Landscape lens for NEX3
Started Jan 4, 2014 | Discussions
hondav21098
Junior MemberPosts: 33Gear list
Jan 4, 2014
Whats a good sharp landscape lens for my NEX3 . Legacy or new . I have heard a lot of praise for the Sigma 19 & 30 . I find my 18-55 is not wide sometimes .
 hondav21098's gear list:hondav21098's gear list
Sony Cyber-shot DSC-HX1 Panasonic Lumix DMC-ZS20 Sony Alpha NEX-3 Sony Alpha NEX-7 Sony E 18-55mm F3.5-5.6 OSS +5 more
Sony Alpha NEX-3
Wordsmith9091
Regular MemberPosts: 312
Re: Landscape lens for NEX3
In reply to hondav21098, Jan 4, 2014
Well the Sigma 19mm, though a very nice lens, isn't going to be any wider than your 18-55.
There's the Sony 16mm pancake, though most people here have been unimpressed by it. You can get the Sony Ultrawide extender to bring it down to 12mm, which is nice and wide, but again, the quality is going to be awfully meh.
The Sony 20mm, which works as well with the UW extender, is a decent choice, from what I've seen on these forums, though I haven't tried them myself. Together, they get you down to 15mm. But the cost is a bit more.
Some people have paired the Sigma 19mm with a Panasonic ultrawide converter -- it works, but not very well, according to the various forum posts. Again, haven't tried it myself. I just ordered a Sigma 19mm, so I'm still hoping someone finds a good UW extender option for it.
There's a couple of 8mm fisheyes marketed as either Rokinon or Samyang, depending on where you look. I've seen several posts from people who get great results using the Hemi plugin for PS or Lightroom to correct the fisheye distortion, still maintaining very strong picture quality. And then, of course, you can just use it as an intended, as a fisheye, and get some awfully interesting pictures. It's manual focus only, but stopped down just a bit, you've got pretty much the full range from shortly in front of you out to infinity in focus anyway.
Sonyshine
Senior MemberPosts: 7,245Gear list
In reply to Wordsmith9091, Jan 4, 2014
If you want to see some stunning landscapes taken with a Nex camera then look here:
http://www.flickr.com/photos/uberdogleg/with/11730462796/
He has the EXIF dated in his files, most are shot with the SEL-1018 lens.
Not cheap but a brilliant landscape lens.
 Sonyshine's gear list:Sonyshine's gear list
Nikon 1 V2 Nikon 1 J5 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor 10mm f/2.8 Nikon 1 Nikkor 18.5mm f/1.8 +6 more
mountaindrew22
Junior MemberPosts: 42
Did anyone compare the 19mm + adapter vs 20mm + adapter?
Son Of Mustang Ford
Contributing MemberPosts: 517Gear list
In reply to Wordsmith9091, Jan 5, 2014
the 16mm pancake has had many favourable posts on this forum - and the combination with the UWA is often (it seems) more liked than the 16mm by itself.
stoppingdown
Regular MemberPosts: 405Gear list
In reply to Son Of Mustang Ford, Jan 5, 2014
I second the suggestion of the SEL1018 - just check carefully the quality of your copy when you get it. If it's a good copy, it's sharp. Here you can find a review of mine, after the first trip with it (no full size samples, but if you click on a photo it will pop up at full browser size, up to 4MP).
Fabrizio Giudici
 stoppingdown's gear list:stoppingdown's gear list
Nikon D7000 Sony Alpha NEX-6 Sony a6000 Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF-S Teleconverter TC-14E II +8 more
stoppingdown
In reply to Sonyshine, Jan 5, 2014
Definitely the best Sony showcase I've seen so far.
Fabrizio Giudici
captura
Forum ProPosts: 21,096Gear list
In reply to hondav21098, Jan 5, 2014
First of all you should upgrade your NEX-3 to at least a NEX-3F or newer. The NEX-3 does not do distortion correction so that no matter which Sony lens you use, the camera body will be unsuitable for landscapes.
hondav21098
In reply to captura, Jan 5, 2014
Thats first time I have heard that . I might watch out for another body I would like a 6 but they seen to hold there price in NZ . There is a few 5s coming up for sale so might up grade . I travel Asia 6-8 months of the year so dont like having a lot of money in camera and travel gear.
D Cox
Forum ProPosts: 12,581
No, it isn't.
The 16mm is improved by the UltraWide adapter and with it can give very good sharp results. My guess is that the lens was designed mainly to work with the UWA.
Some people got bad copies.
D Cox
I agree that it is worth while to upgrade from the original NEX-3.
But distortion is not a problem in landscapes as there are no straight lines. Cityscapes are a different matter.
Sol Invictus
Regular MemberPosts: 394Gear list
Also, take a look at a couple of high quality lenses by Zeiss. The Zeiss Touit f2.8/12mm prime and the Zeiss SEL1670 zoom lens. Both are pretty expensive though but quality comes at a price...
To see a world in a grain of sand and a heaven in a wild flower, hold Infinity in the palm of your hand and Eternity in an hour...
 Sol Invictus's gear list:Sol Invictus's gear list
Sony Alpha 7 Sony FE 24-70mm F4 OSS Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Adobe Photoshop CS6 extended ACDSee Pro 5 +10 more
captura
Even a NEX-3N will have distortion correction built in.
captura
In reply to Sol Invictus, Jan 5, 2014
Fr as I know, all of the native NEX lenses require ditortion correction. Thatis part of the design nowadays, same thing with M43 lenses.
captura
In reply to hondav21098, Jan 6, 2014
I would hold out for the newest, the 5T. It has the Play Memories disabling device same as the A7, which hugely improves battery life.
