Any Diglloyd subscribers? EM1 12-40 backfocus issue.
Started Jan 31, 2014 | Discussions
Big Ga Forum Pro • Posts: 18,344
Anyone here subscribe to Lloyd Chambers' Diglloyd site?
Seems he's come across a nasty backfocus issue with the 12-40 on an EM1. The full details seem to be on the paid for part of his site, so please don't cut and paste here, but if anyone's got a synopsis, I'm curious as to what the general gist of the issue is?
Tia.
Ga.
PS - I've considered subscribing in the past. Anyone got any comments on the usefulness of the paid for articles?
Olympus E-M1
tgutgu Veteran Member • Posts: 3,613
Re: Any Diglloyd subscribers? EM1 12-40 backfocus issue.
5
Tia.
Ga.
Lloyd Chambers has a strong opinion against m4/3 and agitates against it, whenever he can. He claims that m4/3 has no future. So I wonder if he began his test runs without any preoccupations.
I guess, that he either made operational errors or he was in bad luck and got a faulty E-M1 sample. I never experienced serious focus problem other than my operational errors.
He also slams the quality of the 2.8/12-40mm zoom. However, in practice, I think it is the best standard zoom, ai ever owned - regarding IQ. It has better quality than most of my prime lenses.
After having subscribed for 1.5 years now, I have some doubts about his agenda. He thinks that the A7 system is almost a photographic revolution (although he experienced terrible shutter shock with the A7r), but fails to recognize that effectively smaller camera systems are only possible, if you also shrink the sensor.
So, it would not generalize his findings. The overall happiness with the E-M1 and the 2.8/12-40mm is justified. As with every product, there are faulty units, slipped through quality control, but not extraordinarily so. The problem is that every single incident pops up in internet fora and this skews the overall picture.
Thomas
 tgutgu's gear list:tgutgu's gear list
Olympus E-M1 Olympus E-PL7 Olympus E-M5 II Panasonic Lumix DMC-GX8 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS +30 more
drj3 Veteran Member • Posts: 3,869
13
I can see that it might miss focus poorly, but how can an on-senor CDAF backfocus?
drj3
 drj3's gear list:drj3's gear list
Olympus E-M1 Olympus E-510 Olympus E-5 Olympus OM-D E-M10 Olympus Zuiko Digital ED 14-42mm 1:3.5-5.6 +6 more
Big Ga OP Forum Pro • Posts: 18,344
An excellent question, hence my interest in finding out what Lloyd is saying!
Lab D Senior Member • Posts: 6,938
drj3
If you don't know what you are doing and use a large focal point, the camera can focus on something in the focus box that is behind the subject.  My bet is that is what he experienced.
With CDAF it is virtually impossible to have a backfocus issues which is an advantage mirrorless has over DSLRs.
 Lab D's gear list:Lab D's gear list
Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-GH4 Nikon D600
agentul
agentul Contributing Member • Posts: 618
6
drj3
will he also discover that he has a clogged carburetor in his gasoline injection engine?
 agentul's gear list:agentul's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-LZ2 +1 more
That is possible of course, however someone in his position with a subscriber based website is more than likely going to try to be at least accurate. So if he's reporting a problem, I'm tending to believe he's really seeing a problem, and he's tried to eliminate any obvious flaws in his testing or observations.
Excellent ... so what does he say
And to be fair, hasn't he instigated a petition to get Sony to at least admit there is an issue?
I can't comment as I'm not familiar with most of his writing.
True, but I would find it strange if Lloyd was not aware of the possibility his was a lone case. What has he said?
maljo@inreach.com Veteran Member • Posts: 7,035
Hard to know what to make of Lloyd
I don't have any of the problems he has.
He uses the most expensive lenses to create photos that don't engage me.
Everything in life is a compromise.
I like the MFT compromise, works well for me.
I think different people have different types of priorities.
maljo
 maljo@inreach.com's gear list:maljo@inreach.com's gear list
Canon EOS 5D Mark III Nikon AF-S Nikkor 14-24mm f/2.8G ED
Re: Hard to know what to make of Lloyd
So what problems does he have?
Anders W Forum Pro • Posts: 21,465
Don't know any more than you do about Digilloyd's findings. But FWIW it's worth, he had similar complaints about the 17/1.8. See here:
http://www.dpreview.com/forums/post/52083106
Perhaps just a way to recruit new subscribers by making puzzling claims.
