Oly 25mm 1.8 available for pre-order on Amazon
Started Jan 29, 2014 | Discussions
azazel1024
Senior MemberPosts: 1,112Gear list
Re: Oly 25mm 1.8 available for pre-order on Amazon
In reply to broody, Jan 29, 2014
broody wrote:
Sorry for the double post... There is an MFT chart from a spanish site:
So it seemingly has sharper corners than the 45mm wide open. Looks pretty good to me!
Hmm seems like it is slightly weaker than the PL25mm in the center across the range, but maybe slightly sharper in the corners at f/1.8 and f/2, but slightly weaker again in the corners at f/2.8 on. I guess a question of rendering, do you need the extra speed and what the small price difference means to you (and if the size/weight different matters).
It would be a much easier choice if the price was $299 or $349 instead. But, meh. Doesn't effect me. It does seem like a very nice lens though.
Many things dealing with Olympus and their OM and Pen cameras, plus my general photography and musings http://omexperience.wordpress.com/
 azazel1024's gear list:azazel1024's gear list
Sigma 30mm F2.8 EX DN +10 more
michealjmn
Regular MemberPosts: 170Gear list
Re: I'll wait
In reply to Art_P, Jan 29, 2014
Like Art I will also wait for the reviews and perhaps for the price to settle a bit. However, the 25mm samples in the gallery for the EM-10 look good.
Micheal
 michealjmn's gear list:michealjmn's gear list
Olympus OM-D E-M5 Sony a6000 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm 1:1.8 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +2 more
G1Houston
Senior MemberPosts: 2,287Gear list
Re: Only $100 more for the Panasonic?
In reply to lnikj, Jan 29, 2014
lnikj wrote:
We'll see but my guess is like the other Olympus 1.8 primes this will be edge and corner corrected whereas the Panaleica 1.4 is not to my knowledge (on Olympus bodies)?
First I am not sure if the 25/1.8 will have better corners at f1.8.  Keep in mind though that only the 25/1.4 can be used at f1.4, which makes it the fastest native m4/3 lens.  Another thing to remember is that corner sharpness is not everything, and in fact the corrections for corners sharpness often result in bad bokeh.  The 25/1.4 is known to have a smooth bokeh even wide open, which is one of the main reasons people want it.  Edge to edge sharpness is more important for a lens designed to be used for landscape.  The 25/1.8 is really best to be viewed as an ideal kit lens with the new OM10 for people who are just starting to collect lenses.  If you already have the 25/1.4 or the 20/1.7, it is hard to justify the need to get this lens, IMOP.  If OM10 uses the same image processor as EM1 (and it seems that it does), the banding issue with 20/1.7 should be addressed.
 G1Houston's gear list:G1Houston's gear list
Panasonic Lumix DMC-GH1 Olympus PEN E-PL5 Nikon D7100 Nikon AF-S DX Nikkor 35mm f/1.8G Panasonic Lumix G 20mm F1.7 ASPH +6 more
azazel1024
In reply to G1Houston, Jan 29, 2014
Mmm, but it has the same sensor as the E-M5 and not the E-M1 and it is likely a SENSOR issue, not an image processor issue. So it probably does have the same banding.
Your other points I agree with completely though. That said, at least the one chart floating around (see above) shows the 25mm f/1.8 to have slightly better corners at f/1.8 and f/2, but not quite as good from f/2.8 on and the center sharpness on the 25/1.4 is better across the range, though not by much.
Maybe 5-8lp/mm weaker on the 25/1.4 at f/1.8 and f/2, but 5-10lp/mm sharper in the center across the range and 3-5lp/mm sharper in the corners from f/2.8 on. Or so it seems. IE not significant differences. The rendering on the early samples on the 25/1.8 seem nice, but they don't move me. I do LOVE the rendering on my 25/1.4 though, and without a lot more pictures to compare, I think I like the rendering on the 25/1.4 better.
DoF is still a modest different between 25/1.4 and 25/1.8 too, and its already resonably deep for the 25/1.4, so I don't know that I'd want to limit my options further.
Just my 2 pence.
FrankS009
Senior MemberPosts: 2,785Gear list
Disagree about abandoning the Panasonic 20mm. For one thing, the 20mm is considerably sharper, and I have never had slow focusing issues personally.
F.
When no-one else is there, the camera becomes my means...to say to a wider audience, "Did you see that?" David duChemin
G1Houston
In reply to azazel1024, Jan 29, 2014
Read the E-M1 review: this issue was addressed in E-M1.
FrankS009
In reply to FrankS009, Jan 29, 2014
Left the Panasonic 20mm out of the comparison with respect to sharpness. It is also significantly sharper than the new Olympus 25mm.
F.
mh2000
Senior MemberPosts: 2,701
In reply to peppermonkey, Jan 29, 2014
peppermonkey wrote:
lnikj wrote:
Which I have done
ETA March 7th.
