Nikon 500mm or Sigma 500mm lens for safari?
Started Jan 18, 2014 | Discussions
systemguy Contributing Member • Posts: 857
Hello
I wish to know if anyone can comment on the performance of the above lenses at wide open aperture (f4 vs f4.5).  The application would be for a safari.  There is a saving of about $2000 in price and is it worth it?
Or is the difference in performance of the Nikon significant with the D800?
 systemguy's gear list:systemguy's gear list
Canon EOS 5D Mark II Canon EOS 20D Nikon D800 Nikon D810 Canon EF 15mm f/2.8 Fisheye +17 more
Nikon D800
Rory Veteran Member • Posts: 3,227
Re: Nikon 500mm or Sigma 500mm lens for safari?
Get the Nikon.  I don't know anyone who has purchased the sigma that has not later "upgraded" to the Nikon.  For a safari you should consider the 200-400...
Rory
Alan Brown
Alan Brown Veteran Member • Posts: 4,634
the perennial Qs... is it worth it?
systemguy wrote:
Hello
this question is part and parcel of the compromise that is photography and more money available doesn't make the dilemma any less of a compromise. f2.8 zoom = more weight etc. Looking at your gear list you know this.
Some questions presuming the Nikon is probably better in all respects:
How often will I use it?
Can I get the most out of the Sigma, let alone the Nikkor?
Am I or other viewers going to be able to 'see' the difference that the price increase is going to cost?
you probably found this already.
http://www.thephoblographer.com/2013/09/01/review-sigma-500mm-f4-5-ex-dg-apo-nikon-f-mount/
my 2 cents
There is a very fine line between 'hobby' and 'mental illness.' :'!':
 Alan Brown's gear list:Alan Brown's gear list
Nikon D3200 Nikon D610 Tamron SP 70-300mm F/4-5.6 Di VC USD Nikon AF-S Nikkor 50mm f/1.8G Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR
JimPearce
JimPearce Veteran Member • Posts: 8,737
The Sigma is only a touch less sharp than the Nikkor. Remember though, it won't autofocus with a 1.4x converter (It seems to be disabled in firmware). Personally I'd use my 300 f2.8 VR plus TCs for a safari and leave my 500 f4 at home. But I shoot DX.
Jim
 JimPearce's gear list:JimPearce's gear list
Nikon D7100 Nikon D500
calson Veteran Member • Posts: 7,295
Don't assume that the Nikon teleconverters will work with this Sigma lens. It may or it may not and that would result in two sets of teleconverters.
I don't know about the Sigma but I recently purchased the Nikon and it is incredible with all three Nikon teleconverters. The autofocus and image quality is good even with the 2x so it becomes a very usable 100mm f8 lens (and there are several cameras now with f8 AF sensors like the D800 and D7100).
With the Nikon lens I truly have a 500mm f4, 700mm f5.6, 850mm f6.3, and 1000mm f8 set of lenses and need only deal with the added weight of 3 teleconverters.
With the Sigma lenses I would be more inclined to buy or rent the 150-500mm f5.6~6.3 lens or take/rent the Nikon 80-400mm f4.5 or 200-400mm f4 zoom lenses. You don't want to be changing lenses while out shooting and zooms are an option over carrying two cameras (and even then I would have the 70-200mm on the backup camera).
jjnik Senior Member • Posts: 1,319
systemguy wrote:
Hello
If it's just one safari, why not rent?  It would take a lot of rentals to come remotely close to the cost of purchasing.  Do you have other, frequent uses in mind that would justify buying one?
