Sold all Canon gear - want to switch to Nikon, need some suggestions please.Thanks
Started Jan 17, 2014 | Discussions
volodyalysak New Member • Posts: 4
Hi guys i'm new to forum but not new to DSLR world. Had some Canon gear over last 5 years, but nothing really valuable, so sold it all and now trying to decide what to buy and which way to go from scratch, any comments/suggestions greatly appreciated.
About me: amateur photographer (Landscapes,people,kids, macro, night, low light photography)
Gear that i had
2008 to 2011
Canon 350D (Rebel XT)
Sigma 24-70 2.8 EX DG macro
Canon 50mm 1.8
Canon 430 EX II sppeddlight
2011 -2014
canon t1i (500d)
Canon 50mm 1.8
Seems like 60-70 % of my pictures were constantly out of focus or to soft.
I tried different setting and always shot with AV TV or M modes, and i know what setting to use and where, seemed like on the bright day closeups everything worked as it should but in lower contrast or with flash all my pictures got to soft/washed out. So i just got tired of it and decided to start all over with DSLR photography.
lets say my budget is around 2000$ all together for a new setup.
At this point i'm not sure if i should go FX or DX route. Looks like i can get used d600 with tamron 24-70 2.8.  Or go DX let say Nikon d7000 with nikon 17-55 2.8 and new flash.
Or i can go canon route   let say:
used 5d mkII with canon 24-105 F4  for around 2000$
new canon 70d with canon 17-55 2.8 for around 2000 $
I would like to have:
fast and acurate focus Lens+body combo
good low iso performance
good dynamic range
and sharp images in all conditions
sapple
sapple Regular Member • Posts: 420
Re: Sold all Canon gear - want to switch to Nikon, need some suggestions please.Thanks
Buy a used D7000, a tokina 11-16 and a sigma 17-70 and a tamron 70-300.
That camera with those 3 lenses will cover a full range for you and should do great and scrape in just under your budget assuming you buy used equipment in excellent condition. If you don't own one you also need a tripod which could explain a lot of your nature and macro pictures being blurry.
Good luck!
 sapple's gear list:sapple's gear list
Nikon D5200 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR Nikon AF-S DX Nikkor 35mm f/1.8G Tamron SP 70-300mm F/4-5.6 Di VC USD Sigma 17-70mm F2.8-4 DC Macro OS HSM +7 more
Westmill
Westmill Senior Member • Posts: 1,335
I would go with the D7100 and sigma 18-35 F1.8 if you can stretch that far
 Westmill's gear list:Westmill's gear list
Nikon D810 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Micro-Nikkor 60mm f/2.8G ED Nikon AF Nikkor 85mm f/1.8D Nikon AF Nikkor 105mm f/2D DC +2 more
PepsiCan Contributing Member • Posts: 739
Re: Critical note
You do realise that that has much more to do with the photographer and not so much, if at all, with the equipement, right?
 PepsiCan's gear list:PepsiCan's gear list
Canon PowerShot S95 Adobe Photoshop Lightroom 4 Nikon D7100 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G +5 more
mike geier
mike geier Senior Member • Posts: 1,286
Nikon 7100
Nikon 24-85
Toshiba 18-270
Nikon 50mm f1.8
perfect setup
 mike geier's gear list:mike geier's gear list
Sony Cyber-shot DSC-HX50V Sony Cyber-shot DSC-RX100 III Sony Alpha NEX-7 Sony Alpha 7R Sony a6000 +16 more
s_illes79 Regular Member • Posts: 159
Gear that i had
2008 to 2011
Canon 50mm 1.8
2011 -2014
canon t1i (500d)
Canon 50mm 1.8
good dynamic range
I also had the Canon 350D for 5-6 years, had focus issue, specially in low light.
Upgraded to D5300 which is far superior to it by any means.
First got the Sigma 17-70, but sent it back:
It's not good for landscapes, corners are horribly soft from 17-28 mm at any aperture.
