Some dramatic black and whites
Started Jan 10, 2014 | Discussions
Rocky ID Olympian Contributing Member • Posts: 705
Re: Some dramatic black and whites
Some really nice shots you have here!
 Rocky ID Olympian's gear list:Rocky ID Olympian's gear list
Olympus E-300 Olympus PEN E-PL1 Olympus E-5 Olympus OM-D E-M5 Olympus E-M1 +14 more
enrique santa
enrique santa Senior Member • Posts: 1,399
Wonderfull images!!
 enrique santa's gear list:enrique santa's gear list
Leica X Vario
mazzuccato
mazzuccato Senior Member • Posts: 2,251
Beautiful work.
Stefano
 mazzuccato's gear list:mazzuccato's gear list
Sony RX100 Panasonic Lumix DMC-GF1 Olympus OM-D E-M5 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +3 more
Moti Veteran Member • Posts: 6,895
Beautiful photos, thanks for sharing.
Moti
Nkobile Junior Member • Posts: 46
Some truly excellent photos in that set! The first 2 are really great.
 Nkobile's gear list:Nkobile's gear list
Canon EOS M Panasonic Lumix DMC-GM1
faith_ps
faith_ps Senior Member • Posts: 1,102
Beautiful
Excellent series.
Jakop
The saxophone is a very interesting machine, but I'm more interested in music.
Steve Lacy quotes
 faith_ps's gear list:faith_ps's gear list
Ricoh GR Digital Sigma DP3 Merrill Leica X Vario Olympus Stylus 1 Canon EOS 5D Mark II +17 more
intruder61
intruder61 Veteran Member • Posts: 3,064
great set, very nice PP.
Jouko Senior Member • Posts: 1,356
A very nice set of photos
and I find these tones well suited for the context - for me the brownish sepia gives a timeless feeling.
If you were after more dramatic appearance, I think a cooler, more neutral black tone would have been a better match. But the appearance would have been very much different.
PS. Have you tried the bw-conversion of Capture1? I do most of my stuff with it, only minimal (or sometimes quite aggressive) pp elsewhere (photoshop, ACDsee, some other programs). For me the C1 gives enough parameters to adjust the tonality within the grayscale and color - graytone match in the photo and in the outcome (like sepia-toning).
Jouko
'The best camera in the world is the one you have with you when you need it'
http://lehtokukka.smugmug.com/
http://jouko-lehto.artistwebsites.com/
Alex 13 Regular Member • Posts: 118
Re: A very nice set of photos
Very nice; like others have said, the first two in particular are excellent.  The second is the standout for me.
 Alex 13's gear list:Alex 13's gear list
Leica X1 Sony Alpha 7 Voigtlander 21mm F1.8 Ultron Sony FE 55mm F1.8 Sony FE 28mm F2 +2 more
tinternaut Veteran Member • Posts: 7,178
Re: Beautiful
The fourth is my favourite.
 tinternaut's gear list:tinternaut's gear list
Olympus E-510 Panasonic Lumix DMC-L1 Olympus E-30 Olympus PEN E-PL1 Olympus PEN E-PM2 +13 more
Gompie OP Regular Member • Posts: 375
Jouko
Thanks Jouko,
Yes. I tried the b/w conversion within Capture1. Which is by the way my favorite raw convertor for Olympus. The b/w conversion is very flexible and useful.
I'm still learning Capture1. I just bought it a month ago after using it as a trial for a month.
NIK Silver Efex has a lot of presets which can give you a sense of direction on which you can experiment further and adjust them to your own taste. This gives you a good starting point.
Ruud
 Gompie's gear list:Gompie's gear list
Olympus E-M1 Olympus OM-D E-M10 II Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario 35-100mm F2.8 OIS +4 more
Thank you all very much
Thank you,
That's the beauty of this forum. Negative and positive cc can be a great help for learning and expanding your photographic and PP skills. It makes you think and sometimes look different at your own work.
As long as people behave in a civilized manner it can give you much help.
Thank you all.
Ruud
Harold66
Harold66 Veteran Member • Posts: 6,423
Gompie wrote:
Harold66 wrote:
Hello Gompie
I think that the images would actually be a little bit stronger if you were to tone down a bit ( not remove it all , just reduce it) the sepia effect which is not suited to all the pics anyway
Just my opinion
Harold
www.haroldglit.com
www.modelmayhem.com/haroldglit
Thanks Harold,
I'm going to give it a try. Could you please tell me which ones aren't suited for sepia?
Maybe a quick reply in a few words on when to use sepia and when not?
For example, people, landscape or photos with a lot of contrast or not.
Based on the subject or based on the type of photo.
Thanks!
Ruud
Hello Ruud
Thank you for the reply. First, I want to say that there is no " absolute rule " about when you to use sepia or not , or even how much toning should there be. It is ALWAYS the photographer choice
also keep in mind that people who are responding to this thread are viewing images on computer that may be calibrated differently so they do not necessarily see the same level of toning or contrast
Secondly if you were to present these images together ( like in a gallery for instance) you are better off having a consistent tone across the series even if individually some images in the series may not "need " the toning ( I hope I am being clear)
with all of that in mind I would give you my opinion. I think image EIGHT ( and also 5 to a lesser extent) is in a completely different mood than the others. It is a funny shot and a keeper but in my mind , not going with the others and not needing the sepia tone
and by the way , you have several good images ( 1, 2 , 4 , 6) but number one is my favorite
Harold
www.haroldglit.com
 Harold66's gear list:Harold66's gear list
Ricoh GR Digital IV Sigma DP2 Merrill Sigma DP3 Merrill Ricoh GR Ricoh GR II +22 more
ahmami
ahmami Senior Member • Posts: 1,513
Some very nice images, love the processing.
pede59 Senior Member • Posts: 1,270
I like 2, 4, and 7.
What did you use for PP?
pede59 wrote:
I like 2, 4, and 7.
Hello pede59,
I used Capture one Pro for converting the RAW files and then used a photoshop plugin called NIK silver Efex for the B/W conversion.
NIK has several presets which you can use as a good starting point.
From there it's all up to your own imagination.
Ruud
Harold66 wrote:
Gompie wrote:
Harold66 wrote:
Hello Gompie
Just my opinion
Harold
www.haroldglit.com
Thanks Harold,
Thanks!
Ruud
Hello Ruud
Harold
www.haroldglit.com
Thanks Harold,
Your explanation is very clear. I see what you mean about image 8.
Thank you.
Ruud
KTClown
KTClown Senior Member • Posts: 1,452
Nice B&W shots. I need to do more of those.
Gary
Pueblo, CO
 KTClown's gear list:KTClown's gear list
Olympus XZ-1 Olympus PEN E-PL5 Olympus OM-D E-M10 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +2 more
C1 presets
Have you noticed the presets of styles-tools? There are multiple bw-and other presets already. And you can always save your own, when you are satisfied with the result.
You can even save import presets for a camera type for whatever output you want - I have set Noise to low and clarity bit up for EM1. Usually no need to touch those settings afterwards.
PS. This does not mean, that forget NIK... More tools in the box is always a good thing.
Jouko
Sergey_Green
Sergey_Green Veteran Member • Posts: 8,907
Did not like the title ..
Till I saw the pictures. And they are very good. The first two and the last frames are excellent. Thank you for sharing these.
- sergey
 Sergey_Green's gear list:Sergey_Green's gear list
Samsung Galaxy Note 10.1
