recommend a wide zoom for d600
Started Jan 18, 2014 | Questions
mikeysaling
Regular MemberPosts: 353
Jan 18, 2014
To be also used on d7100 but mainly 600 need a sharp wide zoom for artitectural and landscape.
Nikon D600 Nikon D7100
mlewan
Senior MemberPosts: 1,284Gear list
Re: recommend a wide zoom for d600
In reply to mikeysaling, Jan 18, 2014
Obvious choice: 14-24mm f/2.8. To some people that lens is probably the main reason to have Nikon instead of Canon.
There are other options as well, but none that appeals to me. If size and weight is an issue, you may want to consider some prime instead.
AEPA
Regular MemberPosts: 278Gear list
In reply to mlewan, Jan 18, 2014
mlewan is 100% correct, hands down the 14-24 f2.8 is the lens to get if you want a sharp wide zoom.
If you cant afford it right now save and wait its worth it!!!
 AEPA's gear list:AEPA's gear list
Nikon Coolpix S6000 Nikon 1 V1 Fujifilm X-E2 Nikon 1 V3 Nikon 1 Nikkor VR 10-30mm f/3.5-5.6 +8 more
George Paulides
Contributing MemberPosts: 998
In reply to AEPA, Jan 18, 2014
The 18-35mm G represents good value - not as sharp as the 14-24mm but a fraction of the price.
sd40
Senior MemberPosts: 1,483Gear list
Here we go again.
Start by reading other recent threads on this topic and you will find that it is by no means obvious that the 14-24 is the best choice to meet your needs, starting with the fact that it does not accept screw-in filters.
The 16-35 has many satisfied users (including me), and the 17-35 and 18-35 have their advocates as well.  And that's just the Nikkor options.
It pays to read the previous threads.
 sd40's gear list:sd40's gear list
Nikon D750 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Fisheye-Nikkor 16mm f/2.8D Nikon AF Nikkor 105mm f/2D DC Nikon AF-S Nikkor 85mm f/1.4G +9 more
mikeysaling
In reply to sd40, Jan 18, 2014
Hi SD40 - did try to locate similar but couldn't find anything - sorry to have inconvenienced you but many thanks to the useful responses.
sd40
I'm not inconvenienced. I would like to see you derive the full benefit of the knowledge around here.
This thread, for instance--current, right now:
http://www.dpreview.com/forums/thread/3609264
mikeysaling
Hi - thanks for that link - seems a bit plus and minus on the 16-35 but having checked a couple of reviews i'm warming to it . I have a tokina 11-16 which I am very disappointed with - seems very unsharp and suffers CA . cannot get it sharp on distant objects or even close objects (tree branches are always a bit blurred) the 16-35 Nikon looks good from the results I have seen - more comment please.
user_name
Veteran MemberPosts: 3,128Gear list
Nikkor 14-24mm
In reply to mlewan, Jan 19, 2014
+1
Architecture and landscape are what this thing excels at.
 user_name's gear list:user_name's gear list
Leica M8 Nikon D700 Nikon D800 Leica M Typ 240 +1 more
user_name
In reply to mikeysaling, Jan 19, 2014
16-35 has issues at either extreme of the zoom range.
At 16mm it is distortion.
At 35mm it is going soft.
You also have a penalty of f4.  While you may stop down to f8 or more, your camera opens up the aperture as wide as it gets to focus.
For the 14-24mm that is f/2.8.  For the 16-35mm that is only f/4, which the VR can not fix.
The 14-28 does have an issue with focus shift between f/2.8 and about f/5.6, but sharp across the corners at almost any zoom range and very low distortion.
As said before, everything has its price, so you really need to understand all of the limitations of each lens and what it is good at.  You also need to know what it is you really need.
mikeysaling
In reply to user_name, Jan 19, 2014
Thanks for that review - what i'm after is something competent for building exterior/interior and some landscape. sharp is a must .-.
