E-M5 Firmware update... V 2.0 today..
Started Jan 29, 2014 | Discussions
Anders W Forum Pro • Posts: 21,465
Re: Lenses too
Art_P wrote:
My 12-50 got an update too, and the 45 (I think... I lost track which lens got the update after going through all my lenses)
The update for the 12-50 (which I don't have) was released November 28 2013 and that for the 45 (which I do have) on September 19 2013 so neither is brand new. But thanks for the heads-up anyway.
The update for the 45 appears to be relevant only for users of certain Pany bodies (GF6, G6, GH3) but I might want to get it done nevertheless.
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +28 more
Re: Hurray!!!
Steen Bay wrote:
Anders W wrote:
kenw wrote:
These were two things I had wanted on the E-M5 - so glad they added them. Smaller point focus desired for shallow DoF portraits and for much of my landscape shooting I end up over exposing ISO200 already and will be glad to have the extended ISO100 to do it for me (or at least start out closer).
Hi Ken,
Long time no see. Glad to see you around.
But as to the ISO 100: Why would you even want to use that as a RAW shooter? Surely, all the ISO 100 setting does is to alter the metering and the tone curve of the OOC jpegs. The clipping point in RAW stays unchanged and if you go by the live-view "blinkies" when setting exposure, as I do, there is no difference between ISO 100 and ISO 200.
If shooting mid/low contrast scenes/subjects (using ETTR), won't ISO 100 then give a less 'washed out' live-view image in the EVF and more natural looking JPEGs?
Yes, it would, and that may possibly be an advantage with regard to in-camera review even for a RAW shooter at times. On the other hand, high-contrast scenes will now come out looking more "underexposed" than they would at ISO 200 so it is a mixed blessing (unless you take the trouble to switch between 100 and 200 depending on the contrast of the scene).
Another little problem with the "fake" ISO 100 setting is that it makes things inconsistent across ISOs. If I ETTR at ISO 400 (which makes sense on the E-M5 when you can't saturate the sensor at ISO 100/200), things will look different in terms of brightness than if I ETTR the same scene at ISO 100. Staying with the regular ISOs makes things consistent in that regard.
Small focus box without having to change to zoom-frame AF: Well, I am just as happy to have that as you are. This was at the very top of my list of things to be fixed.
There is of course a long list of other things I want to - but these were near the top of the list and there will always be another feature for me to be annoyed by (AEB Fn access - argh!).
As to focus peaking I may be remembering wrong but I thought at some point in the past some one from Olympus had said in an interview that appropriate processing and hardware resources were needed to effectively implement focus peaking and so it might not be practical to do on older models. It was a long time ago and I might be confusing this with a Panasonic interview on the G/GH series cameras instead.
Personally I've tried focus peaking on a few cameras and didn't find it useful, but since I didn't own those cameras and couldn't use it for long enough it is quite possible I just was familiar enough with the implementation to use it effectively.
Ken W
See profile for equipment list
giaccophoto Forum Member • Posts: 73
Re: E-M5 Firmware update... V 2.0 today..
Christophotog wrote:
Just updated my E-M5 to V 2.0 which was released today.
Small A/F point was added which shows a 5 x 7 matrix of small focus points.
LOW ISO extension also added.
Those were the release note items and there is no sign of other unannounced additions that I can see (yet).
Chris
Is the setting of the small focus point kept in camera when you turn it off and back on again or needs to be selected everytime?
I'd like to have the small focus point all the time as I turn the camera on without selecting it everytime. Thanks
 giaccophoto's gear list:giaccophoto's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ
Art_P
Art_P Veteran Member • Posts: 9,864
FP stays as you set it
small or normal.  no resetting every time you power up
Art P
"I am a creature of contrast,
of light and shadow.
I live where the two play together,
I thrive on the conflict"
 Art_P's gear list:Art_P's gear list
Olympus E-M1 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +2 more
Steen Bay Veteran Member • Posts: 6,959
Re: Hurray!!!
Anders W wrote:
Steen Bay wrote:
Anders W wrote:
Hi Ken,
Yes, a bit confusing if the tone curve and amount of headroom vary at different ISOs. And btw, maybe you could check whether ISO 100 actually is a 'fake' ISO. Would be very surprising if it isn't, but don't think that anybody has checked it yet.
Ken W
Art_P
Interetsting...
Was sure I had checked my lenses more recently than that.
But now that I think of it... probably haven't checked since September.... before my trip to Scotland.
