MFT Users: Do you miss the shallower depth-of-field of bigger sensor cameras?
Started Feb 8, 2014 | Discussions
JBurnett Contributing Member • Posts: 816
Yes, occasionally. More often grateful for greater DOF.
Miss shallower DOF of larger sensor: very occasionally
Grateful for greater DOF of M4/3: more often (landscapes, macro)
 JBurnett's gear list:JBurnett's gear list
Olympus E-M5 II Panasonic 12-35mm F2.8 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Panasonic Lumix G Vario 35-100mm F4.0-5.6 ASPH Mega OIS +9 more
MrScorpio
MrScorpio Senior Member • Posts: 1,365
Yes and No
Sometimes yes, but sometimes it is good to have the good light gathering with a large Aperture without having to have the very shallow DoF.
It all depends on the situation and what you want to achieve...
 MrScorpio's gear list:MrScorpio's gear list
Olympus OM-D E-M5 Canon EOS 6D Nikon Df Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +14 more
Ulric Senior Member • Posts: 3,580
Re: MFT Users: Do you miss the shallower depth-of-field of bigger sensor cameras?
Superzoom2 wrote:
I know you can buy fast MFT lenses for more aperture control, but I'm probably going to just stick with a cheap 14-42 for various reasons.
Whatever those reasons are: skip the cheap kit zoom if you care about background blur.
 Ulric's gear list:Ulric's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GF3 Panasonic Lumix DMC-GM1 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +9 more
Steve_
Steve_ Senior Member • Posts: 2,551
not really
I found the DOF vs FOV relationship for the APS-C geometry a better compromise overall than full-frame, where I was constantly struggling to create enough DOF. I don't much notice the difference between APS-C and 4/3s sensor sizes. I thought I might lack for DOF control when using my 12-35/2.8, but it hasn't been an issue.
Just don't try a 12-35 or 12-40. Priorities might change.
 Steve_'s gear list:Steve_'s gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 +12 more
William Prip Regular Member • Posts: 346
Shallow DOF harder to achieve w/ M43
Superzoom2 wrote:
I'm thinking of buying my first ever MFT camera, an Olympus OM-D E-M10 with 14-42 EZ lens.
I've had lots of compacts and DSLR's, mostly Canon. Once in a while, you have these beautiful blurry background pics when the lens and aperture combination are right. I am a former pro photog, and understand fully camera optics and depth-of-field physics.
I just want to know if you sometimes miss the easily attainable shallow depth-of-field that you usually get with an APS-C or bigger sensor camera.
Thanks!
In a word, YES! I do miss using a large sensor body.
The first three are just fun pics of my son begging to eat a Kit Kat.  Shot with the Canon 5D with the Canon 135 2.0:
The next batch was shot at the NY Fashion Week with my Canon 1D Mark IV with either the 135 2.0 or the 24-70 2.8:
The final batch were short at the same venue with my Oly OMD-EM5 with the 75 1.8:
Dheorl Veteran Member • Posts: 3,211
Re: Shallow DOF harder to achieve w/ M43
Thanks!
I'm confused. You say you miss the shallow DoF of larger sensors but then show two at the end with fairly comparable background blur.
nrwhitman Regular Member • Posts: 389
FF Users: Do you miss the greater depth-of-field of MFT sensor cameras?
So, wonder if this question ever shows up on a FF forum.
 nrwhitman's gear list:nrwhitman's gear list
Olympus OM-D E-M5 Olympus PEN E-PM1 Olympus E-30 Olympus E-1 Olympus M.Zuiko Digital 45mm F1.8 +6 more
benarden Contributing Member • Posts: 573
Re: No
- Not a bit.
ryanshoots Regular Member • Posts: 401
I would guess
Those that did miss it are back in a larger sensor format.  The fact that there are no lenses in m4/3 with the moniker "cream machine" is telling.  On the other hand the 4/3 format excels at many other things.
How much shooting do you do now where a shallow dof is what you want?  What lenses were you using.  Then we can tell you what lens in m4/3 might work for you.  The kit lens offers no shallow DOF.
jhinkey
jhinkey Senior Member • Posts: 2,772
If I need shallow DOF and creamy background that my 75/1.8 can't make, then I simply reach for my D800 . . . otherwise I enjoy the very good IQ and compact size/low weight of my m43 kit.
