EM-1 uses Panasonic sensor per Chipworks
Started Feb 8, 2014 | Discussions
madzazulu Senior Member • Posts: 1,310
14
Zensu11
Zensu11 Senior Member • Posts: 1,485
Re: EM-1 uses Panasonic sensor per Chipworks
madzazulu wrote:
http://chipworks.force.com/catalog/ProductDetails?sku=OLY-E-M1_Pri-Camera
I've always thought the sensors in the OM-D series were all made by Sony. Guess I was wrong.
 Zensu11's gear list:Zensu11's gear list
Olympus PEN E-P5 Olympus E-M1 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus 12-40mm F2.8 Olympus 40-150mm F2.8 Pro +1 more
Martin.au
Martin.au Forum Pro • Posts: 10,273
Now that's quite a surprise. I wonder if we now know the chip that will be in the GH4?
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +6 more
s_grins
s_grins Forum Pro • Posts: 10,258
7
Wow!!!
For many forum activists this would be unbearable to admit this. Olympus has to be assembled with very best from Sony
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Sigma 30mm F2.8 EX DN +3 more
FrankParis Senior Member • Posts: 1,042
5
s_grins wrote:
Wow!!!
Um, big deal.
Um, doubtful. You must be a Panasonic fan boy or fan girl. I have an E-M1 and all I care about is performance.
 FrankParis's gear list:FrankParis's gear list
Olympus PEN E-PM1 Panasonic Leica D Summilux Asph 25mm F1.4 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +7 more
drj3 Veteran Member • Posts: 3,867
9
I am not sure why I should care about which company produced the sensor, the lenses and as well as many of the other components are often designed and produced by other companies . As long as I am satisfied with the performance of the product it really is not important.  Actually if it means that Olympus is not just tied to Sony for sensors, that would be a good thing, since Sony may not always produce the best sensor.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD +6 more
Gregm61 Forum Pro • Posts: 14,505
There you go. It's on the internet, so we all know it has to be true....
"There's shadows in life, baby.." Jack Horner- Boogie Nights
 Gregm61's gear list:Gregm61's gear list
Leica M9 Panasonic Lumix DMC-GX7 Olympus E-M1 Leica M (Typ 262) Olympus Zuiko Digital ED 50mm 1:2.0 Macro +21 more
pedroboe100
pedroboe100 Regular Member • Posts: 296
And you can buy a one page document for $5000?
 pedroboe100's gear list:pedroboe100's gear list
Fujifilm X10 Pentax MX-1 Olympus PEN E-P2 Pentax Q Pentax K-01 +11 more
Probably even includes a certificate of authenticity!
Fredrik Glckner Veteran Member • Posts: 3,336
I remember interviews with Panasonic engineers saying that they would not be using on sensor PDAF. But the EM-1 does. So this appears to not add up well.
http://m43photo.blogspot.com
exdeejjjaaaa
exdeejjjaaaa Veteran Member • Posts: 7,708
so it is this one... the same as in GH4 = http://www.semicon.panasonic.co.jp/ds8/c3/IS00006AE.pdf
MN34230PL
that is a big surprise in fact... so Sony after all was not able to edge Panasonic out
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Phase One Capture One Pro +23 more
The specifications say that it can do 1080p @ 60fps and 4k @ 30fps. So no chance of a high speed full HD video output from GH4.
Also, it says that the full scan can be done at 22.5 fps. This means that the electronic shutter readout speed is about twice that of the GH3. The GH3 has an electronic shutter readout speed of about 1/10s, leading to big rolling shutter effects:
http://m43photo.blogspot.com/2013/03/gh3-electronic-shutter.html
exdeejjjaaaa
see carefully - that sensor (it might be a mod of it specifically for GH4 though - that is why it is "MN34230PL" and not simply "MN34230") can do "4k2k movie mode (30fps)"
also that sensor is 1.9 crop
Actual imaging area dimensions 17.6472 (H) mm x 13.3228 (V) mm (active pixel area) = 4656 (H) x 3518 (V)
and as "Number of effective pixels" = 4644 (H) x 3506 (V), we have :
((17.6472 * 13.3228) / (4656*3518)) * (4644*3506) = 233.7 mm^2
E-M1 has 4608 x 3456, so it is unfortunately does not reach 1.9 though, but rather 1.944 crop (228.6 mm^2)
Dr_Jon Senior Member • Posts: 2,965
What you're buying is a bunch of X-Rays and Scanning Electron Microscope (SEM) photographs of the chip, including cross-sections of the devices, so competitors can see what Panasonic did to make it.
