E-M5 Firmware update... V 2.0 today..
Started Jan 29, 2014 | Discussions
Christophotog OP Forum Member • Posts: 66
Re: Great!
Jasonmon wrote:
Still no focus peaking?
My Speak Art blog.
No... I looked under AF/MF menu and the only focus assist option is still MAGNIFY
 Christophotog's gear list:Christophotog's gear list
Olympus OM-D E-M5 Olympus E-M5 II Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +4 more
Re: E-M5 Firmware update... V 2.0 today..
baxters wrote:
To select the small target via SCP:
-bring up the SCP
-highlight the focus box and press OK
-press INFO.
Now you can use either the rearmost dial or up/down arrow buttons to cycle thru the focus box choices. The left/right arrows or frontmost dial cycle thru face detect modes.
OK. I selected small target box and get it when it locks focus. But I use touch screen to position the focus box, I get the big target box. Anyone care to explain?
I can see that too.. But I also just tested the same process on my E-M1 and guess what! It does the same thing. Small square focus-point when using the half-press or EVF but large square focus point when using touch focus.
CJ
mchnz Contributing Member • Posts: 570
Sourze wrote:
Whoah! Fantastic news
With access to lower ISO, does this mean we can also expect a slightly higher dynamic range?
It's marked as an "extension" ISO setting - like the very high ones.  It's only simulated in firmware to make it easier to use fast lenses in bight daylight.  DR will likely be down a bit.  The E-P5 does this, so E-P5 users would have a feel for it.
 mchnz's gear list:mchnz's gear list
Olympus E-M5 II
Jasonmon Forum Member • Posts: 60
Re: Great!
Christophotog wrote:
My Speak Art blog.
Not fair... em10, em1 & ep5 has focus peaking. and EM10 is considered as the lower end model of the OMD.
My Speak Art blog.
 Jasonmon's gear list:Jasonmon's gear list
Canon EOS 60D Olympus OM-D E-M5 Canon EF 50mm f/1.8 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Canon EF-S 18-55mm f/3.5-5.6 IS +4 more
Sergey Borachev Senior Member • Posts: 3,295
Hallelujah!
I hope this means that Olympus does monitor this forum and has heard the numerous complaints about the lack of updates to provide features that have long be available on lower models like the E-PL5 etc.
Let's hope there will be a V 2.1 soon with Focus Peaking.
Olfdee Regular Member • Posts: 120
This update is a joke.
It makes E-M5 the most retarded function-wise camera in the whole lineup, missing features already introduced (so readily available as source code) on other Oly cameras:
- custom self timer
- auto IS option
- time lapse counter
- adjustable direction of both dials
- focus peaking
as well as it doesn't fix flaws present from the very beginning, like option to assign quick access to bracketing settings to any of Fn buttons.
I'm sure there are other things missing and and I'm not even trying to point to ideas offered by competition...
If this, plus option to buy more expensive kit is all Olympus has to offer to keep E-M5 alive for another year (at least) then well... RIP.
 Olfdee's gear list:Olfdee's gear list
Panasonic Lumix DMC-ZS3 Panasonic Lumix DMC-FZ1000 Nikon 1 V1 Olympus PEN E-PM2 Olympus E-M1 +4 more
duartix Veteran Member • Posts: 3,568
As others have said before me, NO.
This should be looked at as if it was a JPEG effect. The base ISO on the camera is still 200, which means that this is nothing more than ISO 200 overexposed by 1 stop.
RAW DR will likely be lower, because the camera will expose more to the right (possibly over the point of clipping) and will leave you with less headroom for recovery of highlights.
Duarte Bruno
 duartix's gear list:duartix's gear list
Fujifilm FinePix F40fd Olympus PEN E-P1 Panasonic Lumix DMC-GH2 Olympus M.Zuiko Digital ED 14-42mm 1:3.5-5.6 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS +4 more
stefano888
stefano888 Senior Member • Posts: 1,010
WOW!!! I like very much the 100 iso thing!
Thank you!
(equipment in profile)
stefano-italy
 stefano888's gear list:stefano888's gear list
Olympus E-620 Olympus OM-D E-M5 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Olympus Zuiko Digital ED 8mm 1:3.5 Fisheye +8 more
ApertureAcolyte
ApertureAcolyte Contributing Member • Posts: 994
Crybaby (nt)
- custom self timer
- auto IS option
- focus peaking
 ApertureAcolyte's gear list:ApertureAcolyte's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GH4 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm 1:1.8 +1 more
Pixnat2
Pixnat2 Veteran Member • Posts: 3,815
Re: Great!
My Speak Art blog.
My Speak Art blog.
Focus peaking isn't terribly well implemented nor useful in the E-M1. You don't miss a lot.
Olympus should rework this feature to make it fully useable. But that's not a must IMHO.
 Pixnat2's gear list:Pixnat2's gear list
Canon PowerShot G7 X Olympus PEN E-P1 Panasonic Lumix DMC-GH2 Fujifilm X-E2 Fujifilm X-T1 +1 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 23,395
LCD touch AF uses Magnify box
-bring up the SCP
-press INFO.
