Em-1 Noise in Low ISO, Low light shots.
Started Jan 29, 2014 | Discussions
LTZ470
Forum ProPosts: 11,926Gear list
Re: Em-1 Noise in Low ISO, Low light shots.
In reply to TangoR, Jan 30, 2014
I always bracket shots like this to give me a choice of exposures...
--Really there is a God...and He loves you..
FlickR Photostream:
www.flickr.com/photos/46756347@N08/
Mr Ichiro Kitao, I support the call to upgrade the FZ50.
I will not only buy one but two no questions asked...
TangoR
TangoR OP
Junior MemberPosts: 46
Re: There is a pattern....
In reply to Gravi, Jan 30, 2014
Gravi wrote:
LaMesa wrote:
...which is very evenly distributed over the whole picture, bright or dark, contrasty or not - it is everywhere. This pattern is not or not only noise, but is very likely a characteristic of this RAW-conversion.
Herbert
Yes, its called over-sharpening
Gravi
The second photo I posted that claimed to not have any sharpening did in fact have some as a part of my default work flow that I didn't realize. The Original image (straight form Raw) did not and the final image did not. (unchecked Sharpning in Aperture)
Gianluca Grossi
Forum MemberPosts: 85Gear list
Re: I looked...
In reply to knickerhawk, Jan 30, 2014
knickerhawk wrote:
Gianluca Grossi wrote:
I use PN from one year and I can trusty say that it can do an unbelievable work in supressing luminance noise while maintaing a lots of detail, much much more of Aperture and LR that I own.
Until you use it (with the right setting), you can't understand what this program is capable of doing.
It uses the Noise Ninja noise reduction engine, which I've used. I understand perfectly well what you're talking about but even as good as Photo (Noise) Ninja might be at handling noise, it's never as good as starting with a properly exposed and noise-free file. The only time a better noise reduction strategy is the correct answer to give somebody who's got a problem with creating noisy images is when the exposure is optimized to begin with and the raw files produced by the camera still include unacceptable amounts of noise.
pls take a look at the pics I post...
I looked at your LR and PN comparison street shot. There are obvious problems with processing options selected with Photo Ninja, probably related in part to your more aggressive noise suppression and sharpening settings and in part to the demosaic algorithm utilized by PN. Look at the pavement to the left of the "Macelleria" sign. The more aggressive noise suppression in the PN has rubbed out texture in the pavement bricks and given them a plasticky look. Moreover, there is obvious maize moire in the pavement. It's quite clear as you look "up" the sidewalk. This moire is not present in the LR version, so it didn't "originate" in the raw file. Rather, it was introduced by some combination of the PN demosaic engine and/or your settings in PN and it's the sort of problem you sometimes see when aggressive demosaic/sharpening strategies are used. There are other tradeoff issues in the PN version as well, but these examples should suffice to reinforce the point that there are no magic bullets and no substitute for getting exposure right in the first place.
probably I used to much sharpening, but to me this conversion is way head the LR and the downside are really really minor to me(moire easily suppressed in LR) and the brick on the pavement are very underexpose and again PN does a great job to recover them and to my eyes doesn't look plastic at all. What I know for sure that no other program could have done it better...or you can contradict me?
By the way, in case you didn't know, Iliah Borg, who responded in this thread, has been involved in the development of raw processing tools for many years. You should pay attention to what he's trying to explain to you. Some of us who've been hanging around DPReview for a long time have learned a lot from him.
 Gianluca Grossi's gear list:Gianluca Grossi's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G 14mm F2.5 ASPH Samyang 7.5mm F3.5 UMC Fisheye MFT Panasonic Leica Summilux DG 25mm F1.4 +1 more
Gianluca Grossi
In reply to RGiskard, Jan 30, 2014
I suggest you Lightroom, (but you have to tweak the sharpness/noise default value )
Do you have any suggestions for adjustments to these defaults in LR? I'm new to the EM-1 and would appreciate your thoughts. Thanks!
Try these setting from base iso and up to 1600
( you can always tweak them to your preference):
Sharpening
Amount:10
Radius:0,5
detail:25
Masking:0
N.Reduction
Luminance:13
L.Detail:50
L.contrast:0
Color:25
C.detail:50
knickerhawk
Veteran MemberPosts: 4,345
Re: I looked...
