E-M5 Firmware update... V 2.0 today..
Started Jan 29, 2014 | Discussions
Ethan637372
Ethan637372 Junior Member • Posts: 38
Re: ETTR ISO 100
just a question for everyone, since ISO 100 might be an overexposed ISO 200, can I still use the blinkies in ISO100 to not clip, are the blinkies still accurate?
 Ethan637372's gear list:Ethan637372's gear list
Olympus OM-D E-M5 Sony Alpha 7 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Leica Summilux DG 25mm F1.4 Voigtlander Nokton 17.5mm F0.95 Aspherical +2 more
texinwien
texinwien Senior Member • Posts: 3,320
Exactly
Iliah Borg wrote:
The dpreview of the E-M1 indicated that there was less highlight detail at ISO 100. Their graphs also indicate this. (scroll down to the end of this page).
It is from processed images, not from the raw data. To decide how the midtone placed in the raw one needs to operate directly on the raw data, without any tone curves that a converter applies. The difference between ISO 100 and ISO 200 settings is just the placing of the midtone - 1 stop higher for ISO 100. Means the headroom in highlights for ISO 100 is 1 stop less. You can easily determine the exact number yourself by shooting some evenly lit surface out of focus while allowing the exposure meter to set the exposure; and looking at the placement of the histogram peak in raw data
And as we know from tests performed by DXOMark and others, the E-M5's base sensor saturation ISO is ~107, which means that ISO LOW on this camera is likely to be a camera ISO of ~100 with a saturation ISO of ~100 and no (significant) loss of RAW DR.
 texinwien's gear list:texinwien's gear list
Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus 12-40mm F2.8 OnePlus One Canon EOS 300D +20 more
Thomas Niemann
Thomas Niemann Veteran Member • Posts: 4,333
Re: Exactly
I see two statements and am having difficulty reconciling the two.
"the headroom in highlights for ISO 100 is 1 stop less"
"no (significant) loss of RAW DR"
Can someone help me out here?
Iliah Borg
Iliah Borg Forum Pro • Posts: 19,037
Re: Exactly
Some loss in highlights, some gain in shadows. There is no such thing as "DR in highlights", only headroom. DR is an integral metrics.
Anders W
Anders W Forum Pro • Posts: 21,465
Re: ETTR ISO 100
I just checked and the answer is yes. The highlight "blinkies" turn on at the same exposure (same f-stop and shutter speed) at the LOW (ISO 100) setting as at ISO 200, as should be the case if they are working as they should.
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +28 more
brycesteiner
brycesteiner Senior Member • Posts: 1,550
Re: The graphs are for JPEGs, not RAW
Have you actually compared two different raw files with the same exposure but one set at low and the other set at iso 200 ?
This setting has been there all along but most of you never encountered it
What do you mean? I've never had LOW setting available until the update.
Make it a Great day!
 brycesteiner's gear list:brycesteiner's gear list
Olympus E-510 Olympus E-30 Olympus OM-D E-M5 Olympus E-M5 II Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 +6 more
Alien from Mars
Alien from Mars Regular Member • Posts: 470
Re: E-M5 Firmware update... V 2.0 today..
It's nice to have that small focus area, that's true. But whenever I tap the screen to select a focus point it brings up rectangular focus area (smallest available before 2.0 FW), not tiny square focus zone. Is there a way to have this new small square focus area at selected location when you tap screen to focus?
 Alien from Mars's gear list:Alien from Mars's gear list
Panasonic Lumix DMC-GX1 Olympus OM-D E-M5 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +2 more
Thomas Niemann
Re: ETTR ISO 100
Different results here. Should point out that shooting muted with all the "jpeg" options set to -2.
Anders W
Re: ETTR ISO 100
Different results here:
Not for the highlights, which is what the question was about. For the shadow warnings, where there is no fixed clipping point, it is to be expected that there is a difference in the direction your samples indicate.
Thomas Niemann
Re: ETTR ISO 100
The highlights are different. Look at the lamp shade.
