Exposure
Started Jan 19, 2014 | Questions
Trazan Regular Member • Posts: 121
Exposure
I'm curious...how do you prefer to expose a e.g. "dark" scene when ISO is the difference? Do you expose it "full" (as long as highlights are not clipped) and reduce exposure in post, or adjust in camera on the spot?
Did anyone compare resulting noise from reducing exposure in camera vs doing it in post?
 Trazan's gear list:Trazan's gear list
Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 50mm f/1.8D Nikon AF-S Nikkor 24mm f/1.4G ED Tamron SP 90mm F2.8 Di VC USD 1:1 Macro (F004)
VertigonA380 Senior Member • Posts: 1,133
Re: Exposure
It's too long to explain here but if you understand how a CMOS sensor handles brightness information, then you will expose to the right. As much as 50% of the information can be retained in the brightest stop all the way down until the shadows have minimal information retained in them. As you can see, it doesn't average exposure information like you might expect. This way you bring up the shadows in PP. This applies to low light exposure and not to middle exposure scenes. Look up "exposing to the right" and more than likely you will find some information.
samjstern
samjstern Veteran Member • Posts: 6,791
Re: Exposure
http://www.cambridgeincolour.com/tutorials/digital-exposure-techniques.htm
I gave you a link with some info to read.
ETTR is not always the correct way.
It is somewhat more involved than always exposing to the max.
 samjstern's gear list:samjstern's gear list
Nikon D70s Nikon D750 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G +10 more
Re: Exposure
That link itself says:
Advantages:
  • Maximizes the number of tones recorded.
    Note: many recent digital SLR cameras have RAW files which record tones with 14-bit precision, so this is less of a factor than it used to be. It is highly unlikely that a RAW image will have insufficient tones (and become posterized) as long as it isn't grossly underexposed.
The OP is talking about low light, and exposing to the right is the right way in low light with RAW. If in doubt take an identical picture with different exposures and then pull out the shadows in PP. Crop in for noise and it will leave you with no doubt.
Trazan OP Regular Member • Posts: 121
Re: Exposure
How about if I'm convinced I don't need more dynamic range into shadows? From the link posted:
ETTR:
Requires more light than normal, and potentially a higher ISO speed
(which could mitigate any reduction in image noise from ETTR).
Exposing "dark":
Requires less light than normal, potentially enabling a lower ISO speed
(which would offset any increase in image noise).
So...exposing to the right/lighter areas gives less noise, but the use of higher ISO mitigates that.
Exposing darker results in more noise, but the use of lower ISO offsets this increase.
Assuming the resulting noise is equal I'd definitely chose ETTR. However I'm a bit unclear on whether plain reduction of exposure in post will equalize the gain/noise applied from higher ISO...
Scott McMorrow Regular Member • Posts: 366
Re: Exposure
ETTR:
Exposing "dark":
Here's a simple rule of thumb to maximize dynamic range and noise for most recent Nikon sensors:
For D800/D6x0/D7x00/D5x00  Expose to the right up to ISO 1600.  Above that, leave ISO at 1600 and adjust in post.  If using AutoISO, set the maximum ISO to 1600 and be aware of this during your photography.  When AutoISO approaches 1600, be sure to use manual aperture and shutter speed settings to maintain better control of DOF and blur.
In general, ETTR in the ISO range where the sensor is using Analog gain.  Above that range, where digital gain is used, perform your final exposure adjustments in post processing.
Re: Exposure
It's not intuitive but its about the way the sensor handles information, and how you can use that information to push more detail into the shadows, in low light. Unless you read about it, you won't understand it and unless you try it, you won't believe it. As for adjustment in camera vs post it, RAW does not hold extra unseen pixels, it just doesn't suffer the JPEG suppression.
olakiril2 Contributing Member • Posts: 639
Re: Exposure
Shooting under dark conditions with moving subjects and unpredictable light, ETTR will often give me blurred shots and clipped highlights. That is why in dark conditions I ETTL, but that's just my shooting method.
ETTR is very useful for static subjects with a tripod and well thought metering.
14bit vs 8bit makes a huge difference. Unless you try it, you won't believe it.
InTheMist
InTheMist Senior Member • Posts: 3,077
Re: Exposure
I usually just try to get it right in-camera. As I prefer my night scenes to be dark, I add negative exposure compensation.
I only use expose-to-the-right when I know the scene is going to be a exposure challenge.  Street lights are going to be blown, it's ok.
An advantage of not overexposing is that you keep a higher shutter speed.
It's more important how an image looks as a thumbnail than how it looks at 100%.
http://inthemistphoto.com
 InTheMist's gear list:InTheMist's gear list
Leica M Monochrom (Typ 246) Leica M-Monochrom Nikon 1 AW1 Nikon Df Nikon D810 +18 more
Re: Exposure
Scott McMorrow wrote:
ETTR:
Exposing "dark":
Thanks, good to know! Disregarding dynamic range, could I apply the same guidelines to jpeg and video capture, noise wise?
Re: Exposure
I was referring to static objects and referring to the way information shifts during RAW processing and yes there is a massive difference for greater bit depths.
As for generally exposing a shot in low light, I like to bracket when possible. Getting it best in camera is a great idea although these days I PP anyway, getting it right just gives me more latitude in Photoshop.
Re: Exposure
So then, it seems to me for the D800/D6x0 that the process which maximizes creative control, dynamic range and noise is:
  • manual control of shutter and aperture
  • Auto ISO to 1600
  • Exposure compensation to control highlight overexposure
  • let the camera underexpose once AutoISO hits 1600
