Another Olympus E-M1 and SONY a7 walkabout test, high ISO
Started Jan 29, 2014 | Discussions
Big Ga Forum Pro • Posts: 18,398
Re: "But if you shoot at high ISO - a larger sensor is your friend."
Fred Mueller wrote:
Full frame gets sold on the magic of the very narrow DOF "look", but in practice, that look is an outlier most of the time.
That all depends on what you shoot. For many people, needing extended DOF in a shot is an outlier most of the time.
Lab D Senior Member • Posts: 6,938
Wrong
Sergey_Green wrote:
Anders W wrote:
blue_skies wrote:
Anders W wrote:
Henry showing the difference between sensors
Lol, instead of 2x I will use 1.5x for A7 and 1.8x for A7r. So, at equivalency, the M1 will be slightly better?
Sorry but apparently you still didn't get it. As you can see from the diagram above, the E-M1 is about 1.5 EV ahead for equivalent images and about 0.5 EV behind for non-equivalent ones (same exposure, different DoF).
It is about 1.5 stops behind when you take pixel count into consideration,
The chart already takes pixel count into consideration.  If you don't on the DxO site the E-M1 line moves up even with the 2 A7 cameras.   Go to DxO and read about the difference between "screen" and "print" when viewing their graphs.
and is another 1.5 stop behind in headroom (highlights).
Now you are just making stuff up.  I trust DxO over you.
 Lab D's gear list:Lab D's gear list
Panasonic Lumix DMC-FZ1000 Nikon D600 Panasonic Lumix DMC-GH4
Sergey_Green
Sergey_Green Veteran Member • Posts: 8,906
No, not really ..
The shown graph shows screen (100% crop) comparison, not from normalized down-scaled images. Below is the normalized print comparison.
I just realized there is a fraction of difference for shadows between OMD5 and OMD1, else the graphs are pretty much the same.
- sergey
 Sergey_Green's gear list:Sergey_Green's gear list
Samsung Galaxy Note 10.1
Ulric Senior Member • Posts: 3,580
MatsP wrote:
Once upon a time when I was shooting FF - back in old film days - my biggest concern was to get enough DOF, not the opposite. Anyway I still, as an EM-5 owner, sometimes think that maybe I should get myself an FF digital. And the 7 and 7r really tempted me. After reading this thread they are much less tempting to me.
Getting enough DOF still is a challenge. Here's Ingrid, only one eye in focus, and the lens is not even wide open. The primary benefit of fast lenses is that they let in more light.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +9 more
You didn't read did you
You didn't read did you.  The Chart is for noramized down-scaled images.  PLEASE go to DxO's site and read about the difference between "screen" and "print" when viewing their graphs.
Then go look it up again, make sure you select print this time.
You didn't read.  These were with "Print" selected.  Even when you switch to "screen" which used the full resolution it does NOT change by 1.5 stops like you keep saying.  Instead it give the E-M1 about 1/2 stop advantage and makes it almost even (see screen is now selected).
- sergey
Sergey_Green
Yes, I did read ..
Is what it should be if you compare to the same result. Image with more pixels does not have to have the same noise granularity at 100% to be equal.
Even when you switch to "screen" which used the full resolution it does NOT change by 1.5 stops like you keep saying. Insead it give the E-M1 about 1/2 stop advantage.
No, it does not. Sony is ahead by 1.5 stops in the shadows on the average. Add another 1.5 stops for the highlights. You get smoother looking image as a result.
See my post above.
- sergey
HELLO!! You are not reading!
No, it does not.
HELLO!!!!! I even posted the actual DxO graph!  As you can see if we switch to "SCREEN" it moves the E-M1 line up almost equal with the A7.  The other chart had the images normalized and so the E-M1 was about 1/2 stop lower.  Your 1 and 1/5 stop claims make zero sense here.
Here is normaized and "Print" is slected:
Sergey_Green
You posted wrong graph ..
But that is irrelevant, you are comparing 100% crop, what good is comparing to the same noise if you have more detail in one image and less in the other. Hello back at you.
- sergey
Sergey_Green
Ah here ..
Lab D wrote:
This graph is about right. But then again, it is more than a stop difference at base ISO, where most people shoot. At least I do. OMD will still clip highlights way before Sony does, at any ISO.
And I am honestly surprised OMD1 does slightly better in the shadows than OMD5, would think this is almost the same imager.
- sergey
So yes, I was right all along, thanks
Sergey_Green wrote:
So after psoting this graph about 10 times you finally agree.  As you can see the difference for almost every ISO is about 1/2 stop.   Nowhere is it the 3 stops you claimed.
For the record, when you kept saying I was posting the non-nomalized graph, here that is which shows the E-M1 is virtually the same.  For practical purposes we should not use it and the one above is more useful.  Notice there is NOT a 1.5 stop difference between graphs.
Sergey_Green
In all seriousness ..
Have you considered this,
http://www.flickr.com/photos/97512826@N06/sets/72157634195387985/
- sergey
Now you agree it was correct.
- sergey
I see in you other post where you finally agreed it was the correct chart.
Here are both:
Godfrey Forum Pro • Posts: 29,008
Re: Another Olympus E-M1 and SONY a7 walkabout test, high ISO
... In conclusion, I am enjoying both these cameras tremendously and if I were stuck with either one, I'd be just as happy.
Same here. So far, I have not seen enormous differences in imaging performance between the two cameras that are in any way derivative of sensor quality. The big differences I see are responsiveness and the specific lenses ... and I'm using mostly Panasonic-Leica and Olympus top line lenses on the E-M1, and Leica R lenses on the A7.
Both cameras are very enjoyable to use, now that I have them sorted to my preference, and work very well. The goal now is to forget all the bits and bytes, comparison stuff and use them to make great photos...
Sergey_Green
I did not say I agree,
Lab D wrote:
It is 14.2 over 12.7 at base ISO, but you are looking at the shadows only. Look at how they compare in the headroom. From dark to white you get almost 3 stops difference. Well, fraction less, but you can safely round it up to the nearest digit. Also look at the color depth, hmm, I think you are upset enough for today already.
Whatever. We get the picture
- sergey
texinwien Senior Member • Posts: 3,320
Re: Ah here ..
- sergey
LOL. Sergey's wrong again. Seems to be making a habit of that, lately.
 texinwien's gear list:texinwien's gear list
Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus 12-40mm F2.8 OnePlus One Canon EOS 300D +20 more
Sergey_Green
Really?
Wrong how exactly?
- sergey
Sergey_Green
Considering Sony has the same (or at least very close) as D800 sensor
You will not see much difference in normal mode on the average scenes. You will see enormous difference if you get creative with it and start looking at finer detail from more dynamic scenes (into the light, white snow, finer color, etc ..).
- sergey
Re: I did not say I agree,
Sergey_Green wrote:
Actually you are making use laugh.  So at the ISOs you need DR the most you claim 3 stops and yet DxO shows it is about 1/2 stop.  I'll go with DxO.
Oh, and everyone uses the base ISO exclusively right?  Why do they have have an ISO setting on cameras?  I am sure in doors and you enjoy using the 2 second shutter speed at base ISO.
- sergey
Re: Considering Sony has the same (or at least very close) as D800 sensor
- sergey
Yeah, where is that giant dynamic range difference again at ISOs 120-12800? LOL!   I see about .5 stop.
Sergey_Green
Actually ..
We are looking at DXO. What does DR mean to you, why is it important?
I do use ISO rather often, but I get more clipped highlights (yes, with D800) then I care about shadows. It is difficult to clip highlights with this camera, but I manage ;).
- sergey
