Problem with Sony A7, reflections on the sensor.
Started Jan 26, 2014 | Discussions
Mauro.B
Mauro.B Senior Member • Posts: 2,405
Yes, KR pointed that out first.
 Mauro.B's gear list:Mauro.B's gear list
Ricoh GR Leica Q Leica M Typ 240 Sony Alpha 7R II
SQLGuy
SQLGuy Veteran Member • Posts: 4,014
Re: Yes, KR pointed that out first.
Looks like an opportunity for adapter makers to offer adapters with a built-in anti-reflective (both sides) filter in them.
A7 with kit lens and a number of legacy lenses (mostly Canon FD)
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Nikon D200 Sony Alpha 7 II Sony Alpha NEX-7 Nikon AF-S DX Nikkor 35mm f/1.8G +2 more
Mauro.B
Your guess' totally wrong
Trollmann wrote:
Interesting thread!
Seems like the initial problem is reflection from the rear element of the lens (in the early digital days this was a BIG issue and it did not take lone before lens makers had all their lenses coated with superb anti reflection coatings on the rear lens element). Reflection from sensors are real, with film it was no issue - and lots of older lenses have uncoated or poorly coated rear lens elements.
Had the Minolta 2.8/16 mm fish eye (film day lens) and there was a plethoria of reflections when used with my Minolta digital camera - with film there was almost none. Simply gave up the lens as a digital alternative.
So I guess (note: I do not know) the lens is to blame and not the sensor per se.
Diffraction spikes (like rays around the sun when using a small aperture) is caused by diffraction in the aperture blades. Circular apertures cause diffraction rings and apertures with angles (like a four or five blade aperture) cause diffraction spikes (and some other not that easy to spot diffraction pattern).
There is a lot of theory about reflective sensor surfaces and diffraction but mentioning things like these on a forum usually open cans of worms. Lots of misconceptions...
A7r does not do that unless pushed hard, like sun into the frame, and in the latter case you have to squint to notice.
OTTH, the A7r draws fat halos around red lights in night shots.
M
Petroglyph
Petroglyph Senior Member • Posts: 4,806
Re: Take this back... sensor covering too reflective?
viking79 wrote:
viking79 wrote:
The lens likely wasn't designed for highly reflective digital sensors so you get a lot of reflections off the sensor. Newer lenses have better coatings on the rear elements to kill these off.
I notice the same BTW.
Those reflections are not adapter issues, they look like light hitting the sensor then hitting the rear element of the lens, then hitting the sensor, etc.
Eric
I take this back, it appears to be reflections off or internal to the filter stack? This is definitely a sensor issue, I just figured it was flare from the FE 35mm f/2.8 when I tried it. I commented on this in my review last month.
What makes me change my mind is a lens that is fine on the D610 or something should be the same on the A7, if putting it on the A7 causes those patterns (and they really don't appear adapter related) but putting it on the A7r with the same adapter (or non adapted FE 35mm) and they go away? That is the filter stack or sensor itself.
If this is from the A7 it won't change my usage of it, but it does give a good reason to get the A7r instead (if you take night cityscape photos or landscapes with the sun in the frame).
Eric
I didn't see this in 5-6 thousand shots with a NEX-7.  Doesn't really prove anything but I do use older lenses on the NEX.  Might tend to indicate an A7 only problem but as I said not really any proof.
 Petroglyph's gear list:Petroglyph's gear list
Pentax K-3 Sony Alpha 7R II Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Sigma 35mm F1.4 DG HSM Art Pentax smc DA* 300mm F4.0 ED (IF) SDM +4 more
SQLGuy
I found these: http://www.edmundoptics.com/optics/windows-diffusers/visible-windows/anti-reflection-ar-coated-high-efficiency-windows/48926
They would require me to open up the ID of my Fotasy FD/E adapter by about 3mm to install them. Too bad they don't have something just a bit smaller in diameter, but I might give this a try...
Edit: Just thought about this some more, and it wouldn't help. The AR coating really needs to be on the lens and/or the sensor, since an AR window in the middle is still doing to do nothing to stop reflections bouncing back and forth between these two surfaces.
Mauro.B
Adapters have nothing to do with that.
The adapters' supposed internal reflections have been worked to death with gaffer, sugru and stuff: no change .
The A7 reflections look like a diffracted and enlarged reflection of sensor's pixel pattern, either reflected back to the rear lens and then again onto the sensor, or the effect of angled rays being furterly diffracted by sensor glass cover.
M
Mauro.B
I had 2 Leica M 240
viking79 wrote:
Just to add, this is a problem since the lens sits so close to the sensor. Even newer lenses do this to some degree (albeit much less). The Zeiss 35mm f/2.8 does this.
So maybe it is in part the sensor cover being overly reflective, but I don't think it is worse than any other short flange distance full frame mirrorless camera with CMOS sensor (hint, there is only 1 other). I can't for the life of me find any info about the new Leica M, since the name is too generic to search for to see if it is also an issue with it.
I imagine the same is visible from the NEX series cameras with these lenses?
Eric
M240 has an almost flawless performance in night shots. Btw, the M9 is even better.
m
Kiril Karaatanasov
Kiril Karaatanasov Senior Member • Posts: 2,011
Strane....
Strange my zeiss 35/2.8 seems to perform very well. I do not get much flare with it let alone any reflections...
http://www.flickr.com/photos/kirilk/11315262355/sizes/l/
note that the pictures was taken through hotel window so perhaps some of the effects come from it.
I do see some flares in some of the lights. Really not much out of ordinary.
