D800 or d800e??
Started Feb 2, 2014 | Discussions
Copter01 New Member • Posts: 4
D800 or d800e??
Hi
I am a Amateur, mainly landscape photographer. I don't upgrade often, but when i do i buy decent gear that will last me.
i am about to upgrade from a D200 to a D800 but not sure whether to get the e. usually reviews are sufficient, but it is difficult to quantify the difference between the two. I have a few questions?
- Reviews say that Moire, at least problematic moire is rare on the e. Is that peoples experience here?
- i have decent lenses, and wish to be able to print, periodically, pretty big. At what size, and at what apertures do people find the difference between the two can be identified.
- is there much of a difference in quantity of sharpening needed for the 800 vs e?
thanks in advance for responses.
Nikon D200 Nikon D800 Nikon D800E
iJoost
iJoost Regular Member • Posts: 105
Re: D800 or d800e??
Differences (both moire and extra detail) are minimal and only present from apertures F/5.6 down.
JF69 Contributing Member • Posts: 751
if you have to ask,
just get the D800, you'll be happy. The differences are not that great between the two.
 JF69's gear list:JF69's gear list
Fujifilm FinePix S5 Pro Nikon D610 Nikon AF Nikkor 85mm f/1.4D Carl Zeiss Distagon T* 2,8/21 Carl Zeiss Distagon T* 2,8/25 +8 more
Photec Regular Member • Posts: 153
Re: D800 or d800e??
I have to agree, I also feel that in your case (as in mine) the D800 would be the better choice. Depending on your particular workflow and PP hardware the camera will produce images that can be printed any size you want with no problems.
You stated that you want to print large prints, the 36MP files will certainly enable you to do that. You will not see any real differences to speak of between the D800 and D800e at print sizes to 40X60. At normal viewing distances prints from either camera will look phenominal. Good luck with it.
Robin Casady Forum Pro • Posts: 12,898
Re: D800 or d800e??
Copter01 wrote:
Hi
With landscape shooting, extremely rare. With cityscapes a little more common. However, the moiré difference between the D800E and the D800 is small. If you get moiré with a D800E you are likely to get it with the D800, just a little less pronounced. If you don't get it on the D800 it will be subtle on the D800E.
I haven't printed enough D800 images to quantify that. Looking at images at 100% on screen, the differences are noticeable, but subtle, at f/8 and wider.
A D800/E image produces a print that is approximately 20x30" at 240 ppi. which is an optimum resolution for Epson printers. I have an Epson 7800 that uses 24" wide rolls of paper or canvas.
Yes.
I went with a D800E. I didn't see the point of buying a high-resolution camera that has its image accutance degraded. If I were shooting weddings, I might have gone for the D800, but I shoot mostly landscapes and macros. With the D800E I know I am getting the sharpest image possible.
Robin Casady
http://www.robincasady.com/Photo/index.html
"Get your facts first, then you can distort them as you please."
—Mark Twain
soloryb Senior Member • Posts: 2,126
Re: D800 or d800e??
I've had the D800E for almost 2-years, having graduated from a D200 and then a D700. I shoot a lot of landscapes and make 17" by up to 27" cropped/enlarged prints, sometimes to a high degree. With all those megapixels at your disposal, the D800/E just begs you to do this and I find it hard to resist.
As far as I've read - and there's lots of comparisons out there - the differences between the D800 and the D800E are not terribly significant. The only reason I went for the 'E' is because I do so much enlarging and felt it worth the extra $300.  However, since I don't have the D800 to compare output, I can't say for sure how much of a resolution boost there really is. I can tell you that I have yet to see even a hint of moire and my prints come out raiser-sharp.
Most people don't have both cameras (like me) and cannot give you a definitive answer. I would suggest that you search on-line for actual comparison photos between the two and listen to opinions of photographers who do have both cameras before you make up your mind.
The good part is that no matter which one you choose you'll end up with one fantastic camera.
soloryb
Copter01 wrote:
Hi
 soloryb's gear list:soloryb's gear list
Fujifilm FinePix X100 Nikon D800E Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Fisheye-Nikkor 16mm f/2.8D +9 more
nikonuserinfo Regular Member • Posts: 278
Used D800 and D800e for months side by side...