Art P
Corkcampbell
Corkcampbell Forum Pro • Posts: 14,880
Thanks for that tip, and here's the link to the Oly lens FW
current versions and upgrade dates. Now, I'm gonna have to check my Pany and Sigma lenses...
http://www.olympus.co.jp/en/support/imsg/digicamera/download/software/firm/e1/
"Knowledge is good." Emil Faber
 Corkcampbell's gear list:Corkcampbell's gear list
Sigma DP2 Merrill Sony Cyber-shot DSC-RX10 Sony Cyber-shot DSC-RX100 III Panasonic Lumix DMC-GH3 Olympus E-M5 II +3 more
photofan1986 Senior Member • Posts: 2,774
I'm a bit sorry that they did not include the flicker reduction menu like in my E-PM2. Set to off, it completely takes care of the "rattlesnake" sound coming from some lenses. I sent an email to Olympus a couple of months ago about this, and they told me that they have no plan upgrading the firmware. Well, finally they did (thank you), but they did not listen...
Oh well, guess we may still be happy anyway.
 photofan1986's gear list:photofan1986's gear list
Canon PowerShot S100 Fujifilm FinePix F200EXR Panasonic Lumix DMC-GM1 Olympus E-M1 Olympus M.Zuiko Digital 45mm F1.8 +7 more
Jake21 Contributing Member • Posts: 523
Does this firmware upgrade reset the camera like all other firmware upgrads ?
Is there an easy way to electronically save and restore camera settings ?
No, the camera settings will not be reset.
toporossa Regular Member • Posts: 125
Focus peaking soon to come?
As someone posted on 43rumors, there is an E-M10 review that says:
"E-M5 owners should note that a firmware update is on the way to enable focus peaking, bringing the original OM-D more in line with its new baby brother"
http://cameras.reviewed.com/content/olympus-om-d-e-m10-digital-camera-review
Interesting since today's firmware update doesn't seem to enable focus peaking..…maybe they cancelled it in the last minute? Or it is a somewhat hidden feature, undetected by the upgraders? Or will it come in a second update for technical reasons?
Corkcampbell
I don't remember my earlier FW upgrades resetting my cameras. (nt)
no text
FranLopez Junior Member • Posts: 49
Whit ISO 100, do I´ll still need ND filters to shoot PL 25 and OLY 75, wide open in bright light??
What do you think?
OM-D EM-5
OLY 12mm F2.0 BLACK / PL SUMMILUX 25mm F1.4 / OLY 75mm F1.8 BLACK / CANON FD 200mm F2.8
OLY 12-50mm F3.5-6.3
and a FUJI X100 BLACK EDITION....
 FranLopez's gear list:FranLopez's gear list
Nikon Df Nikon AF Nikkor 50mm f/1.4D Nikon AF Nikkor 180mm f/2.8D ED-IF Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR Voigtlander 20mm F3.5 Color Skopar SL II +2 more
What do you think?
OM-D EM-5
I think it depends on what you mean with "bright light"
But beware that the DR is reduce when shooting at 100 ISO.
bahamot
bahamot Contributing Member • Posts: 516
Is it just me, or the new firmware also improved the AF in low light a bit?
 bahamot's gear list:bahamot's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Panasonic Leica Summilux DG 25mm F1.4 +6 more
Re: Hurray!!!
Steen Bay wrote:
Anders W wrote:
Steen Bay wrote:
Anders W wrote:
Hi Ken,
OK. I'll try to get that done (although I'd be extremely surprised if it weren't fake).
Ken W
Michael J Davis
Michael J Davis Senior Member • Posts: 2,971
Re: Hurray!!!
Anders W wrote:
Hi Ken,
me 2.
Dead right, Anders!
The new box is smaller than the 14x that I've been using up to now. And a quick check in this dim office suggests that focussing - even with the 20mm f1.7 - is more positive (i.e. less hunting) for instance on my black keyboard at 1.3sec f1.7 ISO200.
Could also be very useful for the BIF contingent!
(eg: http://www.flickr.com/photos/watchman/9218087590/ )
Mike
Mike Davis
Photographing the public for over 50 years
 Michael J Davis's gear list:Michael J Davis's gear list
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 7-14mm F4 ASPH +3 more
Re: Hurray!!!
Michael J Davis wrote:
Anders W wrote:
Hi Ken,
me 2.
Dead right, Anders!
Absolutely Mike. The bigger focus box with standard AF (and the need to switch over to zoom-frame AF to get a smaller one) was one of very few areas where I felt I downgraded when I went from the Pany G1 to the Oly E-M5. Glad to be back to "normalcy" in this regard.
murfthesurf Contributing Member • Posts: 634
Re: Crybaby (nt)
Some people are never happy.
I want my E-M5 to make me a vodka tonic when I get home from work.  I thinks it's a downright sin that it doesn't already have that feature.  I hope that will be available in v 2.1...
- Murf
 murfthesurf's gear list:murfthesurf's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm 1:1.8 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +4 more
cmorse Contributing Member • Posts: 503
Re: Focus peaking soon to come?
I thought Olympus said that the E-M5's processor couldn't handle focus peaking.
 cmorse's gear list:cmorse's gear list
Olympus OM-D E-M5 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko Digital 45mm F1.8 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 +4 more
