Please help me to stay with Pentax!
Started Jan 5, 2014 | Discussions
JimBim
Regular MemberPosts: 221Gear list
Jan 5, 2014
I’m comming to conclusion to upgrade my gear. Since 1997 I’m with Pentax. This time I decided to look to other land, specifically C, N. I see by testing those cameras inside dealer shop, that pictures from D610 and 6D are better compare to K3. What is your oppinion - might be I’m doing something wrong? Or this is because C and N are FF. Might be lens? All shoots are at ISO1600, AWB, F2.8; lens 50mm F1.4. I cropped C and N pictures to fit Pentax sensor size. No PP, jpg output, hands held, luminescent lighting.
I know that some of you complemented Pentax system with N or C. Can you share your experience? I’m really trying to find arguments to stay with Pentax!
Audrius
K3
6D
D610
 JimBim's gear list:JimBim's gear list
Pentax *ist DL Pentax K20D Canon EOS 7D Mark II Pentax smc DA 15mm F4 ED AL Limited Pentax smc FA 50mm F1.4 +3 more
Canon EOS 6D Nikon D610
Model Mike
Veteran MemberPosts: 3,321Gear list
Re: Please help me to stay with Pentax!
In reply to JimBim, Jan 5, 2014
It's all in the processing. I doubt the camera make a blind bit of difference. As Luminous Landscape put it:
"Most cameras these days produce image quality far superior to what most photographers are able to realize. I've written it before, and I believe it to be true. Sure, the pixel peepers can recite DxO ratings and cite the half-an-IE high-ISO advantages of one camera over another. But this is mostly the stuff of hobbyist mania. For me, and many other photographers, content is king and usability is its mistress."
James O'Neill
Veteran MemberPosts: 4,027
That's your comparison ? How much do you shoot at ISO 1600 ?
I have to say there's not much difference between the pictures, the Pentax looks to have its JPEG contrast set higher, and have the option to leave tungsten light slightly warm in AWB selected. My hunch is if you optimized the JPG settings they'd look even closer.
If you're weighing up which of 3 very capable cameras to buy, go for the one which feels best and most natural when you come to shoot with it. Suppose the Canon produces very slightly better images; I can't get on with Canon controls, so if I bought one it would stay on the shelf rather than go out shooting.  The best camera is the one you go and shoot with . You also need to take into account the cost of changing lenses and accessories if you switch systems.
If you like using the Canon or Nikon more and the cost of changing systems isn't prohibitive, CHANGE.  No one will hate you, no need to feel guilty. If you like using the Pentax more, stay. Don't expect other people to make your decision,
Zvonimir Tosic
Senior MemberPosts: 2,545Gear list
Already discussed — it's the heavy Auto NR
It's the default Auto NR that kicks in after ISO 400. It makes smudgy JPEGs.
Turn Auto NR off and set it up as it serves your educated purpose.
I know that some of you complemented Pentax system with N or C. Can you share your experience? I’m really trying to find arguments to stay with Pentax!--
I say, let's stay within common sense. Today's camera s are all very, very good.
You cannot go wrong with either, but you'd go wrong with any of them if you don't understand how they work in particulars.
Have fun.
Zvonimir Tosic
“A portrait is not made in the camera, but on either side of it.”
— Edward Steichen
 Zvonimir Tosic's gear list:Zvonimir Tosic's gear list
Fujifilm FinePix X100
JimBim
JimBim OP
In reply to James O'Neill, Jan 5, 2014
Sounds like if you are not praying for Pentax - go out! By the way, when I'm going for a trip I grab my istDL and I'm happy with output (in normal day light). But I'm doing a lot of shooting inside and have to use flash. These days ISO1600 is normal, I'm not talking about 3000 and above.
JimBim
JimBim OP
Re: Already discussed — it's the heavy Auto NR
In reply to Zvonimir Tosic, Jan 5, 2014
Thank you, Zvonimir! I like deep analysis in your posts!
Audrius
kenwklau
Regular MemberPosts: 387Gear list
Re: Looks like K3 WB is off
Audrius
Hi Audrious,
With that yellowish cast on the K3 photo, I wonder if the SENt on it was set right.
Ken
 kenwklau's gear list:kenwklau's gear list
Pentax K-30 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 55-300mm F4.0-5.8 ED Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Pentax smc DA 50mm F1.8
kenwklau
In reply to kenwklau, Jan 5, 2014
Audrius
Hi Audrious,
Ken
Sort for typo with my new Smartphone. I meant AWB.
Ken
awaldram
Forum ProPosts: 11,867Gear list
Talking just these images as shot
k3
better white balance
closer (better reach)
lower DoF better subject isolation
Higher niose
heavier Nr
Lurid red channel from Jpg (think Pentax calibrator is colour blind )
besides better white balance the rest are either functions of the format or adjustable.
I see nothing in the image that would make you choose Canon or Nikon over K3 the opposite is true there are indications in the image that the k3 is more sophisticated than either other camera.
