I've caught the MF bug
Started Jan 22, 2014 | Discussions
bvphotos Regular Member • Posts: 259
I started with 2 M42 mount MF lenses: a Mamiya Sekor 55/1.8 & Vivitar 135/2.8. I've just bought a Helios 58/2 lens that hasn't arrived yet. All 3 cost me less than $100. I've been reading up on MF lenses and there are so many of them that my head is spinning. I have a few criteria: (a) I don't want to spend too much, (b) I don't want to have too many mounts, (c) I want small & light lenses, (d) good IQ if great IQ cannot be had in my price range. I hope I'm not asking for too much. Specifically, to augment what I have, I want to next look at the following kinds of lenses:
1. 24mm and wider: Here are the choices I have on my (long) list: FD 24/2.8, Yashica 24/2.8, nikkor AI/non-AI 24/2.8, Tokina RMC 17mm FD mount, Rokinon 14mm.
2. Something in the 85-105 range: FD 85/1.8, Kiron 105/2.8, Nikkor (AI) 105/2.5, Nikkor AIS 85/2, Oly Zuiko OM 100/2.8.
3. A standard zoom: FD 35-70/2.8, Vivitar 28-90/2.8-3.5, Contax Vario Sonnar 35-70/3.4 (not cheap, though).
4. A possible replacement for the Vivitar 135: Hexanon AR 135/3.2, SMC Tak 135/2.5, FD 135/2.5.
Any comments on these choices? Cheaper, but equally good, alternatives?
Thanks.
(PS: I'll also be using these MF lenses on a Fujifilm X-E1, which is also on its way.)
Canon 6D, Canon 50D, Canon 100 f2, Canon 100-400 IS, Canon 50 1.4, Canon 24-105mm IS, Canon 70-200mm f4 IS, Mamiya Sekor 55mm 1.8, Vivitar 135mm 2.8, Tamron Pro 1.4TC, Speedlite 430EX, Feisol 3402 + Giotto ballhead.
Canon EOS 50D Canon EOS 6D Fujifilm X-E1
richiemccaw Contributing Member • Posts: 804
Re: I've caught the MF bug
I was about to say its very challenging MF-ing without liveview on my 5D when I realized you have a 6D.
I prefer to use wide angle legacy lenses as they generally are for landscape where I wouldn't feel pressured into using AF.
Personally I have been playing around with the Olympus OM 28mm f2.8 to mixed results. Mainly because Im still learning how to meter and expose properly. It's probably going to be a lot easier on your Fuji, just like how it's a breeze on my Nex.
 richiemccaw's gear list:richiemccaw's gear list
Panasonic Lumix DMC-LX100 Sony Alpha NEX-6 Canon EOS 80D Tamron SP 70-300mm F/4-5.6 Di USD Sony E 16-50mm F3.5-5.6 PZ OSS +6 more
Dave Chilvers
Dave Chilvers Veteran Member • Posts: 3,361
apart from many MF lenses two of the focal ranges you mention that I own:
Contax 37-70 T* MM (superb and like shooting primes)
Contax 100mm f3.5 T* MM ( a bit slow but easy enough to focus with Live View, truly superb IQ and I have two of them just in case I drop one:-)
Leica 50 f2 Sumicron (superb)
and if you can find a used Voigtlander 40mm f2 ultron mk2 you love the small size and corners.
I feel so much better now that I've given up Hope
http://www.pbase.com/davechilvers/latest_images
 Dave Chilvers's gear list:Dave Chilvers's gear list
Canon EOS 6D Panasonic Lumix DMC-G7 Canon EF 85mm f/1.8 USM Panasonic Leica Summilux DG 25mm F1.4 Panasonic 12-35mm F2.8 +14 more
bvphotos OP Regular Member • Posts: 259
Do you mean 35-70mm Vario-Sonnar MMJ lens?
Dave Chilvers
Not sure about the  J  but it is the f 3.4 vario-sonnar
brightcolours Forum Pro • Posts: 12,678
Best skip the FD lenses from your list
The FD mount lenses are not a good idea. Unless you want to use them for macro
The FD mount simply is closer to the sensor/film than EOS mount, so no adapter will fit in-between. Some lenses you can convert, but conversion costs and the lenses you mention are no candidates.
Look at the other mount Tokina 17mm's instead, or the Tamron adaptall 17mm. Other options are Nikkor 24mm f2.8/2, Nikkor 18mm f4/3.5, Voigtländer 20mm f3.5 SL II (N).
