Faked DSLR - A new trend for the mirrorless.
Started Jan 30, 2014 | Discussions
nofumble Senior Member • Posts: 1,512
What's up with the faked pentaprism on E-M1, A7, X-T1 ???
Fujifilm X-T1 Olympus E-M1 Sony Alpha 7
sshoihet Senior Member • Posts: 2,538
Re: Faked DSLR - A new trend for the mirrorless.
19
They probably realized that most of us that actually use our cameras heavily don't want a cigarette pack with a soft drink can stuck to it...
 sshoihet's gear list:sshoihet's gear list
Canon PowerShot S95 Nikon D7000 Canon EOS M Nikon D600 Nikon D7100 +14 more
Martin.au
Martin.au Forum Pro • Posts: 10,317
12
It gives the designers somewhere to stick the enormous EVF.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +6 more
nevada5
nevada5 Veteran Member • Posts: 7,868
So... Another humpophobic.
7
It looked even funnier when they put it on the bottom.  So this is better.
Life is short - drive a convertible.
Tolerance is the last virtue of a dying society. Aristotle
 nevada5's gear list:nevada5's gear list
Nikon Coolpix P330 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-G7
EinsteinsGhost
7
There is no fake pentaprism. You're simply seeing things.
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
Graham Hill Senior Member • Posts: 1,355
Have you figured out where the viewfinder is on these cameras yet?
GodSpeaks
GodSpeaks Forum Pro • Posts: 11,594
Enormous EVF?  Seen an NEX-6 or GX7 lately?
The greatest of mankind's criminals are those who delude themselves into thinking they have done 'the right thing.'
- Rayna Butler
 GodSpeaks's gear list:GodSpeaks's gear list
Panasonic Lumix DMC-TS5 Panasonic Lumix DMC-FZ1000 Kodak DCS Pro SLR/n Sony Alpha DSLR-A850 Panasonic Lumix DMC-GX1 +45 more
Just another Canon shooter
Just another Canon shooter Senior Member • Posts: 4,691
They are going for the retro look.
 Just another Canon shooter's gear list:Just another Canon shooter's gear list
Canon EOS 5D Mark II Canon EF 15mm f/2.8 Fisheye Canon EF 35mm f/1.4L USM Canon EF 50mm f/1.2L USM Canon EF 135mm f/2.0L USM +4 more
nofumble OP Senior Member • Posts: 1,512
A good one
+100
Ontario Gone
Ontario Gone Senior Member • Posts: 4,183
6
Yes, have you? Notice the NEX6 is far closer to a 1DX than the APSC prisms. And, do you really think these won't increase in size over the next few years? The new X-T1 says they will. Do you think OVF will increase in size? History tells me they won't.
"Run to the light, Carol Anne. Run as fast as you can!"
 Ontario Gone's gear list:Ontario Gone's gear list
Nikon D7000 Canon EOS 70D Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 50mm f/1.8G Canon EF 40mm f/2.8 STM
Ontario Gone
+100
Martin.au
- Rayna Butler
Truth be told, I didn't realise they were that large. However, I suspect that's also about the upper limit of what they can jam in there.
In that case, it gives the designers somewhere to stick the accessory port.
Leon Wittwer Forum Pro • Posts: 13,079
Need base for flash attachment. (nt)
TrapperJohn Forum Pro • Posts: 13,836
same thing that's up with...
EM5, EM10, GH1-GH3, G1-G6, A3000, and all of the Sony SLT cameras. Technically speaking, none of them need a prism like hump, because all of them have EVF's.
One reason is marketing: Back in the mid 2000's, Olympus brought out a new DSLR that had no hump, styled after the old Pen F cameras. Like the Pen F's, it used a sideways mirror to redirect VF light to the side and up to the VF, for a lower profile. This was called the E300. It was a slow seller.
Six months later, they took the internals of the E300, repackaged it with a pentamirror and hump for a more traditional SLR look, and it was a hot seller. Otherwise, exactly the same camera as the E300.
