How many of you use lens hoods?
Started Jan 14, 2014 | Discussions
mike
Regular MemberPosts: 184
Jan 14, 2014
Just curious how often you use lens hoods.  I personally never seem to use them. am I missing something, do they really help.
Thanks in advance
mike
Fog Maker
Senior MemberPosts: 1,692
Re: How many of you use lens hoods?
In reply to mike, Jan 14, 2014
Thanks in advance
mike
All the time.
VKM3
Regular MemberPosts: 234Gear list
If I'm setup on a tripod with time I'll snap it on.  Otherwise I find I just don't bother.
PeterK
Contributing MemberPosts: 878
Virtually always on almost all of my lenses. I use them as the primary method to protection. Learned during events that they keep the lens protected from fingers, bumps, etc. very well. Same thing works well in the field, hiking, bushwacking, or any other activity.
Don't use one on the 40mm pancake yet, as the lens is quite small and recessed.
www.pkphoto.net
Mike921
Regular MemberPosts: 294Gear list
Thanks in advance
mike
as clumsy as I am, I use them 100%
 Mike921's gear list:Mike921's gear list
Canon PowerShot S400 Canon PowerShot S2 IS Canon PowerShot G12 Canon EOS 7D Canon EOS-1D X +9 more
Colin Franks
Senior MemberPosts: 1,207Gear list
 Colin Franks's gear list:Colin Franks's gear list
Panasonic Lumix DMC-G3 Canon EOS 6D Canon EOS 7D Mark II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Canon EF 50mm f/1.2L USM +20 more
bhollis
Veteran MemberPosts: 3,111
Always.
AOKH
Senior MemberPosts: 2,674Gear list
Thanks in advance
mike
Always, even when in the bag! Protection and flare-resistance.
Regards. Anders
 AOKH's gear list:AOKH's gear list
Canon EOS 5D Mark II Canon EF 35mm f/1.4L USM Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM +14 more
SwedishGoose
Regular MemberPosts: 272
Always use them on all my lenses. I only take them of if I need to. For instance to add a filtersystem.
They protect the lens and keep stray light out improving the IQ. I see no reason to not use hoods...
Never use filters for protection though as they can deteriorate the IQ and their ability to protect the lens is debatable.
My Flickr stream: http://www.flickr.com/photos/swedishgoose/
victorian squid
Veteran MemberPosts: 3,390Gear list
99% of the time
Maybe, maybe if I'm inside at home, it's late and nobody's watching I'll whip it outwithout a hood.
They're my #1 lens protection. The 17-40 is a royal pain as it's as big as a dinner plate and doesn't fit in a bag for $#&*!, but I still haul it around. And, there's the added image improvement cutting out stray light.
10-20% of the time I've got a clear protection (B+W, Marumi) filter for outside windy/dusty/inclement weather - but the hood is still on.
"I'm afraid that if you look at a thing long enough, it loses all of its meaning." Andy Warhol
 victorian squid's gear list:victorian squid's gear list
Canon EOS 6D Canon EOS 70D Canon EF 24-70mm f/2.8L II USM Tamron SP 150-600mm F/5-6.3 Di VC USD Canon EF 16-35mm f/4L IS USM +37 more
Keith Z Leonard
Veteran MemberPosts: 5,289Gear list
Thanks in advance
mike
I use mine a lot.  My Sigma prime's hood is on 100% of the time because it's small enough to fit nicely in the bag.  The other hoods go on any time that I am shooting on a sunny day or I think there's any risk to the lenses.  They reduce flare and protect the front element, if you are mostly shooting indoors and not towards bright lights you may notice the difference in the actual photographs.
 Keith Z Leonard's gear list:Keith Z Leonard's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/4.0L USM Canon EF 100-400mm f/4.5-5.6L IS USM Sigma 50mm F1.4 EX DG HSM Canon EF 24-105mm f/4L IS USM +14 more
ASR45
Forum ProPosts: 34,346Gear list
In reply to Fog Maker, Jan 14, 2014
All the time +1.
Alan.
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.
Mark Twain
 ASR45's gear list:ASR45's gear list
Canon PowerShot G16 Canon EF 100-400mm F4.5-5.6L IS II Canon PowerShot G12 Canon EOS-1D X Canon EOS 5D Mark III +5 more
NT enty
New MemberPosts: 8
100% of the time!!! only time i have them off is when i need that extra space for storage.
but during a shoot. ALWAYS ON! its the best way to protect your lens without compromising image quality.
Rexgig0
Senior MemberPosts: 2,885Gear list
Yes, usually.
Hoods provide some level of protection to the filter threads and outer element. Even my EF 40mm 2.8 STM has its diminutive hood in place. My EF 100mm 2.8L Macro, which is one of my two most-used lenses, does not usually wear its hood, but I leave the Macro Ringlite adapter in place, which acts as an abbreviated hood.
The hood on my EF-S 10-22mm has deflected several impacts that might have damaged the filter threads or outer element.
I wear a badge and pistol, and, primarily with 7D cameras, with 10-22mm and 100mm Macro L lenses, shoot evidentiary images at night, which incorporates elements of portrait, macro, still life, landscape, architecture, PJ, and occasional action. During personal time, I enjoy using both Canons and Nikons.
 Rexgig0's gear list:Rexgig0's gear list
Canon EOS 7D Mark II Canon EF 135mm f/2.0L USM Canon EF 400mm f/5.6L USM Canon EF 100mm f/2.8L Macro IS USM Nikon AF-S Micro-Nikkor 60mm f/2.8G ED +29 more
RS_RS
Senior MemberPosts: 1,646
Fog Maker wrote:
Thanks in advance
mike
All the time.
+1
Marx81
Regular MemberPosts: 432Gear list
 Marx81's gear list:Marx81's gear list
Fujifilm FinePix X100 Canon EOS 400D Canon EOS 5D Mark III Canon EF 28mm f/1.8 USM Canon EF 50mm f/1.4 USM +3 more
irm
irm
Senior MemberPosts: 2,621Gear list
Re: 99% of the time
In reply to victorian squid, Jan 14, 2014
Try the 16-35 f2.8 L Mk I, it doesn't fit, nor does the 135 f2 hood, just plain large.
The 17-55 2.8 didn't come with one and the 16-35 doesn't seem to work on it.
Now I use the 6D so the 17-55 is no longer an issue.
my 2 exposed flashcubes worth.
Ian the pbase supporter.
http://pbase.com/ianm_au
Please check my profile for equipment list.
An amateur with dreams of being a good to excellent photographer.
 irm's gear list:irm's gear list
Canon EOS 7D Panasonic Lumix DMC-G10 Canon EOS 6D Canon EF 50mm f/1.4 USM Canon EF 50mm f/1.8 II +12 more
irm
irm
Re: Yes, usually.
In reply to Rexgig0, Jan 14, 2014
Which reminds me I have misplaced the hood for the 40mm stm.
Telhma
Regular MemberPosts: 391
I use them always, exept on my 17-40 lens, and on my 8-15mm lens when the hood start to get in the frame when i zoom out. on all other lenses, they are always attached.
greets
leecamera
Contributing MemberPosts: 652
Dropped my 5D3 2ft to the ground with a 70-200 lens attached.  It hit lens hood first and I suffered no more than a scuffed lens hood.
No, if there had been no lens hood... ugh...
Despite the obvious benefits of reducing flare I just don't trust myself or the public bumping into me to not use a hood.
Even use a hood when shooting indoors at my studio.  Feels wrong not to.