In reply to Gianluca Grossi, Jan 30, 2014
Depends on what you mean by "better".  As already noted, the PN version suffers from visible moire that isn't present at all in the LN version.  That's certainly not better to me.  The more plastic look caused by stronger noise reduction in the PN version shows up in other places in the image as well as the pavement.  For instance, take a look at the concrete pole to the right of the bicycle rider.  Half way up, the pole looks like somebody smudged it with greasy fingers.  The LN version isn't perfect, but it's somewhat less obvious.  The downside of strong noise reduction tends not to show up as prominently in scenes dominated by man made stuff.  Nature shots and portraits are better tests of the effectiveness of noise reduction tools than a shot like this one.
Regarding other elements of "better," the PN rendering has turned the highlighted buildings on the right side a sickly yellow and has blown a lot more detail than the LN version.  Highlight rendering is important to me, and the PN fails compared to the LN version in that regard (at least for this one comparison). The clouds in the upper sky in the PN version look false to me.  They're too green and the tonal transition between cloud and sky is not handled as well in the PN version (the LN version is probably a bit too red though).  The color problems in each could probably be corrected.  The strong contrast between sky and tree branches shows more CA in the PN version.  Again, this is probably correctable.
Indeed, there is far less luminance noise in the PN version, but it clearly has not come cost-free.  If noise reduction is a higher priority to you than other things, then I can understand why you're so happy with PN.
Gianluca Grossi
Re: I looked...
My intent was to show how can PN can handle noise. I know that the Highlight are overexposed but IU just push the exposure by 2 stop without recover the highlight.
Probably we see things in different way but to my eyes PN easily win..
Here are the 2 version well exposed:
this is LR:
and this is the PN version:
oluv
Senior MemberPosts: 1,972Gear list
Great shot, but...
...i see another problem. The shot is not sharp at all. Not due to missing sharpening but I see a shutter-shock problem here. There is vertical blurring visible. Which lens did you use by the way?
 oluv's gear list:oluv's gear list
Panasonic Lumix DMC-GM1 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +1 more
jimkahnw
Regular MemberPosts: 104Gear list
Looks like JPG compression artifacts, not noise typical of high ISO or underexposure. It's unlikely the artifacts would be visible at normal viewing distance in any size print. And no problem at all in smaller sizes and for web.
If you insist on peeping the pixels, shoot RAW, or as stated elsewhere on this thread, use the Olympus Viewer 3, though it's hardly the production tool of Lightroom or similar RAW processors.
JimK
 jimkahnw's gear list:jimkahnw's gear list
Olympus E-M1 Olympus OM-D E-M10
knickerhawk
Re: I looked...
You pushed two stops to better show the strengths of PN with respect to noise handling. Fair enough...but only as long as you are willing to consider the other implications of a two-stop adjustment as well. Otherwise, the demonstration of purported improvements in noise is useless. Noise suppression, sharpening, moire, contrast, color, etc. all interact.  Change one and you're very likely to affect the others (and often in a detrimental way).
And just as you could have tweaked PN to reduce some of the problems I pointed out to you, I'm confident I could have tweaked the LR version to reduce the luminance noise it displayed. It cuts both ways and ultimately involves a careful balancing of trade-offs when selecting/using/adjusting raw processors and related tools.
I appreciate your efforts here. You've illustrated your argument with sample images. That's a lot more than most of us bother to do when we engage in our back-and-forth here!
Yes, I think that's a good way to wrap things up.  Unlikely either one of us is going to be swayed further.
Ciao
Michael Jardine
Senior MemberPosts: 1,432Gear list
Re: Good point
In reply to Sourze, Jan 30, 2014
Sourze wrote:
I borrowed a D800 once.. It's got an amazing sensor and when viewing images at normal size (not 100 %) I see less noice than from my E-M5... too bad it's got the size and weight of a bowling ball though.
This is off-topic, but since you mentioned it, it's worth mentioning that the size difference is not all that big, when you get down to it.  For example, I bought a relatively small ThinkTank sling bag, the "Turnstyle 10", for my E-M1.  It holds the camera with 12-40 zoom, 75mm 1.8, and flash - all unobtrusively.  Guess what else fits in the same small sling? My D800 with 24-85 zoom, plus 16-35 f/4 zoom.
Still, since dipping my toes into the M43 water just a year ago, I haven't taken my D800 on one international trip and bout 80% of my photos are with M43...
Michael
www.Qamera.com
www.Qamera.Tumblr.com
www.Pinterest.com/Qamera
 Michael Jardine's gear list:Michael Jardine's gear list
Nikon D800 Olympus E-M1 Olympus E-M5 II Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 16-35mm F4G ED VR +11 more
TangoR
TangoR OP
In reply to TangoR, Jan 31, 2014
So this thread is done. All my questions have been answered.