Apparently, a lot of people don't like funny looking cameras, and that does impact sales.
Can't speak for the others, but in the case of the OMD line, the hump houses not only the EVF but also places the sensor for the electomagnetic IBIS in an optimal location. So there is some functionality for it, but in the end, it's largely styling for a more familiar look.
mosswings Veteran Member • Posts: 7,517
Well, part of this is for style, but there's actually a very good ergonomic reason for the humped viewfinder from a control placement point of view...you can fit more controls in at the right places, and all these humped designs have lots of manual dials. Plus, on the newest ones the viewfinders are immense, with eye relief designed to accommodate glasses...big hump. Check out
www.cameraergonomics.com
for a fascinating and exhaustive treatment of this subject. For viewfindered cameras, the hump isn't just for style points.
 mosswings's gear list:mosswings's gear list
Olympus XZ-1 Olympus Stylus 1 Nikon D90 Nikon D7100 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +5 more
Leonard Migliore
Leonard Migliore Forum Pro • Posts: 13,239
Are you that happy with yourself?
6
Ontario Gone wrote:
+100
This appears to me that you are emphatically agreeing with your own post. Have I interpreted this correctly?
Leonard Migliore
 Leonard Migliore's gear list:Leonard Migliore's gear list
Canon PowerShot G12 Sony Cyber-shot DSC-RX100 III Nikon D300 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G +8 more
socode Regular Member • Posts: 356
Re: Are you that happy with yourself?
8
Leonard Migliore wrote:
Ontario Gone wrote:
+100
To be fair, aren't you less worried than if he'd violently disagreed with his own post?
Aaron801 Senior Member • Posts: 3,110
I'm actually fine with the shape of the "cigarette box" style cameras, but I have to wonder if the ones with that shape tend to have the brightest viewfinders...? From what I understand, they don't. The GH2 that I just bought has a bit of a hump on the top and to me it isn't a slick looking as some of the ones that don't.... but it does have a really bright viewfinder and I'm happy with that... Form follows function you know, though I know that there's a bit more of that going on because that extra space on top tends to be designed to look like an old SLR hump, but is that really such a bad thing.
I think that some of the new crop of cameras like the new Fuji model are quite well designed. I like the "retro" controls on the body approach, it seems like it isn't really any bigger than it needs to be and the look is cool in my book, retro or not.
 Aaron801's gear list:Aaron801's gear list
Panasonic Lumix DMC-GH2 Olympus OM-D E-M10 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS
EinsteinsGhost
- Rayna Butler
Besides that the EVFs on NEX-6 and like might be pushing the limits, you also have to consider ergonomics when you shoot with lenses that are larger, heavier and you also don't limit self to landscape mode only.
As much as I enjoy using my NEX-6, especially with small native and legacy lenses, portrait mode and using heavier lenses becomes an issue with lens mount and EVF not being aligned.
yardcoyote Senior Member • Posts: 6,059
What other shape do you want it to be?
If you are going to have an ergonomic camera with both a large centered viewfinder and a screen that almost covers the back, the logical place to put the viewfinder is above the screen.  So you basically have a rectangular box with a smaller housing on top of it in the center.  The other option is to make the box taller to enclose the housing, but that makes for an awkward grip with no way for the fingers to engage controls on the top surfaces.
If you take that combination of a horizontal oriented rectangular box shape with a smaller housing at the center top, and put a lens in the middle of the box in the front, it's going to look like, guess what, a camera with a high mounted center viewfinder.  Which is what it is.
How you style it, and therefore how much it looks like a "retro SLR" is a matter for the marketing department.  But the basic shape comes from what it is.
 yardcoyote's gear list:yardcoyote's gear list
Fujifilm X10 Fujifilm X100T Pentax K-5 IIs Fujifilm X-T10 Pentax smc DA* 55mm F1.4 SDM +8 more