CJ
Use Magnify - Info to twiddle the box down to 14x size then the touch focus uses that 14x box. It works that way on my E-PL5.
Regular shutter button AF uses the small box if selected, the screen uses the Magnify box whatever size that was set to.
Regards...... Guy
Olympus PEN E-PL5 Olympus PEN E-P5 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Olympus 12-40mm F2.8 Panasonic Lumix DMC-LX3 +19 more
AndyPalf Forum Member • Posts: 88
Re: This update is a joke.
I don't have my E-M5 in front of me as I'm at work, but I thought that you could already change the direction of the 2 control dials? I admit I haven't done it as I was happy with the default direction though.
Great about the firmware. Sorry to sound like a noob idiot but, will this lower ISO equate to genuinely lower ISO or some form of software wizardry that attempts to cheat better IQ at base ISO? i.e. will there be a difference between the previous ISO200 and the new ISO100?
 AndyPalf's gear list:AndyPalf's gear list
Olympus PEN E-PL2 Olympus OM-D E-M5 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +2 more
Ulfric M Douglas Veteran Member • Posts: 4,533
LOW ISO extension also added....
?? Seriously ??
I'm in the hunt for a used E-M5 if that's the case!
Maybe you Christo could test something for me?
Cheksa wrote:
You're evil Ulfric.
Heyseuss Hoolio
Heyseuss Hoolio Contributing Member • Posts: 570
Duarte Bruno
Can someone explain the updates more clearly? Maybe I'm just not understanding it completely.
I don't get the concept of the "overexposed" ISO200 by 1 stop. Wouldn't that mean it looks like ISO400?
And the smaller focus box, is it smaller than the 14x you can already set for the AF focus point, as well as the 14x magnification? Does it just change the autofocus area to smaller boxes covering the same AF area as before?
And how about some examples showing the differences with the ISO100 and ISO200, with subsequent edits where you bring down overexposed highlights or bring up underexposed shadows in each to see which holds up better.
Thomas Niemann Veteran Member • Posts: 4,333
A few things explained
5
Two new features were included in the firmware update: ISO 100 and small focus points.
ISO 100. In the ISO menu you'll notice ISO 100 is marked as LOW and ISO 200 is Recommended. This indicates that ISO 100 is actually ISO 200 over-exposed by one stop. For example, if the ISO 200 exposure was 1/100 @ f/4, and you shot it at 1/50 instead, you would be over-exposing by one stop. And 1/50 @ f/4 would be the proper exposure for ISO 100. The result would be highlight clipping and less dynamic range because ISO 200 is the optimal ISO for the sensor. As a benefit, shadows would receive more exposure and, consequently, less noise.
Small focus points. To implement this feature, do the following:
1. Click the left arrow on the control wheel to bring up focus points
2. Click on the Info button
3. Click the up/down arrows on the control wheel to select a smaller focus point
A very nice addition!
Heyseuss Hoolio wrote:
duartix wrote:
I don't get the concept of the "overexposed" ISO200 by 1 stop. Wouldn't that mean it looks like ISO400?...
A RAW file at ISO200, overexposed by 1 stop looks like an overexposed ISO200 RAW file,
BUT
A 'fake' ISO100 Jpeg will be that same overexposed ISO200 RAW file but using the darker end of the exposure information ... making it look correctly exposed for ISO100.
I use it all the time in daylight with my older Olympii.
Cheksa wrote:
You're evil Ulfric.
Heyseuss Hoolio
BUT
Cheksa wrote:
You're evil Ulfric.
Okay thanks for the answers to all that answered, I understand now how the overexposed ISO200 would be.
So...has this been verified what it actually does?  How does the new ISO100 RAW file look?  Does it look like an over exposed ISO200 file, or is the RAW file brought down in the camera then presented as a RAW ISO100 file?
reygon Senior Member • Posts: 2,035
Re: A few things explained
Thanks Thomas. The small focus point will be very useful!
reygon
Take nothing but photos... Kill nothing but time... Leave nothing but footprints...
texinwien Senior Member • Posts: 3,320
Incorrect
Kelpie wrote:
The base iso of the Em-5 is 200 highest dynamic range should remain there, I believe
The base ISO setting on the E-M5 is 200, but the actual (sensor saturation) base ISO (according to DXO) is 107.
We'll have to test it to be sure, but if it's anything like other recent models (GX7, E-M1, etc.), the new LOW setting will be like setting ISO 100 (or thereabouts) for an actual ISO of 107, so, not really an extended setting, and no loss of DR.
JPEG shooters will have to be more careful about clipping highlights, but they should still have just as much DR as the old ISO 200, assuming this LOW ISO setting is implemented like it has been in other recent m43 cameras.
 texinwien's gear list:texinwien's gear list
Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus 12-40mm F2.8 OnePlus One Canon EOS 300D +20 more
?? Seriously ??
Cheksa wrote:
You're evil Ulfric.
No, sorry, its night time here, LOW ISO isn't useful in the dark.
I don't know if it will be useful in the daylight either but I do know I haven't used f1.8 very often in bright light with shutter limitted @ 1/4000th without overexposing. CJ