For landscape the new 18-140 seems much better choice, at least for me ( need to correct distortion, but camera can do it ) or u could get the 16-85 for 2x price
Also have the 50mm f1.8 which is the best lens i have ever owned
 s_illes79's gear list:s_illes79's gear list
Fujifilm X-T1 Nikon AF-S Nikkor 50mm f/1.8G Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm 1:2.0 NCS CS
Nexu1 Senior Member • Posts: 2,586
Re: Critical note
PepsiCan wrote:
+1
I don't think the original poster is going to get vastly superior results by switching equipment.
That said, as someone who has been itching to go full frame for a while and analyzing (and over analyzing) my options, I wouldn't recommend full frame for the OP either.  FF is much more expensive, the D600/610 (and I wouldn't buy a D600 because of the oil splatter) is basically double the price of the D7100/D7000.  The lenses are more expensive too.  If you aren't kicking butt with a crop sensor and getting your skillset & technique really refined you might as well not waste your money on FF IMO.
For budget conscious users looking for DX I would frequently recommend D5100/D5200/D7000, 18-105mm and the three f1.8 primes 35/50/85 (and buy refurb body or 18-105 if you can find them).
DukeCC Contributing Member • Posts: 532
Seems like you would appreciate having the D7100 over the D5300, though the D5300 has a great sensor and produces great images.
And I would strongly recommend the D7100 over the D7000. The autofocus is apparently much improved.
Consider a Nissin or Yuongo iTTL speedlight as a budget stretcher.
Can't go wrong with the Nikon 'Nifty 50', as noted above.
That leaves a standard zoom. I would say do not overlook the Nikon 18-105 kit lens. Excellent for the price, but of course there are better options.  For DX, I feel one needs something a little wider--the 24-70 range ends up being a little long to suit me.  18-140 makes a lot of sense.  18-200 is great, at a little lower 'image quality' IMHO.
 DukeCC's gear list:DukeCC's gear list
Nikon D200 Nikon D7000 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR Nikon AF-S Nikkor 50mm f/1.8G +5 more
volodyalysak OP New Member • Posts: 4
Re: Critical note
I DO know that, but it is to the point that i think i need some refreshment .  I'm not bad photographer, just not happy with majority of my photos. New gear helps :)) I HOPE
Re: Critical note
I lean more toward nikon d7000 vs d71000 because i can get it for 300$ cheapper than 7100. And than get some sigma lens
SamG10 Regular Member • Posts: 310
You'd be happy with either D7100 or D5300.  The 18-140 lens will pair very nicely too.  I have the d5300 and this lens as a walkaround  setup.
 SamG10's gear list:SamG10's gear list
Nikon D40X Nikon D1X Nikon D4 Nikon D800 Nikon AF-S Nikkor 24-70mm f/2.8G ED +11 more
johnbachel Regular Member • Posts: 431
I'd suggest D7000 with 18-105 or 18-140, plus primes, or Sigma 17-50 f/2.8 for low light photos.   Also consider a flash - perhaps the Nikon SB-600 or SDB700, or a Nissin Flash if on a budget.
If you have the resources, the D7100 is a nice upgrade, but not essential.  Note that there are live view issues with the Sigma 17-50/D7100 combination.
 johnbachel's gear list:johnbachel's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 Olympus 12-40mm F2.8
Stacey_K
Stacey_K Veteran Member • Posts: 7,864
Interesting my copy of the 17-70 is so sharp across the field, even at 17mm, I sold my 16-85. The 16-85 is simply an overpriced slow zoom.
Stacey
 Stacey_K's gear list:Stacey_K's gear list
Nikon D200 Nikon D700 Nikon D7000 Nikon D800 Sony Alpha 7 +14 more
Stacey
Which version do u have? C or the older one? What I heard is the new one is soft at wide and sharp at telephoto, but old was oposite:  sharp at wide but soft tele ( soft I mean off center )
Digirame Forum Pro • Posts: 32,414
Re: Critical note
Looking at your past gear, you are ready to upgrade.  I'm using Canon and Olympus DSLR cameras.  99% of my photos are sharp, maybe because I step down my lenses a lot, I hold my cameras steady, and have enough shutter speed.  I like looking at the Nikon equipment too.  They got some good stuff.
