Screen protector
Started Jan 4, 2014 | Discussions
Mike Stratil Contributing Member • Posts: 800
Screen protector
(a) What screen protector do you recommend for the A7R?
(b) I have looked at the Sony PCKLM16. It seems that one gets only 1 in a package; is that correct?
Michael S
Sony Alpha 7R
Brewhop Regular Member • Posts: 202
Re: Screen protector
I have three Sonys, A99, A7r, RX100, and use this screen protector on all three. They are designed to fit each model and work great. Once you put it in place you wont even know it is there.  Well worth the money.
 Brewhop's gear list:Brewhop's gear list
Leica M Typ 240 Leica Elmarit-M 28mm f/2.8 ASPH Leica APO-Summicron-M 50mm f/2 ASPH
Clayton1985 Veteran Member • Posts: 5,281
I use the Sony as well and I'm generally positive about it but I will say that I find it to be a little less rugged, scratch resistant, etc vs the GGS protectors I've used in the past.
Mike Stratil OP Contributing Member • Posts: 800
Thanks, Brewhop.
Do you get only one per package?
Michael S
Mike Stratil wrote:
Thanks, Brewhop.
Michael S
Yes, it is only one per package.
quezra Senior Member • Posts: 3,915
I got this.  Works perfectly, and didn't have any problems being placed under tap water to clean it before a second application after I messed up the first one.
 quezra's gear list:quezra's gear list
Sony Alpha 7 Sony FE 55mm F1.8 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Sony Alpha NEX-5N Panasonic Lumix DMC-GH3 +10 more
SQLGuy Veteran Member • Posts: 4,223
For those of you using screen protectors
Can you comment on how much (or how little) glare you get from the screen protector versus the stock anti-reflective coating of the screen?
A7 with kit lens and a number of legacy lenses (mostly Canon FD)
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Nikon D200 Sony Alpha NEX-7 Sony Alpha 7 II Nikon AF-S DX Nikkor 35mm f/1.8G +2 more
Re: For those of you using screen protectors
Unfortunately there has hardly been any sun here and also I've been shooting almost exclusively with EVF so I haven't noted glare at all.  But I guess when I have shot with the display I didn't notice it so far.
Sumava
Sumava Junior Member • Posts: 32
For what it's worth, I haven't noticed any difference in glare between the two.
 Sumava's gear list:Sumava's gear list
Sony Alpha 7
Robgo2 Veteran Member • Posts: 4,680
You will have a hard time finding a screen protector as good as the Giotto.
Giotto screen protector
Rob
Thanks to everyone for their input. It has been very helpful.
Michael S
TriniArt2 Regular Member • Posts: 434
Since smartphone screens are now generally bigger than the camera screens, I use those. Cut to size and works great. Been using phone screen protectors on my cameras for the last 4 years.
They're cheaper(generic ones) and you usually get two in a pack.
I cut to size and re stick or stick new tape on the cut portion to enable peel off.
 TriniArt2's gear list:TriniArt2's gear list
Canon EOS 550D Sony Alpha 7R Canon EF 17-40mm f/4.0L USM Canon EF 100mm f/2.8L Macro IS USM Rokinon 35mm f/1.4 +11 more
Rob
Rob -- have you used this on the A7/r?  I'm wondering about the fit and whether the edges of the screen protector cover any of the LCD information.
Here's a pic with the cut phone screen protector fitted. I had first used an old matt protector but it was not very good for viewing on the screen, so I fitted a clear one and it works great.
Rob
No, I have not used it on an A7/R but on a Pentax K-5II.  Both cameras have 3 inch LCD screens measured diagonally, so the screen protector should fit exactly the same.  On my Pentax, none of the screen itself is covered.  I cannot guarantee that the A7/R is exactly 3 inches, having never measured it, but for $25, you don't have much to lose, especially if you can return the item, if it does not fit.
Rob
Robgo2 wrote:
Rob
Rob
I actually have one that I haven't installed yet.  It looks very close on the edges so I was just curious if you or anyone else had already tested it.   I'll report back once I get a chance to try it.
Clayton1985 wrote:
Robgo2 wrote:
Rob
Rob
Clayton,
Screen protectors are supposed to fit very closely around the borders of the screen.  I think that it will be fine.
Rob
Warning about the Giotto
I have measured my A7R screen. It is 3" L X 2 3/16" W, with a 3 11/16" diagonal. Thus, the Giotto, with a 3" diagonal, is far too small for the A7R.
Michael S
Clarification
The dimensions I gave above are for the entire screen. The active area of the A7R is 2 9/16" L x
1 9/16" H, with a 2 3/4" diagonal. So the Giotto will work if one only wants to cover the active area.
Michael S
