Noise and ETTR
Started Feb 6, 2014 | Questions
Ido S
Ido S Senior Member • Posts: 2,763
Re: Noise and ETTR
One thing I forgot to mention in my previous post: what version of Lightroom are you using?
To get the best Raw conversion, use at least Lightroom 4. And in the Develop module, under Camera Calibration, make sure that the process version is 2012.
 Ido S's gear list:Ido S's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus M.Zuiko Digital 25mm F1.8
Anders W Forum Pro • Posts: 21,465
Re: Noise and ETTR
cmpatti wrote:
Anders W wrote:
In addition to the link to the article you already got from GeorgianBay1939, you might want to have a look at this recipe for exposure with the E-M5 specifically:
http://www.dpreview.com/forums/post/51169217
I have a question about the procedure outlined in this post. It calls for setting the largest aperture and the slowest shutter speed that will get the image and then pushing the histogram to the right by raising ISO. It's been my impression that achieving ETTR by increasing ISO doesn't accomplish any meaningful noise reduction because the ISO increase offsets the benefits of ETTR. Therefore, I've thought that ETTR is only really useful in low contrast, well-lighted situations where you can increase exposure at base ISO by reducing shutter speed without blowing out highlights. Since those situations aren't all that common, and since noise isn't usually a major concern in those situations, I haven't really taken the trouble to incorporate ETTR in my metering routine. Instead, my practice has been "shoot at the lowest ISO at which you can get the shutter speed you need" (since I'm generally shooting aperture priority).
So my question: is there any testing available that shows that raising ISO to achieve ETTR reduces noise? In other words, that ISO 200, f/4, 1/100 (with highlights a stop from the right) will produce more noise than ISO 400, f/4, 1/100? This would be useful to know.
Yes, testing that demonstrates this has been done by me as well as others. The reason that ISO 400 is better than ISO 200, if we keep exposure the same and provided that we don't clip the highlights, is that the read noise of the sensor (as measured in electrons) is lower at ISO 400 than at ISO 200. This will make for less noise in the shadows. In the highlights, the noise level will be roughly the same regardless of which of the two ISOs you use (though still marginally better at 400).
How the read noise varies across ISOs can indirectly be assessed by looking at the DR curve in the DxOMark sensor tests. If the read noise (as measured in electrons) remains constant when you double the ISO, the expected loss in DR is one EV. If it is less than that, the read noise falls a bit.
As to the details for the E-M5 specifically, including intermediate ISOs, see here:
http://www.dpreview.com/forums/post/41988325
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +28 more
cmpatti Regular Member • Posts: 254
Re: Noise and ETTR
Interesting thread. Thanks for pointing it out. In trying to find a practical bottom line, I focused on the following statement from one of your comments down-thread:
As far as the E-M5 is concerned, the results indicate that going from ISO 200 to 400 improves read-noise performance considerably but that ISO 250 and 320 as well as any ISO above 400 improves it only marginally, and that there is no further improvement at all beyond ISO 3200.
So I might amend my technique ("shoot at the lowest ISO that you can get the shutter speed you need") as follows: If you're at ISO 200 and can go to ISO 400 at the same aperture and shutter speed settings without blowing the highlights, do it. Otherwise don't sweat it.  Sound reasonable?
 cmpatti's gear list:cmpatti's gear list
Sony Cyber-shot DSC-RX100 III Olympus OM-D E-M5 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus 12-40mm F2.8
LincolnB Veteran Member • Posts: 4,107
Re: Noise and ETTR
smithling wrote:
Anders W wrote:
smithling wrote:
Don't bother with ETTR unless you have an extremely tricky scene to contend with.
Other people have provided you good responses about what ETTR is, and what the benefits are. But ETTR was established when the dynamic range of digital camera sensors were terrible. It's still a valid technique, but today, the noise amount between pushing shadows in post, and ETTR and then pulling them down, is negligible. The sensors today are really good. Professionals don't bother, and most photographers (artists) I know don't bother either because the difference is simply not noticeable in prints.
IMHO, in general, it is a waste of time. Try it out, and then ask yourself honestly if the trouble is worth the time and mental effort.
Once you have figured out how to do it, it doesn't take any extra time or mental effort at all. And I would think there are many experienced and technically skilled photographers here
Where? At the dpreview.com forums? No problem. There's a vast, vast photographic world outside of this forum.
that would disagree with your assessment (as I certainly do) of whether it is worth learning how to do it.
Never did I say that it was a waste of time to learn ETTR. Please note that I said, "try it out." Sorry for the miscommunication.
Sensors have become better than they were, yes, but if you learn how to use them right, the results will be better still. Why wouldn't you want to take advantage of that fact?