First, congrats Any new lens purchase is an exciting event
Not to criticize your purchase too much but if you can get the Pan-Leica 25mm 1.4 for only ~$100 more, I sure hope the lens is absolutely stellar, otherwise, I think the Pan-Leica is a better deal...
Unless I'm dead set on 'only' getting Olympus lenses, I think I would have waited till the reviews comes in. Even then, there is a good possibility I would go for the Pan-Leica simply because of the extra speed.
Still, it's pretty small, and it does look like a pretty lens.
Hubert
My non-digital gear: Agfa Isolette, Fed 2, Konica Auto S2, K1000, Yashica Electro 35 GX, Recesky
http://farm3.static.flickr.com/2034/2457111090_00eafbf8a4_m.jpg
http://www.flickr.com/photos/peppermonkey/
The P/L 25 is pretty big and heavy... not everyone can get over that. Easy to do when looking at numbers on paper, but walking around all day might tell a different story for some.
mh2000
If all you have is the 20 and you really want a 25mm "normal" FL length lens, this is a big deal.
Pic Man
Senior MemberPosts: 1,091Gear list
In reply to mh2000, Jan 29, 2014
mh2000 wrote:
peppermonkey wrote:
lnikj wrote:
Which I have done
ETA March 7th.
Hubert
You are kidding right? It weighs 200g and can easily fit in the palm of your hand. You could walk around with this lens all year and be ok.
 Pic Man's gear list:Pic Man's gear list
Fujifilm X100T
FrankS009
In reply to Pic Man, Jan 29, 2014
For comparative purposes, as noted, the weight of the PL25mm 1.4 is 200g. The weight of the new Olympus 25mm is 136g. The Panasonic 20mm II is 80g.
F.
Pic Man
F.
Thanks for the comparison and even though the other lenses are lighter 200g is still not heavy. The difference is only 64g between the two 25's. I don't think 64g is really a consideration when purchasing a lens and I would find it hard to believe I'm in the minority here.
Fujifilm X100T
Lux Painter
Junior MemberPosts: 49
No chance in hell that I'd pay $400/€400 for a 50mm f1.8 lens.
Jim Salvas
Veteran MemberPosts: 3,451Gear list
If they kit this with a body for $200 above the body-only price, it would be worthwhile. Otherwise, what is the justification for paying the same amount as for the 45/1.8?
Certainly, if you already have the 12-40 zoom, this is superfluous. It's not small. It's not cheap. And it's not all that fast.
Jim Salvas
 Jim Salvas's gear list:Jim Salvas's gear list
Olympus PEN E-PM2 Olympus E-M1 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Samyang 7.5mm F3.5 UMC Fisheye MFT +7 more
FrankS009
I agree personally.
F.
Iskender
Senior MemberPosts: 1,328
I can understand it if you're counting out the fully-mechanical f/0.95 Voigtländers. However, even ignoring those f/1.4 isn't exactly the fastest aperture anymore...
mh2000
Pic Man wrote:
mh2000 wrote:
peppermonkey wrote:
lnikj wrote:
Which I have done
ETA March 7th.
Hubert
BAck when I was shooting Canon, people would argue with me about my 24-70L being too heavy as well. Everything is relative.
I really wanted a 25 that came in more similar to the P14 or O17/2.8.
My hope now is that Panasonic will release a little 25/2.8 pancake for the GM1!
Hey, it could happen!
petersolymosi
Regular MemberPosts: 218Gear list
You're not in the minority. The PL25 is my go-to lens and almost always mounted on my E-PL5. It is not heavy or large by any means.
Pete
 petersolymosi's gear list:petersolymosi's gear list
Olympus PEN E-PL5 Olympus OM-D E-M10 Olympus E-M5 II Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +9 more
baxters
Veteran MemberPosts: 4,449Gear list
In reply to Jim Salvas, Jan 29, 2014
Olympus does likes to hike up the margins for their US pricing.
By the end of the year I expect, this lens will be selling for $300 (just like the 45mm) on ebay from Japanese sellers, who are still making a decent profit after paying Paypal/Ebay $45.
 baxters's gear list:baxters's gear list
Sony Cyber-shot DSC-QX10
Steve_
Senior MemberPosts: 2,173Gear list
I've got the Panasonic 25/1.4, and as much as I like it should the new Oly deliver roughly the same optical goods the small size is attractive enough for me to consider switching. Smaller lenses means I can carry and use more of them, and that's the primary attraction of the m43 system for me.
The 12-35 and 35-100 Panasonics are terrific, and once you start carrying them the primes need to be small or I'll leave them at home. The 14 Panny, 25/1.8 Oly, and 45/1.8 Oly are about all the primes I'm likely to cart about on top of the 7-14/12-35/35-100 trinity. As stellar as the 75 Oly is, It's already riding the pine now that I have the 35-100. Ultimate optical excellence may keep me from selling the 75 (or 25/1.4), but not reserve a consistent spot in my carry bag.
 Steve_'s gear list:Steve_'s gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G 14mm F2.5 ASPH Panasonic Leica Summilux DG 25mm F1.4 +7 more
