Battery issue...
Started Feb 5, 2014 | Discussions
coupeman
coupeman New Member • Posts: 9
Battery issue...
Hi guys and gals,
Slight dilemma, Googled and nada so here I am. Have a D4 and MH-26, bought a BT-A10 direct from Japan as a recent D700 purchase came with a genuine EN-EL4a but no charger for it. Pop EN-EL4a into BT-A10 adapter and into MH-26 and something odd happens, Calibration and Chamber light flash continuously.
As I said, I have Googled this combo but to no avail, just wondered if anyone here could shed any light. Have left in situ for an hour or so and the EN-EL4a seems no more charged than when I first inserted it.
Many thanks in advance,
Adam
 coupeman's gear list:coupeman's gear list
Nikon D700 Nikon D4 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Nikkor 50mm f/1.4D +3 more
Nikon D4 Nikon D700
mais51
mais51 Senior Member • Posts: 1,653
Re: Battery issue...
coupeman wrote:
Hi guys and gals,
Adam
Apparently you need a MH-22 or a MH-26a with BT-A10
Don't really know the real differences between a MH-26 and MH-26a
http://www.robgalbraith.com/content_pageb21c.html?cid=7-11673-12259
"Nikon chose to prevent the D4's EN-EL18 and Battery Charger MH-26 from being interoperable with the D3S' EN-EL4a and Quick Charger MH-22. By placing the new battery's and new charger's connector in a different spot, any measure of backwards or forwards compatibility was eliminated."
There are two charging bays on the MH-26 and if you haven't done so as a suggestion try swapping the BT-A10 to the other bay, the reason is that the MH-26 charge each battery alternatively, not simultaneously. Sorry I could not offer anymore help !
May be your EN-EL4a is faulty - if you could lay your hand on one try charging on a MH-21/22
 mais51's gear list:mais51's gear list
Canon PowerShot S120 Nikon D300S Nikon D800 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF +8 more
mais51
mais51 wrote:
coupeman wrote:
Hi guys and gals,
Adam
Check out this link
http://www.dpreview.com/forums/thread/3526287
as a side note a EN-EL4a rating is 11.1 volt @2500 mAh whereas the new EN-EL18 is only 10.8 volt @2000 mAh possibility is that MH-26a can deliver more voltage and current than a MH-26 to charge a EN-EL4a
coupeman
coupeman OP New Member • Posts: 9
Well tried both bays, same results, so either the EN-EL4a is faulty or Nikon are a shower of thieving ****s. Guess I'll just use the D700 with the EN-EL3 instead, its only a backup camera anyway, a shame really.
I do think it must be to do with voltage, and yeah, what is the difference between the MH-26 and the 'a' version??
Weird, oh well thanks guys.
M Lammerse
M Lammerse Forum Pro • Posts: 11,247
This has partly to do with new laws in Japan regarding battery safety and output.
Michel
- Objectivity is of the very essence of photography, its contribution and at the same time its limitation -
http://www.fotopropaganda.com
http://www.fotopropaganda.com/blog
http://www.flickr.com/photos/9240992@N05
mais51
coupeman wrote:
Hi guys and gals,
Adam
I have made some inquiry with B&H and here is their answer:
Your question has been answered:
Q:
"Is there any differences between a MH-26 and MH-26a"
A:
Dan W from B&H Photo Video said:
"The MH-26 can only charge the EN-EL18 Batteries For Nikon D4. The MH-26a (which we do not sell) can be used to charge the EN-EL18 rechargeable Li-ion battery that powers the D4 D-SLR as well as the EN-EL4/EN-EL4a rechargeable Li-ion batteries that power the D3 series cameras."
Did you find this answer helpful? yes | no
Thank you Dan at B&H for his prompt response
