X100(s) and X-Pro1 owners, what is your usage ratio between OVF and EVF?
Started Jan 10, 2014 | Questions
Joel Stern
Joel Stern Forum Pro • Posts: 10,909
Re: X100(s) and X-Pro1 owners, what is your usage ratio between OVF and EVF?
This may not be pertinent as I only has the X100s for about 2 mos. as it had a defect and I decided to go smaller APSc, and CapOne was still experimenting.
I found the EVF to be very dark in daylight, almost not useable and used the OVF 99% of the time.
If i am typing on my iPad, please excuse any typos.
fluxism Contributing Member • Posts: 511
with 35mm, OVF 50%
with zooms, OVF 0%
 fluxism's gear list:fluxism's gear list
Fujifilm X-Pro1 Fujifilm X-E2 Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +2 more
framus Contributing Member • Posts: 847
X100s - OVF 95% - EVF 5% - LCD 0
X-Pro1 w/ XF 35 mm - OVF 95% - EVF 5% - LCD 0
X-Pro1 w/ XF 18 mm - OVF 95% - EVF 5% - LCD 0
X-Pro1 w/ XF 14 mm - OVF 5% - EVF 95% - LCD 0
I'm fond of the OVF on these cameras, enjoy the 'gestalt' of using the optical finder.
The rub comes with the XF 14 mm (a great lens) - the intrusion into the view in the optical finder with this lens is such that the EVF works better for me with this lens.
 framus's gear list:framus's gear list
Fujifilm X100S Fujifilm X-T1
KCampbell Senior Member • Posts: 2,048
95% OVF, 5% EVF
I bought both cameras for the hybrid OVF, and that's what I use the overwhelming majority of the time.
Kevin
 KCampbell's gear list:KCampbell's gear list
Fujifilm FinePix X100 Canon EOS 5D Mark II Panasonic Lumix DMC-GF1 Fujifilm X-Pro1 Canon EF 24mm f/1.4L II USM +15 more
(unknown member) Senior Member • Posts: 1,321
75% OVF with X-Pro 1 (nt)
No text.
 wchutt's gear list:wchutt's gear list
Fujifilm X-Pro1 Fujifilm X-T1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +20 more
Tubed_Jazz Regular Member • Posts: 205
About 70% ovf, 25% evf and 5% rear lcd.
The advantage of the EVF is its WYSIWYG view. So I use it when parallax error might be a problem for focusing, and in low light where the OVF is too dim. Otherwise it's the OVF.
 Tubed_Jazz's gear list:Tubed_Jazz's gear list
Nikon D810 Nikon D500
Shomari
Shomari Contributing Member • Posts: 564
OVF -DAYLIGHT EVF - NIGHT NT
Howard
htree1@suddenlink.net
 Shomari's gear list:Shomari's gear list
Fujifilm FinePix X100 Pentax MX-1 Leica X Vario Sony Cyber-shot DSC-RX100 III Fujifilm X-Pro1 +4 more
Dougbm_2 Regular Member • Posts: 447
X100 (owned for nearly 3 years).
Mainly use EVF now. Progressed from mainly OVF and shooting jpg to mainly EVF and shooting RAW.
I would like an even better EVF but still like the OVF/EVF combo. Might use OVF more if the framing lines were accurate as I am fussy about composition plus seeing the exposure correctly gives the EVF the edge.
 Dougbm_2's gear list:Dougbm_2's gear list
Fujifilm FinePix X100 Panasonic Lumix DMC-LF1 Canon EOS 5D Canon EOS 7D Canon EF 50mm f/1.8 II +7 more
Joachim Gerstl
Joachim Gerstl Veteran Member • Posts: 6,496
100% with my X-Pro1 because of the 14mm lens
approx. 70% with my X100.
 Joachim Gerstl's gear list:Joachim Gerstl's gear list
Ricoh GR Canon PowerShot G7 X Sony Alpha 7R Fujifilm X-T1 Sony a6000 +13 more
iau Regular Member • Posts: 152
I'd say I mostly just use the LCD screen, then the OVF some. The EVF hardly every. May have tried it, but it's not something I use.
Not sure why I "prefer" the LCD over the OVF as I prefer OVF like on a DSLR, but I guess I have become used to just use the LCD on smaller cameras. Besides, the hood blocks part of the view.
 iau's gear list:iau's gear list
Fujifilm X100T Leica M9-P Nikon D750 Fujifilm X-Pro2 Nikon AF-S Micro-Nikkor 60mm f/2.8G ED +9 more
JapanAntoine Forum Member • Posts: 63
X100S: 90% OVF and 10% EVF
I fell in love with this OVF on the X100s... but I can understand an EVF is more practical when using a zoom lens or various primes on the Pro 1.
 JapanAntoine's gear list:JapanAntoine's gear list
Fujifilm X100S Sony Cyber-shot DSC-RX100 III +1 more
mplkn
mplkn Forum Member • Posts: 69
It's much as with waist-level finders on medium format gear. There's just something to be said for composing using two eyes looking at an image on a surface at a comfortable viewing distance.
I have the feeling that this approach, by not blocking one's entire view with the camera itself, lends some of the context back to the framed picture in the finder, restoring some of that larger contextual view so often cited by those of us who really like the OVF.
Best wishes,
Michael
mplkn
 mplkn's gear list:mplkn's gear list
Canon PowerShot G7 X Fujifilm X-Pro1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +9 more
Shawn67 Senior Member • Posts: 1,089
Re: 100% EVF
Ross Kennedy wrote:
Thanks - I'll give that a try. I would actually like to use the OVF more…maybe my New Year resolution will be to learn the OVF properly!
I tend to shoot a lot of shallow DOF travel portraits (i.e. no second chances if I mess up), so the EVF is just more reliable.
When starting to work with the OVF set the camera to give you a 3 second review after the shot. That way you immediately see your results and can spot check focus. If you need to get right back to shooting half press the shutter and you are back to the OVF.
Shawn
Probably 85% OVF, 15%EVF.
However, this varies depending upon the lens I am using.
When using the 8mm I use the EVF. When using adapted lens I'll use the EVF unless I either have enough light (or flash) to zone focus and then I'll use the OVF. For my 500mm I use the EVF but have also predictive focused and then used the OVF due to lag.
I also sometimes have the camera set to preview the picture after playback so it will auto switch from OVF to EVF for playback and then back. Wonderful feature.
My preference is strongly for the OVF and that isn't just because the EVF in the XP1 isn't class leading. I had the OMD before the XP1 and prefer the OVF against that EVF as well.
Shawn
friderici Junior Member • Posts: 32
x100s:
OVF: 99%
EVF: 1% (only for macro)
miniTO Regular Member • Posts: 239
95% OVF... I love seeing outside the frame especially on the street.
The EVF is only used for very close shooting and Macro in my scenario.
Bill Robb Senior Member • Posts: 3,332
kevinschoenmakers wrote:
How often would you say, percentage wise, do you use either? Also, what did you think your ratio would be like when you first bought your camera?
100% optical. I detest electronic viewfinders, and unless they improve greatly I will never buy a camera that doesn't have some sort of OVF.