With respect Anders, "use them right" and "better results" are merely subjective. Here's an opinion from another real professional that disagrees with you.
http://theonlinephotographer.typepad.com/the_online_photographer/2011/10/expose-to-the-right-is-a-bunch-of-bull.html
Based on my prints and output, ETTR is simply way overrated.
That photographer is using ETTR, regardless of whether he likes to admit it or not. The procedure for ETTR is to expose as far the right as possible without blowing the highlights. What he's discovered is that for night shots it's not possible to push the exposure very far to the right, that's all. It's still pushed as far to the right as possible, which is not very far when you're photographing light sources.
ETTR + HDR:
 LincolnB's gear list:LincolnB's gear list
Olympus PEN E-P1 Panasonic Lumix DMC-G3 Fujifilm X-E1 Sony Alpha 7 II Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +8 more
Re: Noise and ETTR
No doubt. So what?
What I meant by learning is learning it sufficiently well that it doesn't take any extra time to do it.
No they are not. The SNR will be measurably better if you ETTR than if you don't in the scenario you describe in the post to which I replied.
When I evaluate people's claims, I try to do it, as far as possible, based on how they can back it up rather on who they are. Ctein makes three elementary mistakes here.
First, he argues that the ETTR criterion is generally difficult to apply. How difficult it is depends on what tools you have available. With the "live-view blinkies" (highlight/shadow warnings) available on the particular camera we are talking about in this thread (and other Oly MFT bodies), it's usually very easy to get it right.
Second, to illustrate his claim that ETTR is a bad criterion, he uses a sample image that is exposed beyond the right rather than some distance away from the right (as he argues is the right choice).
Third, what he illustrates is that shadow pushing can be useful (who has claimed that it isn't) rather than that ETTR is a poor criterion.
In short, all this article demonstrates is that Ctein doesn't know how to ETTR correctly, and therefore finds it dangerous. It's not the first time I see him show that he doesn't know what he is talking about.
Re: Noise and ETTR
Yes, pretty much. As I said, there is some additional gains to be made in terms of read-noise by going beyond 400. But the difference between 200 and 400 is the only major one.
jkrumm Veteran Member • Posts: 8,959
Re: Noise and ETTR
I'm not so great at getting to natural looking results with normal HDR, but what I was getting at was that Photoshop seems to start from a natural look and I have to push the image all over the place to give it more of an hdr look (increasing shadows way, way up, for instance, then cranking on clarity).
Of course enfuse/enblend is a couple dollars and works very well for both aligning and blending. I think one of the main advantages of Photoshop is better "ghost" control. But I've also had sunsets with photoshop that just did not turn out right in the highlights. Hard to find perfect for all situations.
John Krumm
Juneau, AK
Re: Noise and ETTR
That's good to hear. I don't use Photoshop much myself (except occasionally with a very old version, 2.0, of Photoshop Elements), but I have understood that this is an area where the program is quite capable these days.
The only control you have over ghosting with LR/Enfuse is that you can turn the "hard-mask" option on to have the program use only a distinct input image for a certain part of the scene.
Bob Tullis
Bob Tullis Forum Pro • Posts: 31,105
Re: Noise and ETTR
I was thinking the same thing. For a challenging DR exposing a bright as possible w/o blowing highlights ETTR is the way it's done with a single exposure, wittingly or not. Though, for a mid to bright thick fog with low contrast it wouldn't hurt to over expose (w/o clipping) for optimal S/N, but it wouldn't be necessary to ETTER (expose to the extreme right).
It's best to 'debate' such practices with photographic examples, to insure all parties are referencing the same type of scenes with contrary positions. Otherwise. . .
ETTR + HDR:
...Bob, NYC
http://www.bobtullis.com
http://www.flickr.com/photos/bobtullis/
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Sony Alpha 7S Sony Alpha 7R II Voigtlander 28mm F2 Ultron Sony RX1R II Sony Alpha 7 II +16 more
smithling Regular Member • Posts: 382
Re: Noise and ETTR
Yup. There are certainly scenes where ETTR can yield better SNR. However, because of the ETTR drum banging, we have (as I have seen) folks with a modern camera running around in the day time making a fuss about ETTR. Silly!
Re: Noise and ETTR
No doubt. So what?
You stated that you and others here in this forum disagree. So what? Outside of the realm of dpreview.com forums there are photographers who get by handsomely without ETTR.
How long does it take to learn it sufficiently well that it doesn't take any extra time? What does the ETTR workflow look like when one becomes adept at using it sufficiently well?
Measurably better? Maybe. Noticeably better? Sometimes. It depends on the scenario. Do you have an example where the image was noticeable improved by ETTR? The other images you provided somewhere else in this thread are HDR.
