Thinking of migrating from NEX to Fuji X
Started Jan 24, 2014 | Discussions
gbert15
gbert15 Contributing Member • Posts: 579
Recently, after seeing the rumored specs of the X-T1, I suddenly considered switching systems! The thing that was holding me back for the past few systems were the no tilt screen which helps me a lot in car photography and concerts, the slightly inferior evf(not really sure how good it is but it seems like the review points that the nex system had a better one), slow/inacurate af(again mostly from reviews but sony has the same thing but it seemed like fuji was worse in that department in the reviews compared to sony)!
I love how the rumored specs of the X-T1 seems to have addressed some of my concerns and it seems appropriate for me to jump ship already being that fuji trumps sony in the lens department hands down! Still unsure of the af of the X-T1 so I am still waiting for more leaks or its official release! Also, I wish fuji had the same flash as Sony where it was able to tilt sideways for portrait shots(is there a flash like that for fuji?)! Those are the only things holding me back plus the hassle of selling all my sony gear to migrate to fuji!
Are there any member that came from sony or even have a sony system as part of their gear? If so I would appreciate the input if its truly worth switching mounts! Thanks in advance and would appreciate the input!
 gbert15's gear list:gbert15's gear list
Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R
topstuff Senior Member • Posts: 1,208
Re: Thinking of migrating from NEX to Fuji X
I can see what you mean.
Fuji have been making all the right moves.
Constant improvement through firmware updates.
Relentless and ambitious and constant development of new lenses.
Basically , although I am a fan of Sony gear, Fuji have done all the things Sony should be doing.
Tom Davis Regular Member • Posts: 134
I migrated from Sony NEX (5n + 5t) with a full compliment of Sony and Sigma E-mount lenses along with the Zeiss 24mm. I too wanted a tilt-screen but went with two X-E2 bodies and now a full compliment of XF lenses and, importantly, Capture One to convert raw files (see my profile for lens specifics). I'm will add the X-T1 with grip as soon as it's available since it gets, well, just everything right in terms of control placement. I realized after I switched the degree to which I had missed the easy fluidity of analog controls. With the X-T1 you'll be abel to see all your basic settings with a glance of your eye, with direct finger control of each of them.
I lost nothing with this migration in terms of resolution (the Fuji lenses are excellent, e.g. the 23mm is superior to the Zeiss 24). Color reproduction is superior, most especially with jpegs, now that Capture One has settled the X-Trans problems of other conversion programs. Files "pop" with natural grace. I'm very pleased.
The original temptation for me was moving up to Sony A7/7r. But Fuji's XF lens line-up is well-thought out, is optically excellent, fits my hands well, and costs less than Sony's mostly still-to-be FF lenses. And Fuji's M-mount adapter, while relatively expensive, works exceptionally well with my Leica and Zeiss M-mount lenses and my LTM lenses.
If you want more feedback and reviews on going with Fuji XF, I suggest googling the "Admiring Light" webpage....
In sum: I have no regrets at all with switching from NEX and now that the hype of Sony A7/7r is settling down (see the review here of the A7), I'm not second-guessing that option either.
 Tom Davis's gear list:Tom Davis's gear list
Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 27mm F2.8 Fujifilm XF 56mm F1.2 R APD +23 more
p.s. I second the point about Fujifilm's firmware upgrades: they have established that they will honestly try to keep you up to date.
gbert15
gbert15 OP Contributing Member • Posts: 579
Yea, thats one point i forgot to mention about fuji! Spny basically has 1 or 2 updates on their cameras then thats it! Onto the new body! I like how fuji improves and shows dedication to their products!
gbert15
Nice nice! Thanks for that info on your experience! Basically I am currently shooting with a NEX-6 right now and have the touit 12/2.8, zeiss 24/1.8, sony 55-210, and an adapted Pentax Takumar SMC 50/1.4 and I envy you guys a lot with all these fast lenses at your disposal! My current line up can easily be changed with better lenses if I migrate to fuji! The main selling point though is the 23/1.4 since that is my fav focal length and it seems to be one heck of a lens!
