Another Olympus E-M1 and SONY a7 walkabout test, high ISO
Started Jan 29, 2014 | Discussions
Daniel Wee
Daniel Wee Contributing Member • Posts: 537
27
Recently I wrote up about my comparison between the Olympus E-M1/17mm F1.8 and the SONY a7/35mm F2.8. I figured that many people here might be wondering what the differences may be and how much of a difference one might get going from a micro four-thirds setup to a roughly equivalent full-frame setup. Of course, it was meant to be seen from the point of view of an end-user trying to get roughly the same kind of field of view. I had in mind also to try to show how much the difference in the depth-of-field one could expect with the slightly different setups.
Note: The Olympus 17mm would give a field of view similar to that of 34mm in FF terms, and the DoF afforded by the F1.8 aperture would be what you'd get with F3.6 in FF terms. However, the F1.8 will still be as bright as F1.8 in FF terms, and naturally brighter than F2.8 or F3.6 on FF cameras. I put this here just so that the nitpickers can stop hijacking the thread and turning it into some techno-babble debate.
In the course of that thread, someone asked if I had any high ISO comparisons. I didn't, at that point of time, but today my SONY Carl Zeiss 55mm F1.8 lens arrived. Now, this is one expensive piece of glass, but it is also supposed to be the sharpest glass you can get for the SONY a7/r right now, that offers full AF. If you don't care for AF, you might want to try the Otus if you can afford it.
So, I thought it might be a good idea to compare that with the Panasonic Leica 25mm F1.4 lens that I also had, that was also expensive though not nearly as expensive as the Carl Zeiss. This will give the field of view of a 50mm lens on FF, and the depth of field of a F2.8 FF lens. And yes, F1.4 is as bright as F1.8 on FF, we know that.
My first impressions are that both lenses are incredibly sharp and very high quality. Both are a real pleasure to use. I found that manual focusing (using only the magnification aid and not the peaking function) on the Carl Zeiss was a bit easier than on the Leica. The manual focussing ring on the CZ seemed to be less touchy than on the Leica, notwithstanding the fact that the DoF was shallower. It's not a big difference and certainly not a deal-breaker. In fact, if not for the fact that I was constantly switching between the two cameras, I probably would not have noticed it at all. I mention this here for those who want to know how well manual focusing is implemented on the SONY a7. Answer: Pretty darn good. The E-M1 is no slob either. In one scenario, I found the E-M1's implementation to be particularly better. This is when I am focusing manually and the magnifier is on. If I half-press the shutter release at this point, the magnification is cancelled and I need to move the ring to bring the magnifier back up. On the E-M1, this happens snappily whereas the a7 takes slightly longer to bring back the magnifier.
When it comes to auto-focusing in low-light, the E-M1 feels a lot snappier than the a7. Neither cameras missed their shots but the a7 hunted occasionally whereas with the E-M1, you fire away with a confidence that the camera well deserves. Having said that, I could live with the a7 auto-focusing since I don't really do sports or action photography much, and I don't often shoot in very low light (which is when this problem is more pronounced). When it gets that dark, I prefer to manual focus anyway.
Another thing that I had not written about in my previous comparison thread was the difference between the native aspect ratios. The a7 has a 3:2 aspect ratio while the E-M1 uses a 4:3 aspect ratio. In practice, this means that the a7 produces more elongated frames. I mention this because while trying to get similar framing for the photos from the two cameras, I had to make some adjustments due to the different aspect ratios. I think I could get used to a 3:2 aspect ratio. Yes, I also know that you can select a 3:2 ratio on the E-M1, and yes we can always crop it in post as well. This isn't a criticism of one or the other. Some who are wondering about the a7 may want to take this minor difference into consideration if you strongly favour the 4:3 aspect ratio.
Now, onto the test images. All were shot in RAW, and most were shot wide open, as wide as the lenses will allow - which is F1.4 on the Leica and F1.8 on the Carl Zeiss. I buy these kinds of lenses to use them for their speed so I thought it would be meaningful to test them where they will be used most (by me). In the first test pair, I shot the Leica at F1.8 instead of F1.4 by mistake. In the last test pair, the CZ was shot in F8 while the Leica in F4 on purpose. The field of view of the 55mm is a little narrower than that of the 25mm (FoV of 50mm in FF) so I sometimes had to move a bit to get similar framing. Images were processed in Lightroom 5.3 and luminance noise reduction was set to zero. I notice that the E-M1 tends to expose brighter (using center weighting, sometimes even over-exposing) than the SONY which tends to expose more accurately. As a result, I had to dial in a -0.7EV for the E-M1 on average, sometimes more and sometimes less, to get the correct exposure. I also found the reds quite strong for the E-M1 images (which tends to look warmer) when processed in Lightroom, while the SONY is more muted. I did tweak the colours a bit to get them closer. I do slightly prefer the auto white-balance on the a7 though, although this is easily adjusted in post.
