Wide angle macro solution for DX body?
Started Jan 17, 2014 | Questions
szhorvat Regular Member • Posts: 268
I was thinking about the feasibility of doing wide angle macro photography (say, around 1:2 reproduction ratio) with a DX body. Has anyone here done anything like this? If yes, what kind of setup did you use, or what setup (lens) would you suggest?
I am thinking of photos which don't only include the subject but also a distant background. I have the 60 mm f/2.8 (non-D) lens, which is very nice for closeups of tiny things, but the 22 degree field of view makes it impossible to include a background.
I'm not aware of a macro lens wider than 40 mm for Nikon, so the solutions I can imagine are
1. A screw in "closeup filter" -- I'm really not sure about this and how well it would work on a wide lens. Which
2. Extension tubes
3. Get an old non-Nikon wide lens and an adapter, and hope that since the lens is necessarily further from the sensor on a Nikon body it'll allow me to focus close enough and will still give a good enough quality. Which lens would be suitable?
I was thinking of (3.) because I'm looking for a budget solution (i.e. not more than what the 60 mm lens cost me). Solution (2.) likely wouldn't be cheap because it requires extension tubes that work with G lenses: the only wide ones I have are the 18-55 mm and the 35 mm f/1.8 (probably not wide enough).
So, do any of you have first hand experience with something like this and can you offer advice on how to do it best or post some photos you made?
Stacey_K
Stacey_K Veteran Member • Posts: 7,869
Re: Wide angle macro solution for DX body?
Going to a wide angle lens isn't going to include the background, it still going to be out of focus at 1:2. It's not going to increase the DOF near the focus plane either, just shorten the camera to subject distance.
Stacey
 Stacey_K's gear list:Stacey_K's gear list
Nikon D200 Nikon D700 Nikon D7000 Nikon D800 Sony Alpha 7 +14 more
Jobber56 Regular Member • Posts: 146
Stacey
In other words, there's no such thing as a wide angle macro.
szhorvat OP Regular Member • Posts: 268
Stacey
This is clearly not correct.
If you google for it , you'll find plenty of examples. Also, have you seen BBC's Life in the Undergrowth? They have lots of shots with Attenborough being visible behind a bug. The background is going to be a bit blurry, yes, but still visible and adding a lot to the image. With a longer lens you typically get a solid blur only, and no visible detail: you can't make out a field or a mountain or a tree in the background. With wide angle it's possible.
Sonyshine
Sonyshine Senior Member • Posts: 7,839
I have used the Sony 30mm macro lenses on NEX and SLT cameras. They do give a wide view but even at quite small apertures the background is still fairly blurred out when the focus is up close.
Here is a set on Flickr which may help your decision process.
http://www.flickr.com/photos/thekrankis/sets/72157634730827839/
I also recently begun to use the 40mm Nikon micro lens on my D3200 and V1 cameras:
http://www.flickr.com/photos/thekrankis/sets/72157639691716003/
Its a great lens but not really wide angle as you say.
An alternative may just be a wide angle lens?
Many are capable of quite close focusing - not macro - but close.
 Sonyshine's gear list:Sonyshine's gear list
Nikon 1 V2 Nikon 1 J5 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor 10mm f/2.8 Nikon 1 Nikkor 18.5mm f/1.8 +7 more
_sem_ Veteran Member • Posts: 4,756
szhorvat wrote:
DOF will get quite narrow at higher magnifications. But the wide angle tends to produce an impression of more depth than what DOF says because the background is less blurred relatively. I mean, it is blurred in absolute terms (distances), but it doesn't look so blurred because a wide angle of the background is in the frame and the blur angles are small.
Well, there indeed doesn't seem to be a dedicated wideangle macro lens. But one surely can use ordinary wide-angle lenses, even kit zooms @WA, on relatively short extension (add-on diopters possible too, but need to be thick high diopters).
On extension, the magnification doesn't seem to reach 1:1 macro; around 1:2 or 1:3 seems to be achievable before the focus plane hits the glass (probably this is why no dedicated macros). Please correct me if you know a WA lens that goes to 1:1.
The relatively thin extension is another problem. The thinnest ring for Nikon is the old K1, totally manual, safe on the camera but very tight on the lens electric contact block. Too much extension, and the background may be blurred more than desired.
Mind the image quality on extension is another question. Manufacturers could provide a longer helical for closer focus, but usually restrict it to a point deemed acceptable by their standards. In certain lenses, the focus limiter may be shaved to allow a bit closer focus and higher magnification.
Some examples:
http://www.dpreview.com/forums/thread/3041926
http://www.dpreview.com/forums/thread/3034839
Westmill
Westmill Senior Member • Posts: 1,336
There are just two solutions here. One is a thing called focus stacking ( google it )
The other would be using a lens like the samyang fisheye. Although not what I would call macro.
It will of course focus much closer with a huge amount of DOF. This is about the closest thing Ive got though lol.
You can of course use it with cheap extension tubes
 Westmill's gear list:Westmill's gear list
Nikon D810 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Micro-Nikkor 60mm f/2.8G ED Nikon AF Nikkor 85mm f/1.8D Nikon AF Nikkor 105mm f/2D DC +2 more
The Nikkor 10.5/2.8 fisheye focuses to mere 3 cm in front of the lens (tough to get good light if one goes closer), magnification about 1:10 I recall.
The Samyang 8/3.5 doesn't focus as close but I hear it can be modded. A thin enough extension tube isn't feasible I guess.
There are also peculiar setups involving small-format WA or fisheye lenses on tubes containing relay optics, for instance here:
http://www.koheisha.net/microwidelenz/musinomekakakukousei/e-musinomelensomonasystem.html
Gibbosa Regular Member • Posts: 165
szhorvat - I can't help you from a personal perspective, not having done this, but I can refer you to a young South African professional called Shem Compion who has. I've attended a workshop with him in Cape Town and he's excellent. One of his books which you need to check out is called 'A Landscape of Insects and other invertebrates' - it's exactly what you're looking for. I can't comment on DX or FX, etc., but Shem seems to be the kind of 'tog that you could email directly to get your answer. You can find out more at www.shemimages.com.
Hope that helps - and good luck!
Chris
sapple
sapple Regular Member • Posts: 420
Westmill beat me to it. You are looking for focus stacking.
<a href="http://www.applenegative.com" target="_blank" title="www.applenegative.com" data-mce-href="http://www.applenegative.com">www.applenegative.com</a>
 sapple's gear list:sapple's gear list
Nikon D5200 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR Nikon AF-S DX Nikkor 35mm f/1.8G Tamron SP 70-300mm F/4-5.6 Di VC USD Sigma 17-70mm F2.8-4 DC Macro OS HSM +7 more