How was your experience though on af speed and the fuji menu system?I know the menu system if the nex is a mess so how much easier was the fuji menu system to use compared to the sony? I wish they had modern bodies though but its not a deal breaker at all! I am shooting with my camera anyway and not taking pics of it! Hehe!
Thanks for the reference! I will try to check it out!
gbert15
Btw, on raw file conversion, isnt there any installable codecs for your computer to read those raw files from fuji easily? Would I always need a converter for me to be able to see and the computer to read them?
Basically my process has been hooking my nex 6 to my comp then copying my raw files to my comp then importing them in lightroom then doing a little bit of editing from there and doing some photoshop editing after if needed! So my question is, would I need an extra step/s in order for me to proceed with my photo editing process with fuji?
forpetessake
forpetessake Senior Member • Posts: 4,892
that though may have occurred to many ...
... but then you make a side-by-side comparison and understand that the fantasy world and reality are quite different:
Sony NEX-5N vs Fuji X-E1
Sony NEX-5N vs Fuji X-A1
The best argument against democracy is a five-minute conversation with the average voter -- Winston Churchill
gbert15
Re: that though may have occurred to many ...
In what terms? IQ?
Caerolle
Caerolle Senior Member • Posts: 3,153
Wow, your Sony pics make me glad yet again that I got rid of my NEX stuff.
Not because I think they are good, but because I would like to improve (feel free to provide me with feedback):
http://500px.com/carolteater
 Caerolle's gear list:Caerolle's gear list
Olympus E-M1 Olympus OM-D E-M10 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro +3 more
love_them_all Senior Member • Posts: 2,770
I am using both. If you use MF legacy lenses a lot, Sony is slightly better. JPGs, especially the skin tone and vivid colors, Fuji. Noise, probably Fuji (jpg). Fast primes, Fuji, although the FE Zeiss are also very good, but they need to release a few more. If you have the APSC sony, the size is a lot more portable.
I use a lot of legacy lenses so I can use the same lens on both systems. But Sony got more mount adapter avail like the metabones FE to E with AF and aperture control.
gbert15
Manual lenses isnt really my thing and fuji can already fill my lens needs with their native lenses! I have a couple like the canon fd 35/2, bokina, and the takumar 50/1.4 but only use the takumar since I sold my Sony 50/1.8 a while ago! Fuji seems to trump sony's offering on most focal lengths! The zeiss 24/1.8 does have that nice bokeh that the 23/1.4 has and that seems to have sold me on fuji! Even the initial 35/1.4 release was really enticing me but camera performance from reviews made me shy away from fuji! I truly hope the X-T1 will perform the way I am anticipating it to be! If it does, I will have to jump on that fuji ship asap!
PenPix Senior Member • Posts: 2,209
Prior to getting my X-E1, I had a NEX-5 for almost a year. I had the 18-200 Tamron zoom on it and I thought it was a great travel camera.
The Sony has focus-by-wire like the Fuji, but whenever the power is turned off or goes into standby, the focus position is reset. This was very bad when I was pre-focused to take pictures of a float plane taking off from the lake. Missed shots
Taking pictures of the moon rise over a mountain lake, I set it on my tripod and waited for the moon to move into position. Same problem… camera goes into standby and focus is lost. Focus peaking is useless in this situation and focus zoom only zoomed into the center of the image so I had to take the camera off the tripod to refocus. :-x. The Fuji remembers where the focus is even after you turn it off.
I tend to do change a lot of settings on the fly and I hated menu diving with the NEX… and some of the settings go deep. Exposure compensation didn't work with the scene modes I liked to use, so It was almost pointless to use them because the exposures were never predictable. HDR is disabled in some of them too. The Q button on the Fuji lets you quickly jump to the major setting in the camera.
Those are a few of the things with the Sony that made me swear at the camera! Up to that point, I've never sore at a camera. (usually the anger is directed to myself for doing something stupid).
Perhaps I needed more time with the NEX to get the most of the system, but with the X-E1 I was able to get it to do exactly what I want all the time, right from the beginning.  It is a fantastic camera for anyone who prefers manual control.
