Help, did I screw up my sensor?
Started Jan 19, 2014 | Discussions
mactac
Regular MemberPosts: 287Gear list
Jan 19, 2014
So I had a bunch of dust on my sensor of my d800, and decided to use the visibledust vswabs.
I used one, and it left streaks & marks all over my sensor, and almost a 'film' all over it, like i had breathed on it.
I tried again (finally using all 4 that came in the pack), and still have the same problem.  I now have most dust specks, and streaks on my sensor.
Have I screwed this up?  the guy at the store gave me these swabs after asking what type of camera I had.
I feel like I just need to get in there with a microfiber cloth or something & clean it up, but I'm obviously reluctant to do that.
How delicate is the sensor in a d800 really?  How can I get this thing clean?  I don't live anywhere near a place that could clean it for me.
 mactac's gear list:mactac's gear list
Nikon D800 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +3 more
Nikon D800
Nikonparrothead
Veteran MemberPosts: 4,563Gear list
Re: Help, did I screw up my sensor?
In reply to mactac, Jan 19, 2014
So you're saying these guys, I just saw on the Web don't exist anymore?
http://www.victoriacameraservice.com/
I can't make any suggestions other than that since I've never wet cleaned a sensor. The one time I accidentally did more harm than good (had some foreign matter on an Arctic butterfly brush) and added more stuff than I took out, I sent it out to a guy locally here in Florida who cleaned sensors (he used to work for a now defunct camera store -- I found him through word of mouth).
I've only seen microfiber cloths recommended for use outside the camera (again through google).
'Nice pen, bet you write good stories with it.'
 Nikonparrothead's gear list:Nikonparrothead's gear list
Panasonic Lumix DMC-TZ1 Canon PowerShot S95 Fujifilm FinePix X100 Nikon Coolpix A Panasonic Lumix DMC-LX100 +13 more
j_photo
Senior MemberPosts: 2,379Gear list
What cleaning fluid did you use? If VD Smear Away, you need to then use one of the other fluids to remove all residual film.
 j_photo's gear list:j_photo's gear list
Nikon D800 Nikon Df
InTheMist
Senior MemberPosts: 3,059Gear list
Get some different swabs. It sounds like maybe you had a drop of oily substance and you're just smearing it around.  Or the first swabs were bad.
Try swabs for oil, THEN normal ones.
It's more important how an image looks as a thumbnail than how it looks at 100%.
http://inthemistphoto.com
 InTheMist's gear list:InTheMist's gear list
Leica M-Monochrom Nikon 1 AW1 Nikon Df Nikon D810 Nikon 1 J5 +16 more
Astrophotographer 10
Senior MemberPosts: 5,973Gear list
In reply to Nikonparrothead, Jan 19, 2014
No you haven't damaged it. I think that is just the antireflection coatings smearing slightly when rubbed.
Microfibre cloth, some lens cleaner and a hurricane blower should do the trick. I had this happen on my Sony A7r which is the same sensor as D800. I also got concerned but Ive cleaned optics many times and I knew the coatings can sometimes smear like that. It will even out with some cleaner and mircofibre cloth.
I continued to rub mine down making sure there was no trapped grit that could scratch. It evened out pretty  well. Not 100% yet but thats not with cleaing fluid yet. I see no effect in the images though.
Greg.
 Astrophotographer 10's gear list:Astrophotographer 10's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Zeiss Batis 25mm F2 Zeiss Batis 85mm F1.8 +4 more
mactac
mactac OP
In reply to j_photo, Jan 19, 2014
I used the vdust plus
mlewan
Senior MemberPosts: 1,284Gear list
The only cleaning I do myself is with air. I do not dare touching the sensor with anything - not even blowing on it with my mouth. Even if exhaled air would not contain saliva particles, it is apparently slightly acidic, and than may damage sensors or lens coating.
What I use is a lens blower, like a Giottos Rocket Air Blower.
There are also canned air blowers like Beseler Duster. However, I have so far never tried any on my sensor, and I am not sure it is a good idea.
mactac
mactac OP
In reply to Astrophotographer 10, Jan 19, 2014
Greg.
So, how do I clean it with the cloth, just put it over my finger & start digging around down there on the sesor?
mactac
mactac OP
In reply to mlewan, Jan 19, 2014
Air definitely will not clean my sensor.  It's got streaks & what looks like a bit of a film on it in places.
Dennis Watts
Regular MemberPosts: 106Gear list
Don't use anything other than the swabs. If you got oil on the sensor it may take several. Be sure you follow the directions, and don't use too much fluid.
