New 6D
Started Jan 6, 2014 | Discussions
uddhav regmi Contributing Member • Posts: 573
New 6D
I just brought new 6d.
MegaPixelwise,  why my photo size is just 4.3MB  ????
why I'm not capturing higher size pictures  in JPEG  ?
Is there anything I need to change  ?
like this one  ?????
Canon EOS 6D
Ed Halley Veteran Member • Posts: 4,114
Re: New 6D
The 4.3MB is the size of the JPG file in bytes.  This is not to be confused with the number of megapixels in the image, or the number of megapixels of the camera sensor.
Honestly, I don't even know why they show you this number on the little screen.  It's theoretically a very rough indicator of how sharp your focus was, but only in some circumstances.
[ e d @ h a l l e y . c c ] http://www.halley.cc/pix/
uddhav regmi OP Contributing Member • Posts: 573
Re: New 6D
You mean sharpness is related to that filesize  ?
AOKH
AOKH Senior Member • Posts: 2,675
Re: New 6D
The more detail or noise is in an image, the larger the resulting JPG (e.g. a blurry and/or uniform image vs. a sharp complex landscape). The more data, the less compressed the JPG engine will be able to make the image.
Regards. Anders
 AOKH's gear list:AOKH's gear list
Canon EOS 5D Mark II Canon EF 35mm f/1.4L USM Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM +14 more
Keith Z Leonard Veteran Member • Posts: 5,383
Re: New 6D
You've already been given the answer but I will try and expand the explanation a bit.  JPG is a lossy compression file format for images.  The camera also can shoot in RAW format, which uses lossless compression.
In lossless compression the file rearranges the information so that any patterns that are repeated in the image are stored once instead of 2/3/4/??? times.  RAW data is also stored in 16 bits per channel per pixel, as your ADC is 14 bit.
In a lossy compression scheme you actually throw out some of the data, usually by converting the image to HSL format and storing less luminance data, for instance.  JPG is an 8 bits per channel format, so it's much less data than the RAW information.
In short, the more patterns in your image, or closely related color values, the smaller the file size, so an image with a bunch of evenly lit solid colors will result in small files, while a photo of something high frequency (lots of rapid changes in the image) will result in a large file size.  Noise in the image counts as high frequency data, and does not compress well.
 Keith Z Leonard's gear list:Keith Z Leonard's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/4.0L USM Canon EF 100-400mm f/4.5-5.6L IS USM Sigma 50mm F1.4 EX DG HSM Canon EF 24-105mm f/4L IS USM +15 more
Caerolle
Caerolle Senior Member • Posts: 3,100
Re: New 6D
like this one ?????
Wow, a $2000 P&S...
Not because I think they are good, but because I would like to improve (feel free to provide me with feedback):
http://500px.com/carolteater
 Caerolle's gear list:Caerolle's gear list
Olympus E-M1 Olympus OM-D E-M10 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro +3 more
steelking Junior Member • Posts: 28
Re: New 6D
You can adjust the size of JPG + RAW images in the menu to shoot small, medium or large and will affect the MB size of the files.
 steelking's gear list:steelking's gear list
Canon PowerShot G10 Canon EOS 6D Sigma 50mm F1.4 EX DG HSM Canon EF 24-105mm f/4L IS USM
William Hubert Contributing Member • Posts: 855
Re: New 6D
Sorry, don t understand why you would care about JPEG size.
Always shoot with raw !
if you want a JPEG for quick evaluation etc add that. But your images need to be in RAW.!
As with many things in life a great photograph has strong appeal for what is NOT in the picture.
 William Hubert's gear list:William Hubert's gear list
Samsung NV11 Samsung TL500 Canon EOS 10D Canon EOS 20D Canon EOS 40D +23 more
SwedishGoose
SwedishGoose Regular Member • Posts: 272
Re: New 6D
That is not entireley true is it?
Shoot in jpeg if you get perfect results everytime and never process your photos, not today and not in the future....
RAW is the best format so yes do shoot in RAW or RAW + jpeg.
My Flickr stream: http://www.flickr.com/photos/swedishgoose/
DKCJB Regular Member • Posts: 164
Re: New 6D
The answer is because that's how big your file is.  I set up my 40D (10megapixel) camera for the same settings I can see on your screen and got a file 2.87MB (Large, Fine, JPG).  Same scene in RAW was 11.1MB.
 DKCJB's gear list:DKCJB's gear list
Canon EOS 40D Canon EOS 7D Canon EF 20mm f/2.8 USM Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.8 USM +3 more
waheeb Junior Member • Posts: 28
Re: New 6D
dont worry its the same with my 6d too
its not an issue its just the size of the image and its with the 20mpx
this is cool thing for me to have lower jpeg size images
i shoot raw+jpeg all the time