Agreed on all points. A bad counter-opinion to reference.
Bob Tullis
Re: Noise and ETTR
I don't disagree much with that.    But in another sense even at ISO 200 on a bright day one can get blue sky noise.  I haven't done determined tests, but if I can up the exposure 1 stop more w/o blowing highlights in the daytime, I'll do that when in a RAW only mode.   Even if only for a little theoretical comfort [g].  It can't hurt.
The practice is sound, but really understanding it is key (like anything).   And if one understands it becomes apparent when (& why) one can relax and throw ETTR to the wind.   I like to think of it as shooting for the visual result with JPG, shooting for the sensor's S/N for RAW if/when it matters, in short.
...Bob, NYC
Re: Noise and ETTR
No doubt. So what?
I don't doubt that there are photographers who get by "handsomely" without ETTR. The point is that they would get along even better with ETTR.
With an Oly body, it should take very little time to learn to do it for ordinary scenarios.
Assuming we know that the light level is sufficiently high to get the shot as we want it at base ISO, just set the f-stop you deem preferable and adjust the shutter speed until the live-view blinkies just appear on the brightest highlights you care to preserve.
If base ISO turns out to be insufficient to reach that point given the light level, f-stop requirements and shutter-speed requirements, instead increase the ISO until the live view blinkies just appear.
On the E-M5 it makes sense to increase the ISO only up to 3200 at most. Beyond that point, it doesn't make sense to do it any more since the ISOs beyond 3200 are digitally scaled and thus not associated with any reduction in read noise.
Sure. Here is one which would have been noticeably worse in either the highlights or the shadows if I hadn't ETTRed.
Before PP
After PP
OK. Good that you too think it's bad.
Stevil Senior Member • Posts: 1,462
Ctein's no dummy
I'm not sure Ctein really disagrees. His article is filled with enough qualifiers to make it clear that he's deliberately overstating his case. In effect, he's saying "if you don't understand ETTR well enough to pick this article apart, you will probably do more harm than good by using it." Why would he do this? Well, for one, a good polemic boosts the Ctein "brand" better than a boring technical article. : )
I could summarize Ctein's article this way:
"1. Clipping highlights is BAAAAD.
2. If you use ETTR, you're gonna clip highlights.
3. ETTR is BAAAAD.
4. If you own a high-end camera made in the last year or two, you may not benefit greatly from ETTR much of the time anyway. (Whoops, did I imply there could be a benefit?)"
 Stevil's gear list:Stevil's gear list
Olympus PEN E-PL2 Canon EOS 6D Canon EF 85mm f/1.8 USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +2 more
Re: Noise and ETTR
Well, in fairness to Ctein, who was writing in 2011, his point--particularly clear if you read his response to comments--was that as a recommended standard practice ETTR was a bad idea because (1) most people wouldn't be able to do it correctly and would end up blowing highlights, and (2) blown highlights are a bigger, less remediable problem than shadow noise. He states, for example:
No one, including me, ever said the THEORY of ETTR was wrong. The practice, with current equipment, is what fails (see comment above to Pieter et.al.). A useful rule of thumb is about practice, not theory.
He specifically allowed for the possibility that improvements in equipment might change that situation:
Well, no, the in-camera and in-computer tools for avoiding blown highlights actually are inadequate to the problem. Currently. Quite possibly, even probably, in another eight years my advice will be as bad as ETTR (which dates from 2003) is now. But right now, highlight problems are hard to avoid if you follow ETTR.
Re: Noise and ETTR
Well, first good tools for successfully ETTRing and doing it quickly was available already when Ctein wrote this (live-view histogram, live highlight warnings). Second, it was certainly possible to do it right even without these tools, just a bit more time-consuming.
I bought my first digital camera (Pentax K100D) in 2007 and started ETTRing right away. The technique I used back then (and still use as a back-up strategy now) was to spot meter on the highlights and then dial in a certain amount of positive exposure compensation based on that reading. How much depends on how the meter is calibrated relative to the clipping point of the sensor. I don't remember exactly what figure I used to apply with the Pentax, but it was somewhere between 2 and 3. On the E-M5, it is 3.3 EV (at the normal ISOs, not ISO LOW). This works well if the highlights are large enough to be properly isolated by the spot of the spot meter. If they are scattered and can't be properly isolated by the meter, you have to reduce the EC you dial in, and a certain amount of trial and error may be required to get it right. In the end, you have the ex-post histogram and ex-post highlight warnings to check whether you nailed it or not.
There have certainly been such improvements over time, but the better tools we now have access to were available already when Ctein wrote his article. And it was certainly possible to successfully ETTR without those tools too. It was just a little more time-consuming.