Copter01 wrote:
Hi
Go for "e"
I was using both D800 and D800e for months side by side. You can read my findings here and here.
I was afraid of that, but it's not a problem at all. Only for fashion photographers I would advice the normal D800.
I tested especially in studio for moire while shooting clothing. Capture NX2 RAW processing also helps to get rid of occasional moire.
Wide open while shooting quality glass D800e images are significantly sharper.
D800e used with high quality lenses often doesn't need sharpening at all.
It was a pleasure.
Stany
http://www.nikonuser.info
My former Dpreview profiles ( For which I do not have the Original email address anymore)
Stany Buyle
Photoforfun
 nikonuserinfo's gear list:nikonuserinfo's gear list
Nikon D1 Nikon D1H Nikon D2H Nikon D200 Nikon D810 +1 more
Araucaria Forum Member • Posts: 85
Re: D800 or d800e??
Go for the E, the non E was just made to avoid retarded forum posts. I have the non E because I couldnt find a decent prized E. You wont need sharpening with the E.
Leonard Shepherd
Leonard Shepherd Forum Pro • Posts: 10,518
Re: D800 or d800e??
Most manufactures new bodies, including several Nikon 24 MP, do not have an AA filter.
The original purpose of an AA filter was to reduce (as distinct from eliminate) the greater risk of moire the low MP bodies. The more MP the less the chance of moire being an issue.
The D800e was the first DSLR with "no AA filter" though purists know in the D800e there is an AA filter and a second filter to remove the AA filter effect.
It is a safe bet when the D800 eventually gets updated there will be only one option with no AA filter.
Leonard Shepherd
Great images are often of good subjects.
If they are great images does what lens, body or technique was used matter more than the skill of the photographer?
Nikon Coolpix P7700 Nikon D800 Nikon D7100 Nikon D810 Nikon D750 +24 more
Reilly Diefenbach
Reilly Diefenbach Veteran Member • Posts: 9,864
Re: D800 or d800e??
Copter01 wrote:
Hi
I recommend the "e" for landscape for sure.
Re: D800 or d800e??
Robin,
You said 240 ppi is an optimum resolution for the Epson 7800. I've always read that all Epsons print at an optimum resolution of 360 ppi or 720 ppi. I assume you mean the ppi value you send to the printer.
soloryb
Robin Casady wrote:
Copter01 wrote:
Hi
Yes.
Robin Casady
—Mark Twain
carlk Forum Pro • Posts: 15,940
Re: D800 or d800e??
I agree with what most people here say.  the E is the standard model.  None E is a delete option for people who have some special reasons or just want to save a few hundred dollars.
 carlk's gear list:carlk's gear list
Canon EOS 50D Canon EOS 7D Nikon D800E Fujifilm X-E1 Canon EF 85mm f/1.2L II USM +6 more
Copter01 OP New Member • Posts: 4
Re: Used D800 and D800e for months side by side...
nikonuserinfo wrote:
Copter01 wrote:
Hi
Go for "e"
Itested especially in studio for moire while shooting clothing. Capture NX2 RAW processing also helps to get rid of occasional moire.
It was a pleasure.
Stany
Stany Buyle
Photoforfun
Thanks all for the responses. This is definitely pushing me in the direction of the 'e' which is the direction i was inclining to already. either way i am looking forward to the improvement over the D200
Simon Garrett Veteran Member • Posts: 4,915
Re: D800 or d800e??
See http://www.dpreview.com/reviews/nikon-d800-d800e and especially the pages that compare the two. Some quotes:
"At F2.8, the slight blurring from lens aberrations is sufficient to narrow the gap between the D800 and D800E to the point you'd probably not be able to see any real difference in normal shooting. It's only at the lens's very sharpest apertures, i.e. F4 - F5.6, that the difference between the D800 and D800E is really pronounced. The latter gives clearly higher contrast, but at the expense of the more-prominent moiré that we noted earlier."
"Simply put, with optimum sharpening applied to raw files from both cameras, the D800E still nudges ahead of the D800, albeit by a very narrow margin, and one that is arguably academic for normal everyday photography."
"In the 100% crops above, you can see that edge detail is slightly more 'crisp' in the D800E. It's hard to argue that the D800E is providing more actual detail - the D800's resolution is very impressive in its own right - but edges are a bit more clearly defined in the D800E. You can also see, however, the presence of color artifacts in the D800E that are either absent or significantly reduced in the D800."
