CP+ Rumor Roundup.....
Started Feb 4, 2014 | Questions
sgtsween
sgtsween Regular Member • Posts: 438
So, what does everybody think about the possibility of new product announcements at CP+? So far the only plausible rumor I've seen is the TC. What about the rumored K-60, or the alleged retro K-L? Any new scoop since that great thread on the same topic a week or so ago?
Any new predictions or rumors? A full frame Q? A special edition K-3 in full adamantium? K-02 designed by Jean Paul Gaultier?
 sgtsween's gear list:sgtsween's gear list
Fujifilm FinePix X100 Ricoh GR Pentax K-5 Pentax Q Pentax K-01 +13 more
Pentax K-3
awaldram
awaldram Forum Pro • Posts: 12,316
Re: CP+ Rumor Roundup.....
Given Ricoh has just released 1.02 k3 FW that does not have 'adapter' enabling it has to cast doubt on the authenticity of an imminent TC release
 awaldram's gear list:awaldram's gear list
Pentax K-x Pentax Q Pentax Q7 Pentax K-3 Pentax smc DA* 55mm F1.4 SDM +15 more
Alex Sarbu Veteran Member • Posts: 5,492
You picked a bad time to make such affirmations
Alex
 Alex Sarbu's gear list:Alex Sarbu's gear list
Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 70mm F2.4 AL Limited Pentax smc DA 35mm F2.8 Macro Limited HD Pentax DA AF 1.4X AW Rear Converter +2 more
awaldram
Not as bad if it was actually release as a real product
Would seem a bit expensive and futile to release 1.02 FW to only supersede it with an adapter enabling 1.12 a few days later.
Alex
sgtsween
sgtsween OP Regular Member • Posts: 438
I'm hoping a new body is announced. I have no interest in a TC at the moment as I don't have any fast telephoto lenses to make it worthwhile, and I haven't been birding in almost a year.
Good observation on the FW lacking that addition. Does not bode well for those expecting a TC to be announced.
MightyMike Forum Pro • Posts: 34,528
I know what you're thinking but a TC may not need a firmware update and/or the update could have already been there in the original firmware but just dormant until that particular TC is in use.
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
awaldram
Fingers crossed
Mike from Canada
scanar
scanar Regular Member • Posts: 122
This site is usually pretty close to the money, I don;t think they got into all the hysterical chatter about the K3 having raw video, an additional motor (where the earplug was) etc. They are just predicting a new Pentax K-60 camera and two lenses (135-380mm f/4-5.6 and 18-70mm f/2.8-4.5). More mainstream and more likely, although they do have info about the TC, it is not on their list for CP+.
Digicam Info
 scanar's gear list:scanar's gear list
Sony Cyber-shot DSC-HX7V Nikon D7100 Sony a6000 Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Nikon AF Nikkor 28mm f/2.8D +5 more
miles green
miles green Veteran Member • Posts: 5,187
135-380mm f/4-5.6 sounds good, usual unusual focal lengths for Pentax...
Make it a DA* please, and i might have to yield to my long-lens-lust.
Miles Green
Pentaxian with chronic LBA
Corfu, Greece
 miles green's gear list:miles green's gear list
Pentax K-5 Pentax K-1 Sigma 70-200mm F2.8 EX DG Macro HSM II Pentax smc DA 21mm F3.2 AL Limited Pentax smc FA 31mm F1.8 AL Limited +10 more
sgtsween
Digicam Info
Thank you for the link. There's also an interesting article on there showing the new Pentax WG's now branded and called the Ricoh WG.
Rumored specs on the alleged K-60 seem pretty interesting. I wonder if it would cannibalize K-3 sales, though. Especially if it's 24 mp AA-less. If the specs were correct, I'd be more apt to get a K-60 over the K-3 as ostebsibly you'd get similar IQ. I don't care about video, or selectable AA which I'd never use. Or dual SD card slots. AND it claims wifi, so the whole flucard thing would be moot. Doesn't seem like a smart move by Pentax in my opinion. If it is a myth, I'll upgrade to the K-3 from my K-5.
scanar
Sorry, my link was not clear 'helped' by google translate no doubt. This is the article I was specifically meaning: translated page
Russell Evans Forum Pro • Posts: 11,634
If that's true, then there is probably no hope for a third party TC ever working with SDM lenses.
Thank you
Russell
Thank you
Russell
There may have never been any hope to begin with... However i do believe there are some people who use some PZ capable TC's with some SDM/HSM lenses quite successfully. that shows to me that some combinations or some converters just don't work right and not a generic broad across the board problem with PZ capable TC's.
Mike from Canada
paulkienitz
paulkienitz Veteran Member • Posts: 5,204
Alex
A fully chipped TC should not need any firmware change in the camera. The absence of a change in the camera would help encorage people to replace their old converters with the new one.
"A good photograph is knowing where to stand." -- Ansel
 paulkienitz's gear list:paulkienitz's gear list
Pentax Q Pentax K-3 Pentax smc DA 55-300mm F4.0-5.8 ED Pentax smc DA* 300mm F4.0 ED (IF) SDM Samyang 8mm F3.5 Aspherical IF MC Fisheye +4 more
paulkienitz
Thank you
Russell
Mike from Canada
None of them work right. Sometimes the camera manages to muddle through.
DAVID MANZE Veteran Member • Posts: 3,520
Hi,
Well my Pentax man says the teleconverter is on the way for march, but who knows? the "french leak" (K600,K60, KL Retro) seemed believable to me but it could be a nonsense. If Ricoh want to keep the momentum going their going to have to make several announcements, the flucard is of course necessary, otherwise things will start to look a bit bleak again.
All the other manufacturers are bringing all sorts of cams, I've never known it so hot, the choice has never been greater!
Dave's clichés
 DAVID MANZE's gear list:DAVID MANZE's gear list
Pentax K-01 Nikon D7100 Pentax K-3 Nikon D750 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +21 more
My Sigma 50mm F1.4 works with my Tamron 1.4x PZ... my only other HSM/SDM lens is the Sigma 8-16 and i really couldn't be bothered testing it on that.
Mike from Canada
miles green
DAVID MANZE wrote:
Hi,
Hopefully!
There was no leak, the guy was just guessing what Pentax would come up with next - you know, one of those posts people write when they have trouble falling aslep. The french text was full of hypotheticals and conditionals, and certainly didn't intend to be read as a leaked info. I'm not sure how it translated, as i speak french fluently.
ff? pffff. flucard...
or the other way round!
Dave's clichés
Miles Green
Corfu, Greece
James O'Neill Veteran Member • Posts: 4,106
And if it did need a firmware rev it would need to be released for many cameras. A step in the K3 firmware doesn't mean anything either way
My guesses
TC
645D MK II
Full frame, under glass with no ship date.