From what I read, the Nikon D7100 or Canon 70D might be good choices for you.  Canon's STM lenses work well for video with the Canon 70D.  I'm not sure what lenses might be good choices for the Nikon D7100.  Just get some good ones that aren't expensive and upgrade the lenses in a year or two once you are familiar with the cameras.  That's what I would do if I was in your shoes.
Stacey_K
Stacey
New type and by f5.6 (reasonable landscape aperture) at 17mm it's sharp across the frame. F2.8 corners aren't great but at f4 it isn't bad. Lots of people seem to "have heard" the new one is soft at 17mm, mine isn't and photozone didn't think theirs was either.
http://www.photozone.de/nikon--nikkor-aps-c-lens-tests/822-sigma1770284os?start=1
Now look at how the 16-85 performs wide open, f3.5 at 16mm, it's the same as the 17-70 at f2.8. You have to stop the 16-85 down to 5.6 to get decent corner performance too. Yet look how bad this lens performs on the long end plus the bokeh is simply nasty looking.
http://www.photozone.de/nikon--nikkor-aps-c-lens-tests/635-nikkor16853556vr?start=1
This is a shot out in front of my house when this subject of this lens ve 16-85 came up. I wanted to shoot an identical scene so shot tow frames on a large tripod. The corners at 17mm sure aren't "horribly soft at any aperture"...
This other was shot with a 16-85 and IMHO the corners are soft on that overpriced lens. And has horrid CA, look at the back lit branches in the top of the frame. Add in almost useless at 85mm, is a stop slower, has ugly bokeh AND is 2X the price. Like I said, it's an overpriced slow zoom.
Stacey
After reading for couple of days i'm still can't decide what to get. I came down to couple combinations so far, please pick what you like the most
1: Nikon d7000 + Sigma 17-50 2.8 + Nikon flash sb700  all together around 1400 $
2: Nikon d7100 + Sigma 17-50 2.8 - no flash around 1400$
3. Nikon d7000 + Nikkon 17-55 2.8(used)  1400 - 1600 $
And do i want to get d7100 ?? Is not having low pass filter and having 24 Mp instead of 16mp in d7000 makes a lot of difference ??? I would better spend price difference on better lens.
Stephan K Regular Member • Posts: 132
Direct answer to OP:
D7100
Nikoon 18-105mm (I have it, don't underestimate, very good performance for the price)
Tokina 11-16mm (I have one, according to my research the best WA zoom)
Decent tele zoom: at this budget you are stuck with the Tamron 70-300 or Nikon 70-300, and you will be dissatisfied with both after a few months.
Better set-up:
Back to the dark side, Canon 70d
18-55 or 19-135 STM (great lenses, manufacturers seem to have secret sauce for recent lenses, better than Nikon 18-105)
Tokina 11-16mm
And the opportunity to get a professional-quality tele zoom in the 70-200mm f4 IS (Photozone "the sharpest Canon zoom we have ever tested")
I have had most of the above, and can vouch for their perfomance-to-price.
A cropped pic with the 70-200 F4 IS at 10m
Westmill
I would just say that if you intend on using any zoom like the 18-140 you might as well get the D7000 as these lenses are just not good enough for the D7100. Lenses are always a better investment anyway. As such.. get the D7000 and a top lens
calson Veteran Member • Posts: 7,393
With a $2000 budget you will get a more complete kit with DX along these lines
New D7100 for $1100
New Tamron 28-75mm f2.8 at $499 or or a Used Nikon 17-55mm f2.8 $700
New SB-700 flash $327
The D7100 will provide excellent results up to ISO 6400 for people photography and the autofocus is somewhat better than that of the D600/D610 thanks to the same number of AF sensors covering more of the viewfinder area. I see this difference with my D7100 and D800 cameras.
With FX lense the cost will be 50% higher and so will be the size of the lenses and the weight of the lenses.
Where people go wrong with DX cameras is in buying the kit lenses or the ones with large zoom ranges of 6:1 or even 10:1 and then comparing them to FX cameras using FX zooms with 2:1 or 3:1 zoom ranges. Not an apples to apples comparison.
Nikon's autofocus for its cameras is on the whole a good deal more accurate than that of Canon cameras. It is the aspect of Nikon performance that is most often commented on by people making the switch from Canon.