Simon
 Simon Garrett's gear list:Simon Garrett's gear list
Nikon D800
Devendra
Devendra Veteran Member • Posts: 3,583
i have D800E, but it will be 2yrs old soon
Copter01 wrote:
Hi
I noticed a lot of nice landscape shots in your website. So as you are aware by now, landscape can be single shot or panos, or HDR.
If looking for single shot images especially in challenging lighting situations, then D800E will be the "best" of all, even though D800 is not a bad choice, but like RC above, I want high acutance. Moire is not an issue unless its fabric shots, and CNX2 removes it very easily.
For other landscape situations, if you are seriously thinking of just a landscape camera with decent AF and other capabilities, D7100 with some high end lenses is not a bad choice along with Sigma 18-35mm f1.8 to compliment it. You can add other lenses based on above recommendations. I may get shot down for this, but you can get better out of the box edge to edge sharpness with this DX option. Plus, it is easy to shoot pano's these days.
Let us know what you go for.
 Devendra's gear list:Devendra's gear list
Nikon D200 Nikon 1 J1 Nikon D800E Sony Alpha NEX-3N
Re: D800 or d800e??
In theory, 360 ppi should be better than 240 ppi, but any difference is so subtle I can't really tell the difference. I was using the term "optimum" to mean best resolution to use when printing large.
Yes, ppi (pixels per inch) is the image resolution of the file sent to the printer. Some people use the term dpi (dots per inch) which more accurately refers to what the printer lays down on paper and is not what you set in the image.
soloryb wrote:
Robin,
soloryb
Robin Casady wrote:
Copter01 wrote:
Hi
Yes.
Robin Casady
—Mark Twain
Robin Casady
—Mark Twain
russbarnes Senior Member • Posts: 1,191
Copter01 wrote:
Hi
Go for "e"
It was a pleasure.
Stany
Stany Buyle
Photoforfun
For what it's worth I have had an identical experience. My D800E is my first choice every time, it's perfect for landscape work and I no longer sharpen images. My D800 often required a small amount of sharpening despite the resolution. Buy good glass and it will reward you. My D800 is about to be converted to 720nm Infrared. Images are on my website at www.russbarnes.co.uk
 russbarnes's gear list:russbarnes's gear list
Nikon D800 Nikon D810 Nikon PC-E Nikkor 45mm f/2.8D ED Nikon AF-S Nikkor 35mm f/1.4G Carl Zeiss Makro-Planar T* 2/100 +4 more
Espressoguy Junior Member • Posts: 37
Re: D800 or d800e??
It's an extra $300, so what would you spend that on if you didn't get the "E"? If on a sturdier set of tripod legs or ballhead, or higher quality filters then I'd for those things since they're more likely to make a difference than what the E brings.  But if you have all of that great support equipment then it's up to you.
Re: D800 or d800e??
Its even more in the UK, (£300), as usual. I do intend to keep the body for a good many years, and would rather pay a bit more, for the correct body.
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 12,502
Re: D800 or d800e??
This one really gets down to what bothers you more - lack of $300 or so, or lack of almost-impertible and largely-theoretical sharpness improvement.
I bought the D800e.  I could afford it, and paying a bit more for gear simply doesn't bother me once I've spent it.  I know some people would just miss that extra money over and over - for them, get the D800.
As for moire, I've not seen it to be an issue, ever.   Probably there is some somewhere in one or more of my shots if I looked for it.  (I don't shoot fashion or fabrics much).   Note that cameras now are in a trend where the AA filter is being removed.  I suspect it's so the manufacturers can show a small sharpness improvement, but it's probably also true that moire is less an issue than it's made out to be, and/or less an issue with higher pixel density.
I do pretty small amounts of post-processing sharpening on my D800e shots.   I suspect that you get just about the same results from a D800 shot by increasing intensity of unsharp mask by about 15% over the same D800e setting.
That said, if you print big and shoot landscape, you're the ideal target for a D800e.   But if you don't have a really good lens and technique, and don't shoot between F4 and F5.6, I don't know that it is possible to see a difference.
Craig
www.cjcphoto.net
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +35 more