Also the sensor itself cannot do flares. This is complete non-sense. Light cannot be curved or bent. Light can be reflected off of reflective surface.
More likely there is something else in the box that is causing internal reflections. With adapted lenses the adapter is to be checked first.
With native lenses it may be that Sony have left behind some reflective surface on the shutter mechanism or something.
Also it is possible that we see lens defects on the 35/2.8
Just please stop the sensor flare non-sense.
 Kiril Karaatanasov's gear list:Kiril Karaatanasov's gear list
Sony a6000 Sony Alpha 7 II
geo444
geo444 Regular Member • Posts: 480
Reflections on the Sony A7's low-pass filter (AA) ?...
versus the A7R that has No AA filter...
so no problem !
stoppingdown
stoppingdown Regular Member • Posts: 405
Re: Lens fault, not sensors problem...
Do you think the weaker green blobs here could be the same problem (they seem roughly placed in grid) or are they just regular flare?
Fabrizio Giudici
http://stoppingdown.net
 stoppingdown's gear list:stoppingdown's gear list
Sony Alpha NEX-6 Nikon D7000 Sony a6000 Nikon AF-S Nikkor 300mm f/4D ED-IF Samyang 8mm F3.5 Aspherical IF MC Fisheye +8 more
Mauro.B
Flare [nt]
Fabrizio Giudici
SQLGuy
Re: Reflections between sensor and rear element
I wonder if a polarizer would help. Polarizers reduce glare off of non-metallic surfaces, so polarized light might also be better able to pass through the sensor cover rather than reflecting off of it.
PRESENZA76
PRESENZA76 OP New Member • Posts: 12
A7 with Leica M 21 SEM asph
No CPL
With CPL
I love Leica
stoppingdown
I think you also changed aperture, right? Both have same ISO and shutter speed, so the one with the polariser should have compensated 1+EV... right?
Fabrizio Giudici
secondclaw
secondclaw Regular Member • Posts: 245
Re: Problem with Sony A7, reflections on the sensor.
I have encountered this issue with A7R and metabones adapter so I ended up flocking insides of the adapter with optically non-reflective paper, and it mostly mitigated the issue. It's still there but tolerable.
Here's a shot that produced a starburst effect, and no flares, in the moon or the lights on the side. It's at f9, but result's pretty much the same at f11.
A7R + Metabones 3 + Zeiss 21mm f2.8 ZE, 30s @ f/9
 secondclaw's gear list:secondclaw's gear list
Canon EOS 5D Mark II Sony Alpha NEX-7 Sony Alpha 7R Canon EF 70-200mm f/2.8L IS USM Canon EF 24-70mm f/2.8L II USM +10 more
viking79
viking79 Forum Pro • Posts: 14,135
Definitely the same thing
The smaller green blobs are the same grid aligned flare spots we have seen on A7 only.  They repeat like that over a pattern.  Something definitely up with A7 sensor cover.
Eric
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
viking79
Re: Reflections on the Sony A7's low-pass filter (AA) ?...
so no problem !
Even if the A7r has no AA filter, it still has a glass plate in its place, so there is not reason for A7 to perform worse here, maybe they don't have as good of coating on it or something.
Eric
djp58
djp58 Regular Member • Posts: 351
A7R has similar issue w/FE35
This issue is not just on the A7. I've seen it on A7R, though only when shooting direct into sun with a lot of snow. Here is an example taken at F20, though I still at issues as low as f7.1, just not as pronounced.
http://www.flickr.com/photos/114429158@N08/12166095593/
For me it's not an issue - I've taken more than 1,000 shots and this is the only time I've seen an issue with this combo.
David
 djp58's gear list:djp58's gear list
Sony Alpha NEX-7 Sony Alpha 7R Sony E 18-200mm F3.5-6.3 OSS Sony E 50mm F1.8 OSS Sony FE 35mm F2.8 +13 more
Mel Snyder
Mel Snyder Veteran Member • Posts: 4,088
kimca wrote:
I get the same artefacts with the A7 and FE35, but not with the FE55. I had thought it a problem with the FE35, but I guess not. Its fairly annoying as it happens in sunlight, and you cannot get a sunstar without it... Everything else about the camera is stunning, mind.
A7 with FE35
There's something weird here.Unlike the original post, the dots seem quite regular in rows - is there a lenticular filter over the sensor array?
 Mel Snyder's gear list:Mel Snyder's gear list
Sony Alpha NEX-6 Sony Alpha 7 Sony E 16-50mm F3.5-5.6 PZ OSS Sony E 55-210mm F4.5-6.3 OSS Leica Summicron-M 50mm f/2 +12 more
stevo23
stevo23 Forum Pro • Posts: 10,110
seachicken2000 wrote:
I saw the same on this image from SLRclub from the SEL 24-70mm f/4 on the A7. I assumed it was a characteristic of the lens. It's much more worrying if it's the sensor. I wonder whether it's only the A7, or does the A7r also do this.
A rose by any other name is still a chicken.
http://500px.com/seachicken
I'll give it a try with my A7r later on. Not noticed it yet (not that I have many night shots though).
Thanks. I did a little digging on Flickr, and the A7r seems OK. Here's one (A7r + Zeiss 35mm) that ought to have shown this, but looks very clean.
Look again - this image is starting to display the issue. Look carefully at the lights on the far left. Further, its not every light in the darkness that will cause the problem.
 stevo23's gear list:stevo23's gear list
Sony Alpha 7 Sony FE 35mm F2.8 Sony FE 55mm F1.8 Tamron SP AF 90mm F/2.8 Di Macro Nikon AF Nikkor 20mm f/2.8D +1 more