Same thing for high ISO shooting - I reach for the D800 . . .
 jhinkey's gear list:jhinkey's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-TS3 Nikon D800 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-G5 +21 more
Dave Lively Senior Member • Posts: 1,739
Re: FF Users: Do you miss the greater depth-of-field of MFT sensor cameras?
Deep DOF is limited by diffraction, not sensor size.  If you stop down until diffraction becomes unbearable FF users can get just as much DOF as m43 users.  The FF cameras will be stopped down 2 stops more and using 4 times the ISO but their better high ISO performance makes up most of the difference.
I am using a m43 camera because it is smaller, lighter and much less expensive than FF but still provides good image quality and adequate DOF control for my purposes.  But when it comes to DOF control m43 is at a distinct disadvantage when I want shallow and has no advantage when I want a lot.
Nippero Contributing Member • Posts: 663
Thanks!
The key here is flexibility.
He was only able to achieve such similar shallow DoF with his EM5 when using a 75/1.8. That's equivalent to 150mm.
On the other hand, the 1D was able to obtain shallow DoF with a much wider (as in more varied) FL range.
 Nippero's gear list:Nippero's gear list
Canon EOS 5D Panasonic Lumix DMC-GM1 Panasonic Lumix G 20mm F1.7 ASPH Sigma 50mm F1.4 EX DG HSM Panasonic Lumix DMC-LX3 +2 more
It goes both ways.
No camera system is perfect, for me the DoF argument goes both ways.
I LOVE my Canon 5D with the Sigma 50mm f/1.4. Amazingly smooth, creamy and artifact free bokeh. Almost effortless to achieve.
Sure, you can achieve similar shallow DoF using these 4/3 and APS-C sensors, but that same flexibility isn't there.
On the other hand, sometimes I miss the deeper DoF of m43s, because there will be the times that I want to use the aperture wide open without getting paper-thin DoF.
dwstv Junior Member • Posts: 39
NO! Full frame is too shallow.
 dwstv's gear list:dwstv's gear list
Olympus XZ-1 Olympus E-M5 II Panasonic Lumix DMC-GM1 Olympus OM-D E-M5 Olympus PEN E-PM2
Jacques Cornell
Jacques Cornell Veteran Member • Posts: 6,342
Re: It goes both ways.
Yeah, for event work, I appreciate the ability to shoot at wide apertures and still have enough DoF to keep more than one person in focus.
jacquescornell.com
 Jacques Cornell's gear list:Jacques Cornell's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital 45mm F1.8 Panasonic 20mm F1.7 II Panasonic Lumix G X Vario 35-100mm F2.8 OIS +27 more
Superzoom2 OP Regular Member • Posts: 141
Wow, thank you for all the thoughtful and personal responses.  I suspect I will eventually buy some fast primes, but I am trying to convince myself that I will not end up spending too much on switching to a MFT system in the long run.  Cost is a concern.  Flexibility is a concern.  I mostly want the OM-D E-M10 as a smaller travel camera, rather than taking my T3i with 17-55 or 18-200.
Someone stated that to achieve an equivalent degree of background blur, MFT has to be opened up a stop compared to APS-C.  Is that true, or is it less than one stop?
Sergey_Green
Sergey_Green Veteran Member • Posts: 8,906
So provided you understand how this works ..
mpresley wrote:
Well no, I guess I don't since a shallow DOF and nice creamy backgrounds are pretty easily obtained with M43 gear, just not with the lens you mention... I used to shoot with the Nikon D700 using a 85/1.4, 135/2, and the 70-200/2.8 - it's simply a matter of understanding how it works, with the right lens.
Which equivalent to the listed above lenses would you have on mFT?
- sergey
 Sergey_Green's gear list:Sergey_Green's gear list
Samsung Galaxy Note 10.1
Sergey_Green
Very pretty image ..
DanCar wrote:
I get shallower depth of field than my friends who shoot with bigger cameras and big zoom lenses, although I'm just shooting with primes.
Well done.
- sergey
NCV
NCV Senior Member • Posts: 3,405
Thanks!
No
 NCV's gear list:NCV's gear list
Nikon D300 Olympus OM-D E-M5
Sergey_Green
And the amount of time spent ..
s_grins wrote:
I like deeper DOF
You can add some shallow DOF later, during PP. It is easy
Can you show us some examples, do they look realistic and good?
- sergey