"The Device Essentials deliverable for imaging devices comprises a one page summary of observed device metrics and salient features. The summary is supported by the following unannotated image folders: • Downstream product teardown • Package X-rays, die photograph, non-invasive optical photos of die features • SEM imaging of the pixel array delayered to the metal, transistor, and diffusion levels • Exploratory cross-section SEM imaging of the general pixel array and peripheral structures This deliverable provides basic competitive benchmarking information and enables cost-effective tracking of multiple competitors’ technology."
E.g. see the second picture here:
http://www.macrumors.com/2012/03/16/new-ipad-using-same-camera-sensors-found-in-older-products/
...or this:
http://www.i-micronews.com/news/Sony-Backside-Illuminated-BSI-CMOS-Image-Sensor,3161.html
Here's another example of what they do:
http://chipworksrealchips.blogspot.co.uk/
BTW it's very interesting Panasonic did them a custom one with PDAF, I guess they much think very highly of their defocus technique to use it on the GH4 instead of PDAF. As I plan to get a GH4 then hopefully it's the business...
 Dr_Jon's gear list:Dr_Jon's gear list
Fujifilm FinePix Real 3D W3 Sony RX100 Panasonic Lumix DMC-GH4 Canon EOS 5DS R Canon EF 14mm f/2.8L II USM +23 more
exdeejjjaaaa
only Canon has PDAF that is really "in silicone", the rest are using just various tricks with CFA on top of the sensor
exdeejjjaaaa
the same sensor can be supplied with different CFAs on top of it to accomplish the PDAF... so you are talking about camera engineers, not sensor engineers... Olympus paid for a different CFA (with some locations dedicated to PDAF use) on top of sensors for E-M1 and got what they paid for...
cameron2 Senior Member • Posts: 2,276
Yup, that is an unexpected turn of events ..
 cameron2's gear list:cameron2's gear list
Sony RX100 Panasonic Lumix DMC-GX8
exdeejjjaaaa
OM-D series != (only) E-M1... E-M5 might as well have Sony sensor...
https://chipworks.secure.force.com/catalog/ProductDetails?sku=SON-IMX109
tt321 Senior Member • Posts: 7,207
7
FrankParis wrote:
s_grins wrote:
Wow!!!
Um, big deal.
This surely is a joke? Otherwise your fanboy detector is set to too high a sensitivity.
The way the Sony sensor was embraced probably led to s_grins' remark.
However, the enthusiasm then was fully justified given that Olympus was perceived as being given second-rate old sensors by Panasonic up to that time, and the entrance of Sony represented good competition.
So logically those who enthusiastically greeted Sony should also enthusiastically greet this turn of events as this shows now valid competition with almost equal merits. The best possible situation. Sony has kicked Panasonic out of complacency, and Olympus gets to pick what they want on their own terms.
micksh6
micksh6 Senior Member • Posts: 2,612
Panasonic could be just subcontractor
All die markings say is that the sensor was manufactured at Panasonic fab. It might as well be designed by Sony and then they could outsource production to Panasonic.
Just like Panasonic produces flashes designed by Olympus or Foxconn produces iPhones designed by Apple.
If Panasonic had access to this sensor they would certainly have used PDAF for video in GH4, like Canon does in 70D. Instead, Panasonic had to develop their Depth-From-Defocus technology.
So, if this is Panasonic sensor why don't they use PDAF in GH4?
 micksh6's gear list:micksh6's gear list
Olympus PEN E-PL5 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +6 more