Here we go:-
a7 ISO 1600, 1/1250 sec @F1,8
E-M1 ISO 1600, 1/640 sec @F1.8
a7 ISO 3200, 1/80 sec @F1.8
E-M1 ISO 3200, 1/80 sec @F1.4
a7  ISO 3200, 1/2500 sec @F1.8
E-M1 ISO 3200, 1/4000 sec @F1.4
a7 ISO 3200, 1/800 sec @F1.8
E-M1 ISO 3200, 1/640 @F1.4
a7 ISO 3200, 1/1000 sec @F1.8
E-M1 ISO 3200, 1/1000 sec @F1.4
a7 ISO 1600, 2 sec @F8
E-M1 ISO 1600, 0.6 sec @F4
As you can tell, even up to ISO 3200, both cameras perform admirably and while the a7 has lower noise, as one would expect for the larger sensor, it really isn't radically better than the E-M1. On both cameras, the noise had a very nice and pleasing grain to it and colour noise was not a problem. I'd say that the noise for these cameras at ISO 3200 was similar to what I got at ISO 800 on my Nikon D2H from yesteryear. Details were held well and I wouldn't hesitate to use ISO3200 if I felt I needed to.
As you can probably tell from the test images, both cameras hold their own. The a7 has more resolution and slightly better noise handling but not by an earth-shaking margin. It is what you would expect from a full-frame sensor and a machine/lens combo that costs more. The E-M1 has every reason to hold its head high - we're talking about comparing a m4/3 sensor to a FF one.
In conclusion, I am enjoying both these cameras tremendously and if I were stuck with either one, I'd be just as happy. Each has advantages over the other but neither has an overwhelming advantage. Both the Carl Zeiss and the Leica are really some of the best in their class lenses. You pay for them, but you get what you pay for.
Disclaimer: What is presented above are my observations and opinions. They are NOT intended as "criticism" of either machine, nor presented as gospel truth. The methods used were not intended to be scientific comparisons, but how a typical end user might use both machines to get similar images, so give them some leeway. I own both machines and am brand agnostic. Of course, my own methods are not perfect and there are certainly ways to even things out even more - that is not my intention nor do I have the time for too much elaborate testing. I wish both Olympus and SONY would be spurred by the competition to make even better cameras, because that way we all win.
 Daniel Wee's gear list:Daniel Wee's gear list
Olympus C-2000 Zoom Nikon D70 Panasonic Lumix DMC-GF1 Sony Alpha 7S Sony Alpha 7 II +13 more
Nikon D2H Olympus E-M1 Sony Alpha 7
Daniel Wee
Daniel Wee OP Contributing Member • Posts: 537
Re: Another Olympus E-M1 and SONY a7 walkabout test, high ISO
Typo in the 4th para: The F1.4 is as bright as F1.4 in FF.
Obviously since F1.4 is F1.4 anywhere.
Lindsay D Regular Member • Posts: 426
Thank you Daniel, for taking the time to write a detailed, interesting, and informative response.
www.lindsaydobsonphotography.com
photofan1986 Senior Member • Posts: 2,803
Thanks fir the comparison.
The night cityscape show how much better then PL25 is compared to the Zeiss. The latter is really poor even :s
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Canon PowerShot S100 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +7 more
a13 Regular Member • Posts: 171
It interests me that in some cases you had higher shutter alongside matching aperture for the OM-D over the A7.. strikes me as very surprising. Doesn't seem like it should be possible...
Daniel Wee
I had to adjust some of the exposures in post to get them to look similar. Probably have to take the specifics with a grain of salt. The adjustments were not major though, and the E-M1 tended to exposure brighter that the a7.
Daniel Wee
I think, in all fairness, that could be more an issue of the a7 AF in low-light than a lens issue. For those two shots, I had to use AF because I had the camera on the ledge of a building and it was inconvenient for me to MF them. In this case, I suspect it was due to the a7 missing the focus while the E-M1 nailed it.
Advent1sam
Advent1sam Senior Member • Posts: 2,859
You should of just gone ahead with f8 too for the PL, nice to see some stars in the lights
In any event interesting, very. I think it would be closer with the new PL 42.5 but then you are a little longer still but it would be usable for most of the close-up stuff?