 Dennis Watts's gear list:Dennis Watts's gear list
Nikon D800E Sony Alpha 7R II Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF Fisheye-Nikkor 16mm f/2.8D +8 more
PenPix
Senior MemberPosts: 1,877
... it's good you resisted wiping it with a micro fibre cloth!  The actual sensor is actually under a AA and/or IR filter (sorry.. not exactly sure what glass is stacked atop the D800 sensor).  The sensor itself is not damaged, but to the IR filter could be scratched.  If you didn't press too hard with the swab and get a hard bit of dirt under it, I do not think there will be any permanent damage. The only way to know for sure is to have it professionally cleaned and have it checked for scratches.
I've used the Visible Dust swabs on my D200 sensor because I got tired of fixing all the black dots on my pictures. After the first go, I had streaks too and wondered if I made a judgement error in cleaning it myself.  After watching the tutorial video and reading the instructions several times over, my second attempt was perfect.
In the future, make sure you thoroughly clean your work area, were a short sleeve lint-free shirt, turn on a evaporative humidifier, and use a blower bulb and vacuum to clean inside the camera, before putting the swab on the sensor.  I wish that would have been recommended on the instructions.  That kind of attention to dust is what we used to do when handling negatives.
mactac
mactac OP
In reply to Dennis Watts, Jan 19, 2014
Well, I did use several already (and re-used a few, which it says not to do, but I was out of options).
I can't see how buying 4 more swabs ($25!) will get it any cleaner.  Every time I swipe it, it just leaves different streak patterns, and then dries, leaving residue all over it.
Joe Huckleberry
Regular MemberPosts: 126Gear list
I found that if I put too much fluid on the swab it would streak. Not sure if you are using pre-moistened swabs, but I found those to be far too wet. Going over the sensor/filter a second time with less fluid (and a new swab) has always got rid of the streaks, taking a second pass with the other side of the swab. I also pause for about 10 seconds to let the fluid absorb evenly into the swab before taking a pass over the sensor. But I use cleaning tools made by these folks http://photosol.com/, and not visible dust.
 Joe Huckleberry's gear list:Joe Huckleberry's gear list
Nikon D7000 Nikon D610 Nikon Df Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Nikon AF-S Micro-Nikkor 60mm f/2.8G ED +11 more
Robin Casady
Forum ProPosts: 12,898
I've been cleaning sensors for years.
I've been cleaning my cameras sensors for years (D2x, D700, D800E). For wet cleaning I use Copper Hill Images swabs, QuikStrips, and Eclipse liquid. They are effective and much less expensive than Visible Dust products.
QuikStips is a package of PEC PADs cut into swab-size strips for the pad on the swab. You use the swab over and over, but with a different QuikStip (one pass on each side and then change). Use 3 drops of Eclipse for each pad.
Don't scrub. Just use a lot of pads and the right amount of liquid.
When you are done with the pads there maybe lint left behind. This can easily be removed with a Nylon bristle cosmetic brush that has been properly prepared.
Clean the bristles very very thoroughly with dish soap.
Do the final rinse in distilled water.
Allow to thoroughly dry in a place where dust wont settle on it.
Test it on a very clean filter. If it leaves a smudge, wash it again.
See the Pixel Sweeper page for a complete discussion and instructions for selecting and preparing a brush.
When you have oil on the sensor it can take quite a few passes to remove it all. This is why changing pads is helpful.
I've not used the VD swabs, but you may be able to replace the pads with strips cut from PEC PADs, or QuikStips.
Probably not.
Resist that urge.
As you can see above, you are cleaning the first low-pass filter. It will have an anti-reflection coating. Some such coatings are oil-loving and difficult to clean. I don't know the specifics of the D800 OLPF coatings, but it seems oil-loving.
Robin Casady
http://www.robincasady.com/Photo/index.html
"The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts."
— Bertrand Russell
unknown member
(unknown member)
Re: I've been cleaning sensors for years. Great advice.....
In reply to Robin Casady, Jan 19, 2014
Probably not.
Resist that urge.
Robin Casady
— Bertrand Russell
That sounds like great advice. The couple of times I cleaned my D5000 sensor (have not had to clean my D300 sensor in the almost year I have had it (guess I should..     ), I used Eclipse and Pec pads, after blower brush.
Worked fine.
Amateur photographer. Enjoy.....believe in yourself..
 Bajerunner's gear list:Bajerunner's gear list
Nikon D300 Nikon AF-Nikkor 80-200mm f/2.8D ED +8 more
adventure_photo
Regular MemberPosts: 381Gear list
Stop using Visible Dust
I used to use Visible Dust fluid for a few years and always got frustrated by streaks. I feel like VD is not a good product. Leaves streaking even with a modest amount if fluid. I think it is formulated so that you must use $25 worth of swabs, or more!
