D800 image overlapping / distorted!
Started Jan 1, 2014 | Questions
PaulD1980
PaulD1980 Junior Member • Posts: 43
Hi all,
I haven't used my D800 for a few weeks, but tonight i decided to take some photos of my D3100 to sell on E-bay. I was using a tripod and set the speed to 1/1.6 at F14 with auto ISO. On previewing the image, i noticed that the image seems to be overlapped with the same image? The more i increased the speed the better the images were?
What could cause this problem?...do i need to take it to a dealer for repair?
The lens used was a Nikon VR 18 - 55mm 3.5 - 5.6.
Nikon D3100 Nikon D800
Nikkk New Member • Posts: 3
Re: D800 image overlapping / distorted!
Was VR activated on the lens? If so, that could explain it (should be off when camera is on tripod). MUP is also recommended in this case.
 Nikkk's gear list:Nikkk's gear list
Nikon D800 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF Nikkor 50mm f/1.8D Tamron SP AF 90mm F/2.8 Di Macro Tamron SP 24-70mm F2.8 Di VC USD +1 more
shmn Regular Member • Posts: 362
There is no overlap.  This is camera shake which is causing the image to blur.  You say you are using a tripod...is it solid?  How are you activating the camera?  Are you using mirror lock-up?  Remote release? I think technique is the problem here.
Try the same shot using mirror lock up and a remote release or the timer and let us know.  Make sure the tripod is rock steady.  Don't use an extended center column.
And do you really need to be shooting at F18 with a 24mm lens???
TOF guy MOD Forum Pro • Posts: 12,818
You most likely have nailed the problem. Both precautions must be used.
In combination with MUP use a remote or delayed actuation.
Thierry - posted as regular forum member
 TOF guy's gear list:TOF guy's gear list
Nikon D810 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED Sigma 150mm F2.8 EX DG OS Macro HSM +5 more
caspianm Senior Member • Posts: 2,132
Do not use such small aperture. Turn off the VR.
 caspianm's gear list:caspianm's gear list
Nikon D800E Sony Alpha NEX-3N Sony Alpha 7 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED +13 more
HobbiesAreFun
HobbiesAreFun Senior Member • Posts: 2,457
I expect you did not use a remote trigger or wire trigger, did not use a sturdy enough tripod, or did not use the self timer. In other words, your clicking the shutter moved the camera enough to cause issues.
Another suggestion, you don't need to use apertures THAT small for this kind of thing. f/5.6 to f/8 would have served you fine for the most part, if you focus in the right places with the wide-angle shots.
These were my shots that I used when selling off my Sony equipment (Taken with my D700 + Nikon 28-70mm f/2.8 AF-S). Apparently I shot all of them at f/6.3... Heh. Do not remember that, but oh well.
-Eric (18 years old with tons of things I can't wait to learn)
http://eswenson.smugmug.com
 HobbiesAreFun's gear list:HobbiesAreFun's gear list
Nikon D800E Nikon AF-S Nikkor 28-70mm f/2.8 ED-IF Sigma 50-500mm F4.5-6.3 DG OS HSM Nikon AF-Nikkor 80-200mm f/2.8D ED Samyang 14mm F2.8 IF ED MC Aspherical +3 more
PaulD1980
PaulD1980 OP Junior Member • Posts: 43
Thanks for the comments
I did have VR turned on and i wasn't using MUP or mirror lockup.
I did however use a 5 second shutter delay. I thought this would eliminate any chance of camera shake?
I noticed that the distortion isn't blurred, like you would expect from camera shake / movement. It's looks like two images have been overlapped and are out of alignment?...to me anyway.
I'll give the mirror lock up a try with VR switched off and see what happens.
Thanks,
Paul
Trazan Regular Member • Posts: 121
The first one does indeed look like combined images. You didn't by any chance have "Multiple Exposure" mode turned on?
I can imagine VR acting up during the long expose though.
 Trazan's gear list:Trazan's gear list
Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 50mm f/1.8D Nikon AF-S Nikkor 24mm f/1.4G ED Tamron SP 90mm F2.8 Di VC USD 1:1 Macro (F004)
Thanks,
Paul
When you say 5 seconds delay I guess you used the self-timer (menu item c3) and that doesn't help to avoid mirror slap. Try he shutter-delay (item d4) instead and set it to it's maximum of 3 seconds (5s is not possible there and that's why I think you used self-timer). The key here is that the mirror first flips up and then the delay of 3 s is there before the shutter goes up.
But ... the main cause here for the duplicated pictures is the VR function. If this is activated but in "sleep-mode" then it takes some time to move the special VR lens-element from it's resting to it's active position. This can for example be seen in the viewfinder as a small shift in the picture when the release-button is half-pressed. If you don't wait there, i.e you press the button fully down in one step (or use self-timer) then the VR kicks-in in the middle of the exposure and is seen as a shift in the picture if the shutter is ~1/2 s.
PaulD1980
I had another go last night but the images seem fine this time round? I tried the same setup as before, when i had the issue, but there was no overlapping this time?
I tried with VR on and off at 1/1.6 @f5.6 and f18 but the images came out ok. Possible my lens playing up? Either way it seems fine now
Thanks for all of your suggestions for possible causes / remedies!
Paul
IainD Senior Member • Posts: 1,373
I have read that some people have had malfunctions in autofocus and VR if the battery is low.
IainD
5 sec delay locks up mirror first then the delay. It takes the picture when 5 sec time expires.
5 sec delay is only possible by using self-timer and that function does not lock up the mirror before the delay. Only MUP or the exposure-delay function (d4) raise the mirror before in order to avoid vibrations but only 1, 2 or 3 sec delay is possible there.
