I wish it is possible...
Started Jan 28, 2014 | Discussions
Trevor G Veteran Member • Posts: 6,541
Re: I wish it is possible...
Kendall Helmstetter Gelner wrote:
so lets celebrate diversity instead of killing the camera company that dares not to travel in lock-step with the market.
I agree, but we also need improved functionality along with diversity.
Cheers
Trevor G
Silkypix tutorials at: http://photo.computerwyse.com
Re: Well well....
Aaro wrote:
HBowman wrote:
It is not doable as you say it
http://item.taobao.com/item.htm?spm=a1z10.1.4-7055923565.8.TFzxZQ&id=16897677837
Best
Aaro
Neat!
Looks like they do a great job at a reasonable price.
Cheers
Trevor G
Lord metroid
Lord metroid Regular Member • Posts: 474
Re: Well well....
But is it really better than the default lens?
 Lord metroid's gear list:Lord metroid's gear list
Sigma DP2s Sigma dp2 Quattro
Aaro
Aaro Senior Member • Posts: 2,748
Re: Well well....
It makes DPxx series bayonet camera, with a mount to your choice. Also it  is in many cases not a question better, but rather other merits like bokeh, color, contrast, availability, vignetting .. etc of the lenses.
Best
Aaro
'Simplicity is the ultimate sophistication'.
http://www.lumisoft.fi/gallery/albums/userpics/10001/thumb_IMG03387%7E0.jpg
 Aaro's gear list:Aaro's gear list
Sigma dp2 Quattro Sigma dp0 Quattro Sigma SD9 Sigma SD14 Sigma SD15 +1 more
Lord metroid
Re: Well well....
I wonder how well the camera will perform with the 50mm Noctilux lens.
Aaro
Images
There are several galleries that show different lenses connected. Also some images taken? with modified camera?
Site:
Site:
M42  mount.
But my sguare linguist is -something martian!
Best
Aaro
Richard Franiec
Richard Franiec OP Senior Member • Posts: 2,510
In other-words you are spreading rumors based on "your logic"?
They are not rumors, they are just what I am sure will happen. Rumor implies some possible connection with the source. My predictions are based on logic only.
I'm glad to see that King Solomon is still alive. Reminds me of the bait shop owner who responded to my buddy's question: "What depth the fish are biting today?" with: "Start deep, if the fish is not there, move to shallows."
The wisdom in your anecdote is obvious, my wisdom apparently less so since some seem dubious of it.
All I am saying, is that all factors combined it seems really, really really likely the next camera from Sigma is a revised SD-1 that will include Live View. It seems so obvious I don't see how you can twist logic or reality to produce any other result. It doesn't take any kind of special knowledge to reach that result, yet some ever so resistant to the startling clarity of this obvious next step.
Well, let me congratulate you again.
Thanks! Your acknowledgment of my inherent wisdom is really thanks enough though. Next time you can just take that into account early on and save both of us a lot of writing. I have better things to do.
I'm not sure what provoked you to respond to my thread from the get go. You can save yourself (and me) a lot of writing by doing what you have in mind: better things, whatever they are. Is "ignore button" still working?
 Richard Franiec's gear list:Richard Franiec's gear list
Sigma DP2 Merrill Canon PowerShot G7 X Canon EOS-1D Mark IV Canon EOS-1D X Canon EOS M +8 more
to put Foveon sensor in something like that:
Your thoughts?
I think it's already in something like that, but it could use Live View and much more processing power with greater buffering.  For a start...
Cheers
Trevor G
SigmaChrome Veteran Member • Posts: 8,030
Roland Karlsson wrote:
...snip...
Agree. I would probably buy a mirrorless camera with a Merrill sensor. One requirement would be though that it had an adapter for Pentax lenses.
So, in other words, you will never buy a Sigma camera 'cos the only camera that will ever have a Merrill sensor will be a Sigma -- and they will never provide a Pentax adapter.
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sony RX100 Sigma DP3 Merrill Sigma SD14 +14 more
Roland Karlsson Forum Pro • Posts: 24,554
It takes a very negative mind indeed to find that a great lens maker paired with an excellent sensor is a "problem".
Where did I write that?
I sense a straw man.
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony Cyber-shot DSC-RX100 III Pentax K-3 Pentax K-1 +12 more
I mean, I can use a Canon 17mm T/S lens on the SD/1 if I put my mind to it. I can use older PK lenses which exist in a vast assortment.
Can you really fit a Pentax lens to a Sigma SA mount?
Yes you can.
Three problems though
  1. You lose at the nearest focus distance as the SA mount has larger registration distance.
  2. It is not a 100% perfect fit. It is a little lose.
  3. You have to remove the aperture lever. This involves cutting away the lever protection and disassemble the lens to remove the actual lever, or cut that away also.
MoreorLess Veteran Member • Posts: 3,901
Lord metroid wrote:
I like the minimalist interface of the DP cameras. Everything I need is easily accessible without any superfluous or cumbersome design.
Tracking though menu's to change settings isn't cumbersome?
Re: Not the market
richard stone wrote:
The problem for Sigma is that it has to leapfrog current technology a bit because it produces cameras infrequently, and thus its offerings sometimes appear, in a short while, as if they have fallen behind, even if they continue to work quite well. The market demands new.
The "market" does not demand new. A handful of people do, amplified by the internet...
The Market buys or does not buy, and often continues to buy totally independent of what people claim a company "must" do with this or that product.
I assume you understood what he meant, even if you pretend not to.
When you have a new technology with a nearly unknown camera maker brand, then you do have to have something extra to draw attention. Good enough is then not good enough.
...snip...
I did not say that.
I was just talking about a mirror less camera. And currently I would not buy any mirror less camera if it did not have a good Pentax K adapter.
But maybe I would consider a Merrill sensor based mirror less if it only had a Canon or Nikon adapter.
Building a camera system upon SA mount would be quite painful also.
Richard Franiec
So much for your wisdom, logic and startling clarity of your prediction LOL:
http://www.dpreview.com/news/2014/02/10/sigma-unveils-radical-dp2-quattro-with-re-thought-19-6mp-foveon-sensor?utm_campaign=internal-link&utm_source=news-list&utm_medium=text&ref=title_0_0
No need to respond to this post. Save yourself some time to do some better things whatever they are.
DMillier Forum Pro • Posts: 19,092
LOL