Instead, invest in Pec pads, Pec swabs and Eclipse solution - all made by the same brand, Photographic Solutions. Eclipse works great and is an organic solvent that cleans dirt and oil. No streaking and works quickly and easily. I can also make my own swabs too by taking pec pads and wrapping them around older used swabs (after removing the old wrap). I use one to apply the solution and one to wipe and buff.
I know some will frown upon this, but the only way I was able to remove streaks from when I used visible dust fluid is to breathe a bit of moisture vapor from your breath onto the sensor and then use a swab to remove. Somehow the vapor helps to remove the streaks. Sometimes you have to go up and down as well as right to left, and you'll still have to do this a couple times to remove all the streaks. Sometimes blowing air softly while wiping helps to evaporate the vapor if there is too much.
Hope that helps. Cleaning the sensor is quite easy and a routine procedure needed on all sensors periodically.
Again, just throw away the visible dust stuff and get the Photographic Solutions brand products, they are way better. Then, no headache.
 adventure_photo's gear list:adventure_photo's gear list
Sony a6000 Sony Alpha 7 II Sony Alpha 7R II Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF Fisheye-Nikkor 16mm f/2.8D +20 more
soloryb
Senior MemberPosts: 2,039Gear list
DON'T clean a sensor with a microfiber cloth!
I just read some of the responses you've gotten about the use of a microfiber cloth directly on your sensor (actually that sensor is protected with a thin layer of glass which is what you're cleaning.)
DON'T DO IT! Sorry for shouting but it sounds like you're about to make an extremely damaging and costly mistake. Never touch a sensor with anything but a clean wet swab or a clean sensor brush. A microfiber cloth could contain minute particles and rubbing it on a sensor can scratch that glass layer - permanently. In fact you should never rub anything back and forth on a sensor. Even clean wet swabs should only be used in one direction with one wipe per side, never back and forth.
I've been wet cleaning sensors for many years using a variety of different wet cleaning kits and have experienced the same thing you did on a few occasions. I think it comes from accidentally picking up some lube from the mirror hinges (especially on a new camera) on either a sensor brush or a swab and then the swab just keeps spreading it out in streaks. Repeated wet cleaning will eventually remove the stubborn streaks, but can be costly if you buy your wet-clean supplies from most vendors.
Try Copper Hill. They are the best provider of wet-cleaning kits and related supplies. Their prices are also very reasonable and their kits and materials are first rate. You can also check their site for tutorials.
soloryb
 soloryb's gear list:soloryb's gear list
Fujifilm FinePix X100 Nikon D800E Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Fisheye-Nikkor 16mm f/2.8D +9 more
Schroedingers_cat
Veteran MemberPosts: 3,531Gear list
First, it's unlikely that you have actually caused any damage.
Second, rubbing with a micro fiber cloth CAN cause damage.
Third, it sounds to me like you are using too much liquid.
Fourth, reusing a swab might make it worse.
I have no personal experience with any of the products other than Sensor Swabs and Eclipse.  Available from Photographic Solutions and several others.  I have never had the slightest hint of a problem, but when I first started I was very inefficient and used more swabs than necessary.  There is a learning curve.  I also tended to use too much liquid.  I now use a max of two swabs.
My suggestion is that you purchase these products, read, understand, and follow the instructions carefully, and expect to burn up more swabs than you want.  If $25 seems like more than you want to spend on sensor cleanings supplies I suspect you will be disappointed, cleaning is expensive.
Somewhere you will likely have a local camera store that will clean it for around $35.
Don't use the microfiber cloth.
www.nightstreets.com
One day long ago, a sorcerer and a warrior did battle, as such things were commonplace in that age. Sometimes the sorcerer won, and the sum value of human abilities was improved some trifling amount. Sometimes the warrior won, and again the human race improved by some insignificant amount, for a sorcerer who can't defeat one miserable warrior is a poor sorcerer indeed.
user_name
Veteran MemberPosts: 3,127Gear list
NEVER Use Canned or Compressed Air!!! (nt)
 user_name's gear list:user_name's gear list
Leica M8 Nikon D700 Nikon D800 Leica M Typ 240 +1 more
j_photo
You just need practice. Maybe fewer drops on the swab. Four swabs is not enough, especially when you are first learning.
Also, at first I did find the larger FF sensor a little more difficult to do a good job on compared to my DX sensor second body.
Nikon D800 Nikon Df
