debug mode for K5ii
Started Jan 13, 2014 | Discussions
kitsios_spyros
kitsios_spyros Senior Member • Posts: 2,086
debug mode for K5ii
I checked and calibrated all my lens on my K5ii this weekend. One of them seems way out of range (+/-10) of the cameras cababilities. I predict sth close to -24 based on my other camera/lens combinations.
Is there a debug mode for K5ii, especially a SD-card driven one?
Thanks in advance.
Kind Regards,
Spyros
 kitsios_spyros's gear list:kitsios_spyros's gear list
Pentax K-01 Pentax K-5 II Samsung NX300 Pentax K-3 Pentax K-3 II +13 more
Pentax K-5
bettyswolloks
bettyswolloks Regular Member • Posts: 177
Re: debug mode for K5ii
I'm not sure about this, but, pk_tether has a debug mode. I know it worked on my k10/7, not tried it on my IIs though. Just google pk tether, its a small free download.
 bettyswolloks's gear list:bettyswolloks's gear list
Pentax Optio I-10 Kodak DCS560 Pentax K10D Pentax Q Nikon D600 +13 more
Kerusker
Kerusker Contributing Member • Posts: 896
I have used pk_tether ( http://www.pktether.com/ ) with my K-5 II to read out the AF correction in debug mode (it was/is 0 µm).
I don't know of a SD-card solution for the K-5. I have used it with my K-10D some time ago.
If only one lens is off more than +/-10, it may be better to send the lens in for service.
][.Kerusker
we don't see that we don't see (eye's blind spot)
 Kerusker's gear list:Kerusker's gear list
Pentax K-5 II Pentax K-5 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA 55-300mm F4.0-5.8 ED
kitsios_spyros
kitsios_spyros OP Senior Member • Posts: 2,086
Thank you both for your reply.
My lens is actually older than me but is great. I may cosider sending it in for AF callibration as I'd love to use it with CIF with K5ii.
But I'll first use the programm suggested. It costs neither time not money:).
If anyone else nows of a SD-card solution...
Kind Regards,
Spyros
Younes B Contributing Member • Posts: 842
I think CIF only works with manual lenses....
Kind Regards,
Spyros
 Younes B's gear list:Younes B's gear list
Pentax K10D Pentax K-30 Pentax K-5 II Pentax K-5 IIs Pentax smc DA 15mm F4 ED AL Limited +6 more
kitsios_spyros
Hi Younes B,
my AF lenses are within +/-10 range
Hellios 58 and K135 are manual lenses.
CIF work with Pentax AF lenses that have AF/MF switch on them.
I am not sure about other brand AF lenses with AF/MF switc. Ron/others can verify..
Kind Regards,
Spyros
brandrx Forum Pro • Posts: 28,337
Hi Younes B,
All pentax lenses that have an AF/MF switch on the lens can do CIF. Some non-Pentax lenses that have the AF/MF switch on the lens can do CIF.
The below info was written a long time ago but is equally valid for current models of Pentax cameras.
Links to previous catch-in-focus info that I wrote about.
Tripod mounted Catch-in-focus (for hummingbirds) using autofocusing lenses that do not have the AF/MF switch on the lens.
http://forums.dpreview.com/forums/read.asp?forum=1036&message=35995640
Catch-in focus (focus trapping) using Remote Control F on the Pentax K-m, Pentax K2000, and Pentax K-x.
http://forums.dpreview.com/forums/read.asp?forum=1036&message=35204466
Pentax K-7, IR Remote, Catch-in-focus
http://forums.dpreview.com/forums/read.asp?forum=1036&message=36076983
EDIT: Here is one more that I did - CIF using AF lens.
http://www.dpreview.com/forums/post/51996101
Cheers.
Ron
Ron - 'We don't have time to go take pics this afternoon Carl.'
Carl - 'What do you mean? It will only take 1/1000s.'
'Keep your eyes looking forward. However, glance back now and then to see where you've come from. It will put a smile on your face.' ~ brandrx
kitsios_spyros
All in one.
Bookmarked!
Kind Regards,
Spyros
sleepwalker400 Senior Member • Posts: 1,593
YEAS USE PK TETHER  BUT YOU NNED TO HOOK UP TO YOUR COMPUTER SO SORRY .THERE IS NO MOSET THAT WORKS BELEIVE ME I TRIED WITH THE K-30.
 sleepwalker400's gear list:sleepwalker400's gear list
Sony Cyber-shot DSC-R1 Pentax *ist DL Pentax K10D Pentax K-30