The Nikkor 85mm f2 Ai/Ai-S is not a very good lens. Rather look at the older Nikkor-H 85mm f1.8 or the better coated Nikkor-H*C 85mm f1.8 (pre-AI), which both are much better (optically). Again, the FD is not a good idea. The Samyang/Rokinon 85mm f1.4 is also a nice lens, as is the Nikkor 85mm f1.4 (but the latter probably has pretty steep used prices).
Again... No FD.
Broken record.... FD not a good idea. A VERY sharp (with nice bokeh) lens is the Nikkor-Q 135mm f3.5 in its various guises. The early metal/black Q version is already very good, the later "K", Ai/Ai-S versions have better coatings. The Nikkor 135mm f2.8 (various versions, 2 optical formulas) and 135mm f2 are also to rather affordable. The lightest of the Nikkors are the 135mm f3.5 and the Ai-S version of the 135mm f2.8.
Yeah, skip the FDs
Thanks.
The FDs will work on the Fuji. Just not a good idea concerning your 50D and even more so the 6D.
The manual focus lenses I have in my collection:
  • Voigtländer 20mm f3.5 SL II N. Lovely little pancake wide angle.
  • Nikkor 35mm f2.8. Soft lens. Not recommended.
  • Nikkor-S 50mm f2. Very sharp little lens, does not play nice with focus confirmation.
  • Micro-Nikkor 55mm f3.5. Great macro lens.
  • Nikkor-S•C 55mm f1.2. Nice lens with "interesting" bokeh.
  • Canon FL 55mm f1.2. Nice lens with "interesting" bokeh, with worse coatings. Expensive conversion. Hits 6D mirror at midrange to infinity (so live view needed at such shots).
  • Nikkor-H 85mm f1.8. Lovely lens with smooth bokeh. The H•C version "radiates" less wide open.
  • Nikkor-Q 135mm f3.5. Sharp lens which renders beautifully.
  • Nikkor 135mm f2.8 ("K"-version). Have not used it yet. Heavy at 600 grams.
  • Old Delft Delfinor 140mm f1.8. Old film projection lens, made an adapter for it. Lots of aberrations, but super smooth bokeh. Interesting and weird.
  • Tamron SP 500mm f8 (mirror lens, 1st version (the one with the tripod mount)). Surprisingly sharp/contrasty for a mirror lens, handholdable with the 6D due to its god high ISO performance. Interesting lens due to its extreme compactness and low weight.
The NO focussing lenses I have (industrial fixed focus lenses):
  • Ultra-Micro-Nikkor 55mm f2. Lovely rendering lens. Made a custom adapter for it with also allows for trap focus, with gives it about 1:3 macro.
  • Ultra-Micro-Nikkor 28mm f1.8. Have compiled a setup for it with reversal ring, step down ring and bellows for extreme macro stuff, but have not used it yet.
Re: Best skip the FD lenses from your list
Thank you for bringing the issue of FD lenses with the 6D to my attention. I'm glad you chimed in before I started buying them. I'll focus on the alternatives now. The Rokkors, many of which are also rated very highly, also don't work with EOS cameras.
macky patalinghug Senior Member • Posts: 1,223
After collecting manual lenses from junk shops and repair shops for three years now I noticed that my AI/AIS lenses outnumber my EF/EF-S lenses though I currently don't have a Nikon camera. I also have about 10 screw type lenses (mostly Takumars).
My latest acquisition is a far from mint 75-150 series e zoom. I prefer primes but after reading some positive reviews I tried this one. And I am happy with it. Here are some snaps with the lens on my 6D.
With a couple of few exemptions, old manual Nikkors pair well with modern EOS. This should come as no surprise as the first Canon camera had a Nikon (Nippon Kugako) lens on it when Nikon still had to produce a camera.
slowshotmax
 macky patalinghug's gear list:macky patalinghug's gear list
Fujifilm X-E1 Canon EOS 6D Fujifilm X-M1 Nikon D5300 Canon EF 35mm f/2.0 +4 more
Erik Magnuson Forum Pro • Posts: 12,237
In addition to the FD issue, you have to be careful with Nikkor and Olympus wider angles and your 6D.  Some of these lenses have metal protrusions that interfere with mounting or mirror clearance.
3. A standard zoom: ... Vivitar 28-90/2.8-3.5
The Vivitar has a lot of vignetting on FF.
