Sony 4K Handycam FDR-AX100 sample 2160p video !
Started Jan 7, 2014 | Discussions
Joe Ogiba
Joe Ogiba Veteran Member • Posts: 3,562
The 2160p youtube video looks great on my Mac Pro with 30" 2560x1600 monitor. I pre-ordered it from B&H yesterday.
http://www.youtube.com/watch?v=hEYhkvZEVN4
 Joe Ogiba's gear list:Joe Ogiba's gear list
Sony Alpha 7R Panasonic Lumix DMC-GH4 Samsung NX1 Sony Alpha a6300
stinelise
stinelise Regular Member • Posts: 156
Re: Sony 4K Handycam FDR-AX100 sample 2160p video !
Thanks for sharing Joe Ogiba - It looks great on my mac too.
//Stine-Lise
 stinelise's gear list:stinelise's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro
Vesku Senior Member • Posts: 1,998
I want that!
Looks better than any fullHD could never be even in small monitor!
But of course when downscaling from 4k we get perfect 4:4:4 fullHD.
jkoch2
jkoch2 Senior Member • Posts: 1,198
FDR-AX1 and VG900 questions
What happened to your VG900?  Sold to raise dough for the FDR?
What bitrates attained when streaming YT 4k video? I don't even select that mode, since I have no 4k monitor.
In the PC world, what would be the minimum graphics card, RAM, and CPU specs needed to play 4k files captured with the FDR-AX1? Does the FDR-AX1 come bundled with software that can play or edit the stuff? What specs needed? What preview or render speeds achieved? If cropping 4k video, is the result neat, or does it get corrupted and messy-looking?
stinelise
Re: FDR-AX1 and VG900 questions
Why not try it out your self?
You can find an original file from FDR-AX1 here:
https://www.cinema5d.com/?p=21457
//Stine Lise
Markr041 Veteran Member • Posts: 4,371
Vesku wrote:
I want that!
Still 8-bit, and relatively small dynamic range. And the bitrate?
 Markr041's gear list:Markr041's gear list
Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-LX100 Sony Cyber-shot DSC-RX100 IV Panasonic Lumix DMC-ZS100 Canon EOS M +5 more
CAcreeks
CAcreeks Veteran Member • Posts: 8,805
Re: Nyquist theorem etc.
Joe Ogiba wrote:
The 2160p youtube video looks great. I pre-ordered it...
Yes, much better than RX10 video. Greater dynamic range, subject motion less shaky, zoom and panning are smoother.
Downsampling 1080p to 720p does not seem to improve quality a lot, but this video looks great. Note that 4K is exactly 200% of 720p. Results perhaps ratify the Nyquist–Shannon sampling theorem.
(I am not sure that YouTube actually gives you the higher-res settings when you set them.)
Sean Nelson
Sean Nelson Forum Pro • Posts: 11,730
Did you mean "4K is exactly 200% of 1080p"...?
Steven-T
Steven-T Veteran Member • Posts: 3,340
4K RAW video support?
It seems the Sony 4K FDR-AX100 is an attractive affordable offer. After searching through the web, I can't find 2 spec items.  Anyone knows?
1.  What is the dimensions and weight of this AX100?
2.  Does it support shooting 4K RAW video? If yes, what is the RAW format?
Thanks, . . . Steven
 Steven-T's gear list:Steven-T's gear list
Leica M9 Panasonic Lumix DMC-GH4 Sony Alpha 7R II +6 more
stinelise
Re: 4K RAW video support?
Hi Steven
Found the weigh, that should be around 915 gram, but this is not info from Sony. Source of my info is:
http://www.audiovideopro.net/ces-2014-sony-releases-fdr-ax100-2000-4k-handycam/
I have also been searching more tech info but only found this at Sony:
http://store.sony.com/4k-camcorder-with-1-sensor-zid27-FDRAX100/B/cat-27-catid-All-Handycam-Camcorders
you need to click the link "view specifications" on the top right side of the page.
//Stine-Lise
Steven-T
Hi Steven
//Stine-Lise
Thanks. 915grams is quite portable.
If Sony doesn't talk about 4K RAW support, the customer (aka me) is in doubt negatively. No FDR-AX100 for the customer, until the customer finds out otherwise.
Best, Steven
Hi Steven
//Stine-Lise
Best, Steven
It does not even shoot RAW stills, let alone RAW video. It does not shoot RAW video. Are you waiting to see it say in the specs "Does not shoot RAW video."? It never will. It also shoots 8-bit, 4:2:0. Consumer specs.
If you want RAW 4K video, the Black Magic 4K camera will appear soon.
Specs:
http://presscentre.sony.eu/content/detail.aspx?ReleaseID=9344&NewsAreaId=2
So it is 3840 30P h.264 60Mbs
It may be too low bitrate for me. I think that GH4 would have much higher bitrate and better sensor too. 4K 60P would be a dream.
Steven-T
Hi Steven
//Stine-Lise
Best, Steven
Trust, but verify. If a company can miss the dimensions and weight in the product spec, might be also missing something else. Luckily asking is not a crime, at least not yet. No interest in the Blackmagic 4K.
Thank you for your friendly comment.
Steven
CAcreeks
Yes, sorry.
At some point, downsampling yields diminishing returns, but considering the relatively poor quality of video frames, perhaps taking 4K video will allow you to post really good 1080p videos.
For Bayers sensors, I feel still images are best when downsampled 50%, giving one pixel for four RGGB values.
Joe Ogiba
Joe Ogiba OP Veteran Member • Posts: 3,562
My VG900 is a full frame that shoots 24mp RAW stills and 1080p60 video with all of my fast PK mount prime lenses ( 24mm F1.4, 35mm F1.4, 50mm F1.4, 85mm F1.4) so it's not the same as this fixed lens 4K camcorder with much smaller 1" sensor and F2.8-F4.5 zoom ( f8-F11 FF eqiv) . I also use the Sony HVL-F60M flash on my VG900 that would also work on the FDR-AX1.
Roland Schulz Contributing Member • Posts: 504
...and how to play that 4:4:4? By the way, in 2k it would "only" be 4:4:2 from 4:2:0 original footage.
BUT: for a 2k€ camcorder this looks really great! The sample footage is only 15Mbps, 60Mbps will be somewhat better. I downscaled the 4k original to 2k using Edius 7 with Lancos 3 -> really stunning!!!
yonsarh Senior Member • Posts: 1,812
I want that 4k camcorder!.
Even my FULL HD 1080p camcorder video quality suck at my asus 27" monitor.
lancespring Veteran Member • Posts: 3,744
Why would you believe
that is an original file from the camcorder???
 lancespring's gear list:lancespring's gear list
Sony Cyber-shot DSC-RX10 Nikon D600 Sony a6000 +1 more
stinelise
Re: Why would you believe
Seems like the (3840x2160 / 2GB) MP4 file handles easily on my iMac, and I can even import it into CS5 - but there are no posiblity to export it out in 3840x2160, but I guess a software update will fix this problem.
So now I am also wondering - if this is the original file from the camera, then I'm gonna get one.
After looking at the clip from Sony on Youtube in highest resolution (2160) I'm convinced that this is the way to go. Then its just to decide what camera to choose.
//Stine Lise
