglyph's gear list:Petroglyph's gear list
Sony Alpha 7R II Pentax K-1 Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 43mm F1.9 Limited +5 more
Raist3d Forum Pro • Posts: 35,513
Re: What you complain about needed no change
No, they don't. Not like that- it depends on the conditions. The D800 would outperform the current sensor any day for the most part in DR, gradation and of course ISO.  So a new sensor that addresses the ISO more than anything would be welcome.
It will most likely be a new sensor.
The sensor could move forward in ISO.  DR and RAW bitness too, but the key one to improve is ISO.
That I completely agree with 200%
Raist3d/Ricardo (Photographer, software dev.)- I photograph black cats in coal mines at night...
“The further a society drifts from truth the more it will hate those who speak it.” - George Orwell
Can't deny to you that's weird.... yet...
still interesting.
New sensor
is my bet on these. Hopefully much better ISO.
As much as I prefer a compact camera, I still find this design interesting.
You are right. That was thick of me. I actually had thought about going by the size of the hot shoe but failed to google out the dimension. I could have scaled the hot shoe of the two images to exactly the same size. As they stand now, they look close enough in size, I think, so little point to re-do it.
Maple
Kassra Regular Member • Posts: 165
more on the size comparison, based on lens diameter.
i just scaled the images based on the inner filter ring sizes, and snapped all dimensions.
 Kassra's gear list:Kassra's gear list
Sigma DP1 Merrill Sigma DP3 Merrill
I was impressed at how exactly right it seemed to end up using your system. Looks close enough to me!
PrebenR Senior Member • Posts: 3,267
Re: What I see...
Roland Karlsson wrote:
hexxthalion wrote:
S-R admin hopes for CP+ announcement. I just tried to imagine how would i hold it and where would my index finger be, can't quite get my head around it. another thing what might be of interest is two hand operation which would imply touch screen interface - but i'm stretching it now
I think the focus button gives it away. Why a focus button?
To change between AF and MF like it is on all the DPs.
At any rate, everything looks CGI so until I see some real photos I don't think these are real. Interesting how viral they went in the last hours though.
Lightwriting with Sigma
Re: What I see...
It seems to say 8.4V on the bottom. The SD15 batteries are 7.4V.
Re: What I see...
I don't see ampere reading which is odd.
michaeli Regular Member • Posts: 196
It seems true! 5,424×3,616 pixels
 michaeli's gear list:michaeli's gear list
Sigma DP2s Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp2 Quattro Sigma SD14 +5 more
SigmaTog
SigmaTog Contributing Member • Posts: 849
Re: It seems true! 5,424×3,616 pixels