Many thanks for this.
quezra Senior Member • Posts: 3,915
The picture of the two lighted horses - the EM1 absolutely mashes the wire mesh detail, while it holds up very well on the Sony A7.  But your sharpening/NR at these ISOs looks very much poorer than what the A7 JPEG engine can do?  None of my out-of-the-box A7 JPEGs - even as high as ISO 6,400 - are anywhere as noisy.
 quezra's gear list:quezra's gear list
Sony Alpha 7 Sony FE 55mm F1.8 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Sony Alpha NEX-5N Panasonic Lumix DMC-GH3 +10 more
Daniel Wee
That's possible. I am using minimal to no sharpening, primarily because I didn't want to accentuate the noise situation at high ISO. The idea was that people would be able to inspect the noise characteristics, and then they can apply as much NR as they feel is needed. From what I hear, some people love the a7 JPEGs, while others hate them. If there's enough interest, I could try to take some OOC JPEGs and compare them. I imagine that for some people, this could be useful.
Daniel Wee
You're right. I hadn't noticed that earlier. This could also have been due to a mis-focus or hand-shake (from the looks of some of the lights) but I don't remember shaking that much. Plus IBIS was active.
captura Forum Pro • Posts: 21,781
I don't agree. They are equal.
arbuz Senior Member • Posts: 2,247
Different shutter speeds, different apertures, exposure compensation...
I wonder what is the purpose of that comparison? "by mistake" you set different apertures but with the same time and ISO wouldn't you expect different exposure? If there is different exposure then comparison doesn't make sense. If exposure is the same then Olympus ISO setting is inflated. If it is inflated why do you compare it side by side?
I can't believe you wnated to make  a fair comparison when after preparing several sets of pictures and no single set was shot using the same shutter/aperture/iso.
 arbuz's gear list:arbuz's gear list
Nikon D600 Samsung NX300 Panasonic Lumix DMC-G6 Samsung NX30 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +14 more
Since he tweaked each comparison to make it incomparable (let's set different shutter for one camera here, or different aperture or exposure compensation etc) then I would not be surprised it there was some jpg tweaking involved to match the agenda.
Given DxOmark's test of the FE 55/1.8 you were actually correct:
http://www.dxomark.com/Lenses/Compare/Side-by-side/Panasonic-Leica-Summilux-DG-25mm-F14-on-Olympus-OM-D-E-M5-versus-Sony-FE-Carl-Zeiss-Sonnar-T-STAR-55mm-F18___450_793_1252_0
They have the same T-stop so yes, f1.4 = f1.8 in this case, it wasn't your Oly overexposing the same shot
Daniel Wee
Actually it is very simple and there's nothing conspiratorial about this. After all, I stated exactly what I had done. What do you suppose the agenda might be? To make the E-M1 look worse? And why on earth would anyone want to do such a thing? To make the a7 look better? Whatever for?
As explained in the OP, I did this, first of all, in response to queries about high ISO performance. The rest are low priority outcomes. I can't believe that even with all the disclaimers and disclosures, there would be allegations of hidden agenda. Amazing.
Daniel Wee
Wow. Thanks - I wasn't aware of that. This is useful info. Appreciate your highlighting it.
5
You have stated it but you still did it. Had you forget to mention about it there is still exif. You're claiming you did a camparison and draw a conclusions like if you had compared apples to apples.
Since when adding more light to E-M1 pictures would result in E-M1 look worse?
First set - A7 has much hiher shutter speed = less light.
Second set - At has higher aperture = less light.
3rd set - with times 1/2500 and 1/4000 it is hardly a proper ISO test as there is plenty of light.
4rd set - A7 has 1/3EV less shutter, 2/3Ev less aperture while oply has 0,7 exposure compensation. Less light to A7 again. Not to mention that sony image is darker so they are not comparable.
5th set - A7 get 2/3Ev less light.
6th set - aparture difference with strange explanation. F4 for 35mm gives plenty of DOF and there will not be so much details in distant building anyway with this kind of shot.
Basically you have applied constant exposure bias in favour of E-M1. Interestingly there is no single case where settings are equal or when bias is on sony side. You call it "dislosure". I call it agenda.
ohmydentist Senior Member • Posts: 1,918
can't choose on IQ anymore
Choosing camera based on IQ is like choosing a car based on whether it could take you from point A to B.  All cars do it very very and very well.
It's all about personal preference now:
size (2 or 4 doors, compact or SUV)
design (yes this is big)
ergonomics (handling, AWD? RWD?)
performance (MPG, acceleration)
build quality
and many other high tech options that nobody uses but still wants
^__^
Just Shoot !
Daniel Wee
6
Ah, so you think I'm trying to make the a7 look better than the E-M1.
A kind poster just pointed out that the 55mm lens, when set at F1.4 is actually shooting closer to F1.8. See DXO link above.
Frankly, I think you're way off base here buddy. But hey, it's a free world and you can think anything you want.