Of cause if your a FF wanna be and think it will make you a better photographer then irrelevant of brand that what you should do
knock yourself out in the FF myth but ensure you check out Sony offerings before leaping.
I would suggest you make a list of your 'needs' and choose based on that not some perceived variance that is more today with the jpg engine than cameras.
 awaldram's gear list:awaldram's gear list
Pentax K-x Pentax Q Pentax Q7 Pentax K-3 Pentax smc DA* 55mm F1.4 SDM +15 more
waxwaine
Contributing MemberPosts: 981Gear list
Shooting on camera stores could be better with CaNikons options. So, you know what to do
new2pentax72
Regular MemberPosts: 118
In reply to awaldram, Jan 5, 2014
In my understanding to compare different cameras the WB must be set manualy on the same setting and colour mode to neutral on all cameras.
k3
Higher niose
heavier Nr
miles green
Veteran MemberPosts: 4,711Gear list
Your test will favour FF. Others will favour the fast and rugged aps-c.
Default jpgs have very high NR at 1600 on the K3. Plus it's rather warm.
But obviously the FF will start being a bit better at high ISO. If it's FF you want, i'd wait a couple months, depending on lens you have or want. Ricoh has been quite fast to bring new products out, imho, and they have been talking about FF.
Neither of the other 2 are weather sealed (if i am not mistaken).
Frame rate and buffer size are not at the same level. In fact, i don't think there is another 24mpx camera that can shoot anything close to 25 RAWs at 8.5 fps (give or take, and again, you've gotta check the specs).
With long lens, their reach is much less, or lens are much bigger and pricier.
C&N don't stabilize primes (except teles)...
They are quite different machines.
Oh, and C&N don't make limiteds (that's enough incentive for me not to look elsewhere for those focal lengths).
Miles Green
Pentaxian with chronic LBA
Corfu, Greece
 miles green's gear list:miles green's gear list
Pentax K-5 Sigma 70-200mm F2.8 EX DG Macro HSM II Pentax smc DA 21mm F3.2 AL Limited Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited +9 more
awaldram
Audrius
Hi Audrious,
Ken
I'm surprised, as you gear lit includes k30 you make this remark.
As you should be aware Pentax believe the image should represent what your eyes see as such under artificial light they do not correct to the point the cast is daylight but leave some of the original ambiance.
This is another 'adjustable' setting and personally I think Pentax get it right, When shooting under candles I hate that 'shot in midday sun' look every other manufacturer seems to think is reasonable.
Brad99
Veteran MemberPosts: 3,145
3 things come to mind,
NR on auto is a no-no with the K-3 (as mentioned previously)
Bright mode is obviously set and that should preferably be Natural.
C&N 50mm primes don't have SR, Pentax cameras do so for this type of shot could be used at a lower ISO!
Zenten4
Regular MemberPosts: 173Gear list
It doesn't matter what the rest think. It is how you feel. Nobody can help you that much.
david tittermary
Contributing MemberPosts: 547
In reply to Model Mike, Jan 5, 2014
yep yep and anyone making a choice on a camera by testing in the store needs to just buy what ever makes them look good because the camera doesn't matter. lol.
bjake
Regular MemberPosts: 327
In reply to david tittermary, Jan 5, 2014
From the pictures I wouldn't want to buy any of these cameras but know they will all do much better
kikivrany
Veteran MemberPosts: 3,190
Hello JimBim
Hands down, the K5 picture looks not so good...but I wouldn not upset myself with a bad JPEG.
Look at the histograms: -> the K3 did overexposed !
also the left part of the histogram is wrong -> the black is not really black and the hole picture get a little 'flair'
the other cameras did not overexposed the scene where it's very important -> her face
I try to correct this:
Your original
and a exposure +colour correction:
ok it's useless to try to correct the WB on a JPEG picture...but I think it's still better than the original .
So...all in all... I would not compare the cameras with such pictures...you get the wrong impression.
best regards kikivrany
carpe noctem
MightyMike
Forum ProPosts: 33,159
Shoot RAW and learn how to WB properly, no camera can ever truly get WB perfect, many can come close in many situations but some fall short. I assure you even Nikon falls short. I never trust AWB to get it right, I expect it to come close most of the time but i know how to WB many scenarios either by choosing a neutral white/grey patch or by understanding what WB values are right for sunny, cloudy, shade, and such situations. So consider WB your next target to learn in photography, you'll be amazed at how much better photos will look with the WB set right.
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
JimBim
JimBim OP
In reply to MightyMike, Jan 5, 2014
Mike from Canada
Thank you Mike.
I look at this different. I do WB manually on my K20. Because this is an old stuff I'm forgiving. Today, when I have to pay my money I want to do my life easier. For me K3 looks like music instrument made from high end material, well built, but tuning must be done with everyone yourself. I can produce excellent pictures with my istDL in manual mode. And I do. But if I pay money, I expect something what would made my life easier: decent AWB, good jpg quality directly from camera, fast autofocus and so on. And there is not a big difference in price between K3 and 6D or D610.
Audrius
