Explain this! (Adapted lenses)
Started Jan 15, 2014 | Discussions
tjdean01
Senior MemberPosts: 2,213Gear list
Jan 15, 2014
I was told by members of this forum that we can't adapt older 50mm 1.8 lenses to a D5100 because the space for the mirror leaves no room for adapters like on a mirrorless. I told my friend & she was sad. Today, however, she sends me a pic of her D5100 with an old Minolta 50mm on it! And I asked her how she likes the appx 80mm focal length but she replied that it's more like 35mm. She said there is an adapter in there too and paid like $50 for lens & adapter. SHE doesn't know what she did, but I'm guessing she bought some sort of modified lens? I'm confused!
(Pics to come...I'm on the cell phone)
sapple
Regular MemberPosts: 420Gear list
Re: Explain this! (Adapted lenses)
In reply to tjdean01, Jan 15, 2014
I am not sure who told you that you can't use old glass on the 5100 but they were just wrong. I use both pre-Ai and ais lenses in my d5200 on a regular basis. The rules about focal length still apply though since that has to do with the image sensor. Lenses that can meter old glass like the 7100 need Ai or ais lenses, but non metering cameras can use anything except for invasive fisheye lenses.
<a href="http://www.applenegative.com" target="_blank" title="www.applenegative.com" data-mce-href="http://www.applenegative.com">www.applenegative.com</a>
 sapple's gear list:sapple's gear list
Nikon D5200 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR Nikon AF-S DX Nikkor 35mm f/1.8G Tamron SP 70-300mm F/4-5.6 Di VC USD Sigma 17-70mm F2.8-4 DC Macro OS HSM +7 more
ZorSy
Veteran MemberPosts: 3,350Gear list
Hope your picture will explain it - in meantime, just as a wild guess it may be one of those WA adapters you screw on the front of the  lens (Raynox or whatever the brand name) which would explain how FF 50mm becomes 35mm on DX. ... we'll see. Nikon F mount is (unfortunately) one of the mounts that is hard to adapt other SLR lenses to.
 ZorSy's gear list:ZorSy's gear list
Nikon D80 Nikon D7100
MRM4350
Senior MemberPosts: 1,835Gear list
In reply to tjdean01, Jan 16, 2014
I'm sorry that the first two responders did not read your Original Post.
I'm not interested in using other lens mount lenses on my Nikons, but I think the problem is the lens 'registration distance' that Nikon uses is longer than other brands so adapters have to have glass elements included to get the focus correct. This extra glass elements gets in the way of focus at infinity, and my cause the lens to give a different field of view.
 MRM4350's gear list:MRM4350's gear list
Nikon D90 Nikon D7000
Steve Bingham
Forum ProPosts: 23,122Gear list
I'll try. :)
In reply to MRM4350, Jan 16, 2014
What lens? An F mount is an F mount - but, depending on age, some functions may not work. As the D5100 has no lens motor, you need a motorized lens in order to focus automatically. This should help enormously: http://imaging.nikon.com/lineup/dslr/d5100/compatibility02.htm
If you are talking other company lenses, it becomes a real crap shot, adapter or not. Minolta to Nikon? WHY!!!! Even if possible.
Steve Bingham
www.dustylens.com
www.ghost-town-photography.com
 Steve Bingham's gear list:Steve Bingham's gear list
Nikon D7200 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Sigma 17-50mm F2.8 EX DC OS HSM Tokina AT-X 12-28mm f/4 Pro DX +16 more
eddyshoots
Senior MemberPosts: 2,174
Couple of explanations
Using adapters on Nikon cameras is difficult because Nikon has one of the longest register distances out of the major manufacturers (this is the distance from the mount to the film or sensor). You can use an adapter and mount an old Canon or Pentax or Minolta on your Nikon camera, there's nothing to stop you. Unfortunately, you lose the ability to focus on far away objects. Depending on the difference between the two lens registry distance you might lose the ability to focus on an object just 20 or 30 feet away.
Some adapters will use a corrective lens built in. With the corrective lens you regain the ability to focus to infinity. But you might lose a fair bit of sharpness as the extra piece of glass isn't necessarily designed for the lens.
Some adapters are built for medium format lenses. Medium format cameras have an even bigger registry distance than Nikon so there is no problem using an adapter. Not sure if Minolta produced any medium format lenses. On a D7xxx or D300 you would even be able to meter with the adapted lens.
So there you go, three explanations that might just fit. No infinity focus, corrective lens or medium format lens.
eddyshoots
tjdean01
Re: I'll try. :)
In reply to Steve Bingham, Jan 16, 2014
Steve Bingham
www.dustylens.com
Because she wants to try a fast prime and can't afford $500 for a native Nikon lens.
She got the Minolta lens for $35.  I'll post more details and photo below in response to OP...
tjdean01
Photo of Said Creation...
