What it call in English?
Started Feb 2, 2014 | Discussions
Thanatham Piriyakarnjanakul
Thanatham Piriyakarnjanakul Contributing Member • Posts: 620
I'm looking to buy it, online.
Thank you.
I'm photographer from Thailand and English not my primary, sorry.
 Thanatham Piriyakarnjanakul's gear list:Thanatham Piriyakarnjanakul's gear list
Nikon 1 V1 Nikon 1 Nikkor VR 10-30mm f/3.5-5.6 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor 18.5mm f/1.8 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF
bankybrook
bankybrook Junior Member • Posts: 37
Re: What it call in English?
It's called Nikon strap ring, and the black part is called Nikon strap ring protector.
Look at the BocaPhoto.com site for Nikon Accessories.
 bankybrook's gear list:bankybrook's gear list
Leica V-Lux (Typ 114) Nikon D3 Nikon D300 Nikon D4 Nikon AF-Nikkor 80-200mm f/2.8D ED +14 more
sunhorse Senior Member • Posts: 1,519
Thank you.
นี่เรียกว่า strap lugs ครับ
Ramesh
 sunhorse's gear list:sunhorse's gear list
Fujifilm X-E1 Fujifilm X-Pro2 Sigma 35mm F1.4 DG HSM Art Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 35mm F2 R WR +1 more
masiguy
masiguy Contributing Member • Posts: 527
The site looks really good, but his reseller ratings are in the dirt: Precision/Boca Photo
'You could look it up.' -Casey Stengel after James Thurber
hikerdoc
hikerdoc Senior Member • Posts: 1,053
It is called neck strap ring and neck strap ring cover on the NikonUSA website in the store section. Each piece is 2.80 USD.
 hikerdoc's gear list:hikerdoc's gear list
Nikon D4 Nikon D810 Carl Zeiss Distagon T* 2,8/21 Carl Zeiss Apo Sonnar T* 2/135 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +11 more
BackPacker1532 Regular Member • Posts: 114
It's called a "strap ring protector" and you can get it from
http://www.bocaphoto.com/products/new/nikon/nikonacc.htm
 BackPacker1532's gear list:BackPacker1532's gear list
Leica S2 Nikon D3
hikerdoc
you can get the same parts directly from Nikon for much less, something to think about if the above site is considered a scam by most reviewers:
http://parts.nikonusa.com/en/Nikon-Products/Product/DSLR-Parts/1K100-035/Single-Neck-Strap-Ring.html
http://parts.nikonusa.com/en/Nikon-Products/Product/DSLR-Parts/1K080-005/Single-Neck-Strap-Ring-Cover.html
toomanycanons Forum Pro • Posts: 10,755
Thank you.
Either neck strap thingies or neck strap doohickies.  Your choice.
Thomas Toolan Regular Member • Posts: 208
Thank you.
Those are the scientific names I'm sure.
Tom
 Thomas Toolan's gear list:Thomas Toolan's gear list
Nikon D800E Nikon D3 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF Nikkor 35mm f/2D +11 more
wasserball Veteran Member • Posts: 3,420
Thank you.
Tom
No, it's whatcha call it.
 wasserball's gear list:wasserball's gear list
Kenko Teleplus Pro 300 AF 1.4x Nikon D3S Nikon D600 Rokinon 14mm f/2.8 IF ED MC Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +4 more
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 12,565
I've bought from Boca photo several times with no problems.
What is shown in the OP's first photo is actually two parts - the metal 'strap ring' or 'lug', which has a plastic clip-on protective cover.   Not sure what the plastic part is called.
Craig
www.cjcphoto.net
Nikon 1 V1 Nikon D200 Nikon D300 Nikon D700 Nikon D800E +35 more
brianric Veteran Member • Posts: 6,117
Thank you.
Something I remove and discard when buying a new camera.
 brianric's gear list:brianric's gear list
Sony RX100 Nikon D700 Panasonic Lumix DMC-G1 Nikon Df Nikon D810 +36 more
hikerdoc
Craig
www.cjcphoto.net
I understand it is two parts. The plastic part is called the neck strap ring cover by Nikon (see the link I provided which directs to the page for each part). What I was trying to point out is that each piece is $4.19 through Boca ($8.38) per set of two pieces for each side, whereas the same parts are $2.80 each through Nikon or $5.60 per set of two pieces for each side.
People have expressed reservations about dealing with Boca. If those concerns are legitimate one could order directly from Nikon and save one third of the cost in the process. If one wishes to take that chance for the privilege of paying more through the third party site that is their option.
PHXAZCRAIG
Any idea what part numbers involved?
I ask because I bought a Nikon V1 which was missing one of the strap rings when it came.  I didn't feel like sending it back, so I've been trying to find a replacement part.   Someone kindly sent me a pair of theirs, but they must have been from a different camera than a V1, because while they were very small, they were still a bit too thick to fit into the lugs on the camera.
So ... must be several versions of these things out there, in at least 3 sizes.
Craig
www.cjcphoto.net