It is not completely impossible to get systematic backfocus with CDAF. But the only cause I am aware of is a pretty heavy dose of spherical aberration, which may make the point of maximum contrast deviate from the point where our eyes see things as maximally sharp. See here for an extreme example:
http://www.dpreview.com/forums/post/51866366
Spherical aberration will also cause focus shift, i.e., the best focus will be aperture-dependent and the focus set by AF wide open therefore not match the best focus with the lens stopped down.
Nothing that I have seen so far indicates that either the 17/1.8 or the 12-40/2.8 have problems with spherical aberration of such a magnitude as to cause significant problems in these regards.
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +28 more
davidrm Senior Member • Posts: 1,366
12
If you subscribe, you'll discover that ALL of your photographs of brick walls suffer from hundreds of ghastly defects. If you don't, however, you'll be fine.
Blogs and galleries at http://www.snowhenge.net
E-System photos at http://www.flickr.com/photos/snowhenge/
I am pretty good at discovering that all by myself so it seems I can safely save myself the subscription fee.
D200_4me Veteran Member • Posts: 3,873
I haven't had any problems
Using the E-M1 and 12-40, it works fine for me.
Regarding that guy's site...I'm glad others said what I've been thinking.     I visited his site awhile back and the word that came to mind when seeing his photo samples were 'boring' and 'uninspiring'.  Ok, that's fine...he doesn't have to impress every person on earth, BUT if you present yourself as some sort of expert, it would be nice to have some great looking images to look at to go along with whatever he's trying to say.  So, as you can imagine, when I saw payment is required to see various content on the site, I quickly left the site and forgot about it.  Maybe he'll snag some paying folks, but I'll take a pass on that myself    I would never put down an amateur's photo galleries, but this guy is trying to sell access to content, so I think you can hold people like that to a higher standard.  I've also heard of quite a few wild claims he's made over time so I just sort of came to distrust him.  Mediocre photos + too many wild claims means, no payment from me.
Heck, I pay Smugmug about $150 every year to allow thousands upon thousands of people to view my photo-hobby photos as much as they want and I don't insist anyone pay to browse around my site.  But, feel free to buy tons of prints from me if you want!  I won't turn away a sale, if I ever do get one (officially I've sold 3 prints from my smugmug site in the 5 years or more since I've been there...LOL).
 D200_4me's gear list:D200_4me's gear list
Fujifilm FinePix X100 Sony a6000 Nikon Df Nikon D750 Sony E 16-50mm F3.5-5.6 PZ OSS +6 more
SaltLakeGuy Forum Pro • Posts: 11,223
My combo never misses
so he either has a problem unit or is furthering his anti mft agenda. I pay NO attention to him.
 SaltLakeGuy's gear list:SaltLakeGuy's gear list
Sony Alpha 7R II Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sony FE 70-200 F4 Zeiss Batis 85mm F1.8 +1 more
jkrumm Veteran Member • Posts: 8,961
Re: I haven't had any problems
Funny how that works... I had a pro account for a few years and finally decided to keep it a hobby site and save  some money. If you want to sell images you have to put a lot of time into the marketing/business side of things. With zero marketing I sold one digital download and one image for a state designed government app (through a Google search).
John Krumm
Juneau, AK
I do have an istockphoto account and I've made some money there, but not much.  I rarely upload to my istock account because for one thing, I'm just lazy about it and another thing is, I just don't have the right type of content that sells well there.  I'm surprised how well some images have sold though.  Anyway...I'm happier to keep this as a hobby and not feel burdened by feeling a 'need' to sell.
exdeejjjaaaa
exdeejjjaaaa Veteran Member • Posts: 7,708
for example - focus shift (if lens designed so)...
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Phase One Capture One Pro +23 more
exdeejjjaaaa
indeed...
Hmmm. Well I've not heard about any of his 'wild claims' (care to elaborate?)
However if I'm visiting a site for technical details, I'm really not concerned at all as to whether the person producing the information has the artistic eye and skills to produce a compelling image.
If I'm buying a motorcycle, I want the design team to have degrees and skills that let them produce a machine that looks good, had a great engine, stops well, has decent suspension etc. I don't give a monkeys whether they themselves can ride the thing at 150MPH round a racetrack or not. In fact, I probably wouldn't feel particularly happy if I discovered that some oik who might be the fastest rider in the world had been the person responsible for doing all the safety checks on my bike!!
Also, I know from experience that my own 'tests' rarely if at all end up being award winning images! Especially the ones involving brick walls .....
exdeejjjaaaa wrote:
indeed...
good grief ... I see Lloyd has got a tough audience tonight