Here's the thread that left me thinking it wouldn't work
The adapter is only about a half inch long with no glass. Lens is Minolta MD. User mainly shoots full manual on film so the fact that this combo doesn't focus or meter is not a problem for her.
As eddyshoots suggested above, I'm thinking something has to give, and I'm thinking that thing might just be infinity focus.
But still, what's weird is that this 50mm lens is WIDER than expected, similar to 35mm.  Now is she talking 35 in FF terms, or APS terms?  On full frame terms, I see absolutely no way it is possible except if that lens she got a hold of has been modified.  If the lens is perfectly adapted her FOV would be equivalent to the 50 written on her zoom lens, or 75mm in full frame terms.
So, I'm really confused here.  All I can think of is that the lens has some sort of speed booster/FL reducer modified inside of it.  I'll see it in a few days to solve this mystery!
jkjond
Veteran MemberPosts: 7,669
Re: Photo of Said Creation...
It's good to see someone simply trying something rather than accepting it can't be done! I'd be a bit wary of breaking something in my camera, but if there's an adapter between the body and lens I'd expect the risk to be zilch. Hard to see what's happening in this shot.
FL - I'd take a shot, then match it with a kit zoom on the same camera then read that value to see what the effective FL is. Note that there will be a change in effective aperture if the lens to sensor distance isn't equal to the design spec of the lens, though I doubt the change will be anything significant in this case. A fast prime will still be a fast prime, just not quite as fast the number on the lens indicates.
Wedding and fine art photographer based in the Lake District, UK
MRM4350
Re: I'll try. :)
Apparently you didn't read the OP either. The OP is not talking about a "F" mount lens.
I have used Nikon since 1976, and I know all about the "F" mount.
ZorSy
Re: Couple of explanations
In reply to eddyshoots, Jan 16, 2014
eddyshoots
Back in days I used to have both Nikon and Konica TC and was using Tamron 80-210 adaptal (MF times, the mount of the lens was removable to suit any system at time). I remember I forgot to switch mount and Konica would go right in the Nikon mount, rotated by some 40 degrees or so. Nikon mount would not go in Konica as it required thinner "lips" on the mount. Needless to say, aperture lever was not at the same spot (think Konica was at the bottom while Nikon on the side).
I agree it seems to be adapter with some  correction lens added, which would explain how it became wide instead opposite..
FujicaST605
Regular MemberPosts: 462Gear list
You've probably lost infinity focus.
For less total money, have your friend buy an 50mm F1.8 Series E AI-s lens. about $40 used and you get infinity focus.
http://www.keh.com/camera/Nikon-Manual-Focus-Fixed-Focal-Length-Lenses/1/sku-NK060000350000?r=FE
 FujicaST605's gear list:FujicaST605's gear list
Nikon D7100 Nikon AF Nikkor 50mm f/1.8D Tokina AT-X Pro 12-24mm f/4 DX II Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Nikon AF-S Nikkor 85mm f/1.8G
John Stark
Regular MemberPosts: 148
In reply to FujicaST605, Jan 19, 2014
Back in the 1970's I had a Pentax KX SLR with a standard F1.4 50mm lens, 50 mm F4 macro, and a 200mm F4 telephoto lens, so when I purchased my first DSLR a few months ago I also got a Fotodiox Pentax K - Nikon F lens adapter.  This has a lens in it that will affect image quality - very badly according to some posts above - but retains the infinity focus.  I have taken a number of photos using the Nikon D3200 with the 50 macro and the 200mm lenses attached.
Of course, these Pentax lenses only work in manual mode on the D3200, but (I think) they are quality lenses - very smooth and solid.  Focus is easy in live view - pressing the + button to enlarge the image on the screen.  I have had no real difficulties getting the exposure correct either.  On the computer screen the images look pretty good to me.  The Pentax 200mm lens has a longer reach than the standard 55-200mm Nikon kit lens on max (200mm) zoom.  An object is about 24% wider with the former.
I'm quite pleased with the magnification achieved with the Pentax 50mm macro lens too.  I have not taken any serious photos with it yet - just the newspaper (while watching TV).  At closest focus the full frame corresponds to 22 x 33 mm of the subject.  That's much better than I can achieve with the 18-55 Nikon kit lens.
So far, I am quite pleased with the results I am getting from these old lenses - well worth the $40 or so that the Fotodiox adapter cost.  I am looking forward to taking some photos of decent subjects - especially with the macro lens.  I accept that the results may not be as good as what could be achieved with some decent Nikon prime lenses (but I'm not about to spend that kind of money - at this stage anyway).  Much better, I think, to use the lenses I already have (which otherwise are just in a cupboard).  I nearly sold them a few years ago - but wasn't happy with the miserable amount I was offered.  Pleased now that I kept them.  Besides, having to use manual settings (rather than have the camera figure everything out) is  a good learning experience.
John Stark, Nelson, NZ
Fujifilm MX700, S602z, Z33WP, XP150, S9500
Nikon D3200 twin lens kit, SB-400