The take away is.
1. ETTR. Do not underexpose when there are darker areas. This will lead to the fine pattern noise.
2. This is not a bad thing.
3. People Seems to (for the life of me) prefer noise removal. I don't get it. Noise removal makes your photos look like iPhone 5 photos. Try shooting with no noise removal. I think you will be pleasantly surprised.
4. NO there is no shutter shock(in my camera at least). That issue should be dead. and Please do not use My photos as an example of Shutter shock and no I will no repeat the photos with some setting.
Thanks Guys!
happy clicking.
Gianluca Grossi
Re: I looked...
In reply to knickerhawk, Jan 31, 2014
Ciao!
lancespring
Veteran MemberPosts: 3,730Gear list
You really did a terrible job with this exposure
The amount you underexposed was quite excessive, and certainly contributed to the amount of noise in the photo. You need to keep in mind that when photographing white subjects like clouds, one has to actually INCREASE exposure OVER what the camera's meter recommends. And that is because white subjects reflect more light than your average scene. And your camera's meter thus gets tricked into believing that there is much more light than there really is. It consequently becomes necessary to increase exposure ABOVE what your camera recommends, in order to get a good picture.
Secondly, all of the white clouds also threw off the camera for coming up with a correct color balance too. That needed to be adjusted as well. Your photo is way too cool in color temperature.
Since when have you ever seen blue colored fog? Your photo could hardly look more unnatural in color.
 lancespring's gear list:lancespring's gear list
Sony Cyber-shot DSC-RX10 Nikon D600 Sony a6000 +1 more
yslee1
Regular MemberPosts: 495
The one thing you should be taking away is that you have some rather unrealistic expectations. A D800 shot in similar conditions will exhibit similar noise pattern. It just looks finer when viewed because there's 36 megapixels of info to spread that same amount of noise.
TangoR
TangoR OP
Re: You really did a terrible job with this exposure
In reply to lancespring, Jan 31, 2014
Yea I see now I way underexposed. However the fog did have an almost blueish cast to it. The original is not processed in any way.
Michael Jardine
In reply to yslee1, Jan 31, 2014
Agree.  Although I would say "to absorb" rather than "to spread around" the noise
Michael
www.Qamera.com
SaltLakeGuy
Forum ProPosts: 11,136Gear list
Yeah I think these shutter shock fanatics
need to get their eyes fixed. I'm so dang sick and tired of hearing the excuses for their inabilities to stabilize their cameras and lenses.
 SaltLakeGuy's gear list:SaltLakeGuy's gear list
Sony Alpha 7R II Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sony FE 70-200 F4 Sony FE 24-70mm F2.8 GM +2 more
TangoR
TangoR OP
Re: Yeah I think these shutter shock fanatics
In reply to SaltLakeGuy, Jan 31, 2014
I infact have the BEST example of NO shutter shock. People seem to be looking at my photo and seeing some "ghosting" on the top of the bridge and yelling "Shutter shock".
Wanna know the truth :-D.
What you see are actually thin guide lines on top of the bridge. They run the length of the Bridge and are hard to make out even when you are close to the bridge. So unless EM-1 has a selective "Only bridge and not Buildings" type of Shutter shock. I think My photo is an example of the detail you can get from the EM-1 sans the AA filter and should lay to read any Shutter shock fears.
Im attaching My photo at 100% crop and a stock photo of what you see. I seriously cannot believe my little EM-1 resolved those things!!! Im still in awe.
JF69
Contributing MemberPosts: 740Gear list
Thanks Iliah
In reply to Iliah Borg, Feb 1, 2014
much more readig to catch up!
Usually I'm wary & skeptic of anyone selling seminars, advice, actions & all that stuff; as a working pro in a small economy I'm more interested in what really, really works (= produces tangible differences in the client's end product, differences that the client can indeed appreciate)  in the least amount of time;
but Dan seems to be on another level altogether.
I've installed his actions (the PPW Panel won't install for some reason) & catching up on some tutorials.
Thanks once again.
 JF69's gear list:JF69's gear list
Nikon D610 Fujifilm FinePix S5 Pro Nikon AF Nikkor 85mm f/1.4D Carl Zeiss Makro-Planar T* 2/50 Carl Zeiss Makro-Planar T* 2/100 +8 more
Iliah Borg
Forum ProPosts: 19,031
Re: Thanks Iliah
In reply to JF69, Feb 1, 2014
Right. Dan is one of the very few exceptions. He teaches to observe and understand the image to be corrected. It is quite unique.
