Canon 5D MKIII has a green cast/tint
Started Jan 10, 2014 | Questions
Rich Holland
Rich Holland New Member • Posts: 4
Quick background: Over the course of the year I have been shooting with 3 different 5D MKIII's. I have also been using the 5D MKII and a 550D.  I always shoot RAW and the subject-matter I photograph varies from building interiors to landscapes. I process all my images in LR5 - I recently upgraded from LR4.
I have found that the images produced by the 5D MKIIIs have a very distinct green cast when I increase their exposure during post processing. This cast also appears when I bump up the shadows. The images produced by this camera always seem to have a very subtle green cast, which doesn't really bother me because I can work it out in LR. However, the intensity of green magnifies significantly when I am dealing with an image that is underexposed - even if it's just a bit. The intensity of the green is very pronounced and impossible to get rid of unless I want to affect the entire image.
I have found this to be the case for every MKIII I have worked with and have never experienced this issue with any of the other previously mentioned cameras.  I don't claim to be a guru when it comes to colors and profiles, but I am thinking there may be a profile I can download that will resolve this?
I have found other 5D MKIII owners to experience this same problem, but have yet to locate a solution - if there is one. I am at a loss. Any insight would be greatly appreciated.
For demonstration purposes, I have included two versions of the same underexposed image. One is the original and the other has had its exposure increased in LR5:
Original underexposed image
I bumped up the expose by 2.55 in LR5
 Rich Holland's gear list:Rich Holland's gear list
Canon EOS 5D Mark III Canon EF 24-70mm f/2.8L USM Canon EF 70-200mm f/2.8L IS II USM
Rich Holland
Rich Holland OP New Member • Posts: 4
Re: Canon 5D MKIII has a green cast/tint
Ok, so since my initial post I decided to run a comparative test - because I realized that I don't always have this issue with the green tint.  I decided to shoot the same image twice - once as a RAW and the other a mRAW.  I found that the normal RAW image looked as it should and the mRAW has a distinct tint. I have uploaded each of the images.  I underexposed the image and then significantly increased the exposure in post.  Unless there is a way around the tint, I doubt I will ever shoot using mRAW again.
mRAW - look at that ugly tint.
RAW - a slight red tint but definitely more manageable than the green.
marcio_napoli
marcio_napoli Senior Member • Posts: 1,046
That's new to me.
Every other camera when bumping up shadows, if it has to shift colors, it will always go towards redish / magenta cast.
Never seem anything like it!
Marcio Napoli
www.marcionapoli.com
bigfatron
bigfatron Contributing Member • Posts: 644
What happens if you readjust the white balance? And +2.55 is a hell of an adjustment if you're doing it on anything like a regular basis.
Very unusual though, I have to admit.  Have you tried doing a similar adjustment in CPP (or another RAW editor) to see if its software-specific or definitely the file itself?
 bigfatron's gear list:bigfatron's gear list
Canon EOS 5D Mark III Canon EF 50mm f/1.8 II Canon EF 100mm f/2.8 Macro USM Canon EF 24-105mm f/4L IS USM Sigma 12-24mm F4.5-5.6 II DG HSM +3 more
Mako2011
Mako2011 MOD Forum Pro • Posts: 19,782
Issue with
That's an issue with LR5 not reading the mRAW format correctly. Try another Raw convertor (DPP) and check the results.
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
Rich Holland
Re: Issue with
Thank you!  I found that normal RAW is issue free, but I definitely want to be able to shoot confidently with mRAW when I need/want to.  I'm going to check it out in DPP now.
Rich Holland
White balance can minimize the green, but it won't remove it.  On top of that, all the other colors get wonky in the process.  Fortunately, I found this to only be an error with mRAW, RAW works fine - so I am happy to have a viable alternative.
I normally would underexpose an image like this on purpose with the goal of recovering lost data, I just wanted to show the intensity of the green.  And wow, is it intense!
Rob
Rob Regular Member • Posts: 375
I got a message from Rich about this, since I posted a thread about this exact same problem back in 2012: http://www.dpreview.com/forums/thread/3212799
I have tried other RAW converters such as DPP and ACR, and that green cast is there baked into the RAW file.
It's been a while since I have seen this problem in my photos, and I can't remember when it stopped showing up. I went back and combed through my photos, and the last time the problem showed up clearly was around April of last year, and since then I haven't really seen it all that much. I'm 100% sure it was before I switched to full sized RAW from mRAW because I checked the dates of photos, so it might not have anything to do with mRAW. Maybe Canon quietly fixed it in the last firmware update? Or maybe it was a very specific setting that caused it, but I've unknowingly stopped using that setting?
Rob
Art, music, photography, writings, and blog:
www.ethereality.info
 Rob's gear list:Rob's gear list
Olympus E-M1 Sony Alpha 7R II Sony FE 55mm F1.8 Panasonic Leica D Summilux Asph 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +6 more
Marx81
Marx81 Regular Member • Posts: 432
I shot 5d3 in RAW and use DPP and never saw something like that .
http://www.flickr.com/photos/marxx/
 Marx81's gear list:Marx81's gear list
Fujifilm FinePix X100 Canon EOS 400D Canon EOS 5D Mark III Canon EF 28mm f/1.8 USM Canon EF 50mm f/1.4 USM +3 more
lemming2008
lemming2008 Regular Member • Posts: 457
I shoot lots of low light environments using my 5d3, have never seen this behavior. I shoot RAW and use CS6, have never updated the firmware. I'd guess it is more likely to be something about the mRAW and/or LR5 workflow.
 lemming2008's gear list:lemming2008's gear list
Canon EOS 5D Mark II Canon EOS 5D Mark III Canon EF 35mm f/1.4L USM Canon EF 85mm f/1.2L II USM Canon EF 17-40mm f/4.0L USM +1 more