Erik
 Erik Magnuson's gear list:Erik Magnuson's gear list
Canon EOS 5D Mark II Canon EOS 450D Sigma SD10 Sony Alpha NEX-5 Nikon D3200 +28 more
JackM
JackM Veteran Member • Posts: 7,317
But why?
You don't really say.  You seem to be looking for lenses to cover mutually exclusive purposes.  Using manual focus lenses on a FF SLR is best for landscape or static subjects.  If you want legacy mf lenses for your XE-1, it would be best to go for rangefinder type lenses which will be smaller and lighter and will mount elegantly with a slim adapter.  This will be better for street photography and anywhere that discretion and portability is important.  Mounting SLR lenses on your XE-1 will require a big clunky adapter that also makes up for the much longer flange distance.
So I guess I would advise you to pick one set of uses and concentrate on buying great lenses for that first.  Fuji makes bold claims about its sensors surpassing FF.  They're great, but it simply isn't true, I have both.  So if you crave maximum IQ at 100% view, forget about the XE-1 when buying MF lenses.  On the other hand, if you crave discretion and portability, then concentrate on rangefinder lenses for the XE-1 and forget about the 6D.
Enjoy that aspect of photography for a while and save up for the other.  Or if money is no object, then heck, do whatever you want.
 JackM's gear list:JackM's gear list
Sigma DP2 Merrill Fujifilm X100S Canon EOS 5D Mark III Canon EOS 7D Mark II Canon EF 50mm f/1.4 USM +7 more
That last bit makes no sense
This last bit makes no sense in any way, just very contrived. Nice results though
slowshotmax
Whoa! This lens wasn't on my radar. But the pics are excellent. And the lens is cheap. I'm certainly putting it high on my list. Thanks for the suggestion.
With Nikkor? Only some fisheyes have that, and they protrude in such a huge extent that one can't make a mistake!
10mm fisheye
8mm fisheye
6mm fisheye
All normal Nikkor wide angles will work without problems.
Pentax K/A mount lenses will need (destructive) modification.
Erik
Re: But why?
You've intuited my reasons quite well. It's mostly for my Fuji X camera. But I'd like to use the MF lenses on my Canon as well, particularly in situations when I don't want to lug around my heavier lenses (even the 24-105mm lens can get tiring after a while).
I have not looked at rangefinder lenses carefully, but my understanding is that they're expensive.
Have you tried them all?  Tell me what happened when you mounted the 20mm f/4.
See that black tab at the bottom?
Erik
panoviews
panoviews Regular Member • Posts: 310
Got also caught with this bug. I got the Arsat Tilt Adapter for Pentacon-Six lenses and two old Zeiss Jena lenses (Flektogon 50mm/f4 + Biometar 80mm/f2.8).
http://araxfoto.com/accessories/tilt/
http://www.pentaconsix.com/lenstest.htm
 panoviews's gear list:panoviews's gear list
Canon EOS 5D Canon EOS 6D Sony a6000 Canon EF 100mm f/2.0 USM Canon EF 70-200mm f/4.0L USM +5 more
JackM
Re: But why?
Then I would say forget about mf lenses for the 6D for now. Getting lenses to use on both will turn your XE-1 into a big clunky camera, and that's not why you bought it. You certainly didn't buy it for better IQ than your 6D.
I went through this phase briefly when I inherited an extra Pentax SMC-M 50mm f/1.4. I modified it for use on my 5D2. Great lens, at least as sharp as my 24-70L. After one evening of street shooting, I was all set with that.
FF EOS cameras are big, clunky, heavy, soul-stealing nerd cameras. Not even a body cap lens could make them discrete or portable, so I don't see the point of using legacy lenses on them unless you have a specific lens in mind with specific qualities. Like I recently got a Helios 44-2 for its renowned swirly bokeh.
For reasonably priced RF lenses I would say look to Voigtlander, Konica Hexanon, Ricoh, Canon, Nikon. There are probably others. Hmm, here's an interesting article:
http://www.japancamerahunter.com/2013/10/jch-top-10-m-mount-lenses/
Yes, I see that black tab at the bottom. Tell me, have you had it catch the mirror?
Erik
JackM
Re: But why?
And when you want to do that, just get a Canon 50/1.4 and a 28/1.8 and be happy. Or a 35/2 and a 85/1.8 or 100/2. These are great lenses within their limits. They're not sexy, but neither is your 6D.
Re: But why?
I don't think the EF 28mm f1.8 USM is great. I don't know a whole lot lenses that I find to render less attractive, to be honest. Both contrast and bokeh are lacking. An EF 28mm f2.8 is a better idea then.