Compared to the Nex-5, D700, and D200, I was wowed by the Fuji IQ. This summer I plan to start using the X-E1 instead of the D700 for a few of my shoots. That's how confident I am with the system.
Regardless, my decision to move to Fuji was because I disliked the Sony operation an interface.  If I was happy with how the NEX cameras worked, I doubt I would have changed.
AF speed with the X-E2 is fine, I really see no difference from my experience with the NEX-5t. Of course it's not meant to be a sports camera. But for the work I do in environmental portraiture and Japanese Gardens, it certainly fast enough. And the finder is excellent, especially if you wear eyeglasses as I do. The finder on the X-T1 will be even better.
Fuji has a simple, straightforward, and logically laid-out menu system. But the main point about the X-T1 is that its external controls are so well laid-out that they put every major exposure option within a finger-reach. Which means you simply won't have to use the menus for most any regular setting. And of course there's always the "Q" button to bring up the most used menus if you want them.
If you plan on using native lenses, I don't see how you can go wrong with the Fuji XF lineup. I'll add the 56mm f1.2 when it's out. And I use a Leica 90mm f2.8 Elmarit-M for a longer prime when I don't want to use the 55-200 XF zoom which is excellent for landscape work. When Fuji adds a longer prime I'll get that as well. A great lineup and all developed to match the sensor-size.
Diacyclops81 Regular Member • Posts: 175
Looked closely at the dog sleeping...looks like my old pooch. But to the point, perhaps you didn't use the same lens on the cameras...the resolution is distinctly better with the 5N, examine the hair along the back and the fabric of the cloth. The Fuji smudges the details.  No?
The "smearing" issue with X-Trans is now past-tense since Adobe got its act together, though I use Capture One myself. Though it's a pay-site I strongly recommend Reid Reviews articles on different converters for Fuji raw files to go along with his excellent reviews of the XF lenses.
Were these JPegs or PP raws??   If they are both JPGs then the smearing is present in the Fuji JPGs, but could be corrected by RAW processing?   There's another thread here in which many are very happy with the JPGs out of camera from Fuji. I shoot most of my snapshots never expecting to print very large, mostly share online and view on ipads, etc.,  so a lot of the time it's JPG only. However for more important images, then sure, RAW and processing. But I would not want smearing in the JPG from the camera...I certainly am thinking of switching to Fuji. Had a XE-2 but returned it, the flip up LCD of my NEX 5N has me spoiled. My interest is in the new model XT-1.
Alohaman Contributing Member • Posts: 576
I'v had a Canon for 8 years, Sony for 2 years and a Fuji for 6 months.  I'm going to wait out the next year 2-4 years.  Sony has the new A7s out and probably a new NEX 6/7 replacement next week.  But, I won't jump any of these. Fuji's XT-1 is coming soon.  But, I won't get this either.  This is my last Canon.
After many years of seeing new models come and go, it's best for me to wait.  My T4I, NEX -7 and X100s should be goods for many more years.  Maybe by then, I'll decide between a Sony or Fuji.
 Alohaman's gear list:Alohaman's gear list
Panasonic Lumix DMC-GX7 Sony Alpha 7R II Panasonic Lumix G X Vario 35-100mm F2.8 OIS Olympus M.Zuiko Digital 17mm 1:1.8 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS
ProcrastinationExpert New Member • Posts: 10
Still a little bit of water colour/smearing can be seen at 80% or larger with some dense foliage. Though it has improved, it can still use more work. Not a very big issue but will annoy pixel peepers.
 ProcrastinationExpert's gear list:ProcrastinationExpert's gear list
Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS
gbert15
Had a nex 5 also and agree it was a pain in terms of the menu diving! The nex 6 though was a big improvement taking ques from the nex 7 but with a mode dial and another control dial just underneath it! I loved the design!
Nice that u pointed out the reset of focus! It never bothered me because the next was my first ILC so I was basically used to that and didnt really notice it much in my shooting!
Its good to know and its quite comforting to know your confidence in the system! Hopefully it will be the same on my end but then again I only have one system and dont plan on having 2 or more cameras at a time!
