How do i edit this
Started Jan 28, 2014 | Discussions
isotope
Junior MemberPosts: 45
How do i edit this
Jan 28, 2014
Hi All,
How do i edit this picture. The foreground is way too dark and the background is way too light. I use LR 4.0. only. Its in RAW format.
Thanx for the help,
PTMD
Victor Engel
Forum ProPosts: 15,709Gear list
Re: How do i edit this
In reply to isotope, Jan 28, 2014
Highlights and shadows, aka, recovery and fill. However, the problem should have been caught during setup. The subject never should have been posed that way in the first place.
Victor Engel
 Victor Engel's gear list:Victor Engel's gear list
Canon EOS 600D Canon EF 50mm f/1.8 II Canon EF 135mm f/2.0L USM Canon EF 300mm f/4.0L IS USM Canon EF 100-400mm f/4.5-5.6L IS USM +7 more
mikes
Veteran MemberPosts: 3,160
Mask the area first, copy to a new layer, adjust exposure.......
Maask
sotope wrote:
Hi All,
Thanx for the help,
PTMD
Only when you can criticize yourself, should you criticize others. Mikes.
Saleen1999
Contributing MemberPosts: 940Gear list
Here is something I put together using LR and PS. I know you only have LR but I could help but use more. I used a good bit of it with the NIK software too.
Isotope and family.
Melissa aka mustang_fan
Adobe Photoshop CS6 extended
 Saleen1999's gear list:Saleen1999's gear list
Nikon D3S Nikon AF-S Nikkor 24-120mm f/3.5-5.6G ED-IF VR Nikon AF Nikkor 50mm f/1.4D Nikon AF Nikkor 70-300mm f/4-5.6G
Allen Gerdes
Veteran MemberPosts: 5,458
Here is my version, using PSPX5:
Regards......Allen
Steve Throndson
Senior MemberPosts: 2,110
isotope,
LR 4 - is that Lightroom?  If it has Adobe Camera Raw, you could start like this with your raw file . . .
(this screen shot is ACR in Photoshop CS-5)
Hope this helps.
Felixography
Contributing MemberPosts: 504
Hope this is what you want.
tony brown
Veteran MemberPosts: 3,570
Having the RAW file, it's better if you can post that as all you give is the jpeg.
Could do better with Raw but here's my version:-
Used HDR programme and ACR to get four version of the image suited to each problem area and mixed them with layers and masks.
Cheers, Tony.
Ron AKA
Veteran MemberPosts: 4,875Gear list
isotope wrote:
Hi All,
Thanx for the help,
PTMD
I believe LR4 uses the same 2012 Process as PSE11. Here are my settings in PSE11 for the image below: Contrast -11, Hightlights & Whites -100, Shadows +100, Blacks +17, Clarity +15, Vibrance +50.
 Ron AKA's gear list:Ron AKA's gear list
Sony RX100 Epson Stylus Photo R3000 +1 more
asoftwind
Veteran MemberPosts: 4,635
I don't have Lightroom. Just playing. Done with Elements.
Claude
isotope
isotope OP
In reply to asoftwind, Jan 28, 2014
this is awesome... thank you everyone for providing your inputs...
quick questions..
how do i mask? or layer? in Lightroom 4.0.
isotope
isotope OP
In reply to Victor Engel, Jan 28, 2014
Victor Engel
this was a random picture... and plus i am only a photo enthusiast, by no means a professional.
Ron AKA
quick questions..
Lightroom does not do Layers. You need the full Photoshop or Photoshop Elements for Layers. But it is really not necessary to fix this shot. Just use the exposure settings I gave you in the earlier post.
Victor Engel
isotope wrote:
Victor Engel
Yeah, I tried answering generically. Also, your last point is why I moved the thread to this forum, where it will likely get more appropriate replies (my last point in my first reply is the type of reply you would likely get in Pro Digital Talk, where you originally posted). Just be aware that people in this forum often like to show their treatment without explanation, and some of the treatments leave something to be desired.
Victor Engel
Dareshooter
Senior MemberPosts: 1,549
isotope wrote:
Victor Engel
Good advice from Victor.You don't have to be a professional but as an enthusiast you should get into a habit of routinely using a burst of fill flash in daylight situations like this. I see to too many people relying on a post shoot fix, not good and takes more time yeah ?
Victor Engel
In reply to Dareshooter, Jan 28, 2014
Dareshooter wrote:
isotope wrote:
Victor Engel
If you look carefully at the photo, I think you may agree that there was fill flash in that shot. It just wasn't enough.
Victor Engel
MGJA
Regular MemberPosts: 418Gear list
Always interesting to see how much you can save with modern cameras so long as you're willing to accept that the final result won't be the equal of a correct exposure.
Split the original image in 8 stop masks, lifted each stop individually, merged to one image. Some selective blurring and local contrast. Finally a slight blue channel desaturation for 60's Cuban poster look.
donNico
Forum MemberPosts: 65
Some playing in PS, no extra plugins.
a5519
Regular MemberPosts: 221
My try
Dareshooter
Victor Engel wrote:
Dareshooter wrote:
isotope wrote:
Victor Engel
Victor Engel
You could be right Victor, a few speckled highlights here and there but they may have been reflected from elsewhere as there's a lot  of light coming from the right. I guess the OP knows for sure though .
