Nikon DF, the ultimate in shallow posturing?
Started Jan 1, 2014 | Discussions
ApertureAcolyte
ApertureAcolyte Contributing Member • Posts: 994
7
Why no manual focus aids? Why?
Dials don't mean crap, AF system is mediocre to boot.
 ApertureAcolyte's gear list:ApertureAcolyte's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GH4 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm 1:1.8 +1 more
Nikon Df
Phil_L Senior Member • Posts: 2,969
Re: Nikon DF, the ultimate in shallow posturing?
So, vote with your wallet. Simple!
Phil_L
 Phil_L's gear list:Phil_L's gear list
Nikon D500 Phase One Capture One Pro
philharris
philharris Contributing Member • Posts: 511
The rangefinder/green light works pretty well, and in decent light the screen actually allows for manual focus by eye in my experience.
Thing is, if Nikon had put a split rangefinder/prism screen in it, we would now be inundated with complaints about how it is unusable at f/5.6
I tried my 80-400 AF-S with the F3, which most agree is the nicest viewfinder Nikon ever made. Fact is you couldn't use it much above 300mm wide open, as it blacked out one half.
On the posturing front, I feel a lot less like a poseur with my Df than I do with my D800 round my neck, not that that bothers me of course, but I find it amusing that people associate posing less with a pro looking camera than an amateur looking one.
 philharris's gear list:philharris's gear list
Sony RX100 Leica Q Nikon D7100 Nikon Df Nikon D810 +26 more
RaajS Veteran Member • Posts: 5,777
8
Speaking of shallow, in the dof sense:
Manual focusing works just fine with the Df, in my experience.  AF system works fine too...
-raaj
'Change is not Mandatory, you don't have to Survive...'
SeekingLight.net
SamG10 Regular Member • Posts: 310
-raaj
SeekingLight.net
I love it when mere assertion is responded to with fact, and a beautiful one too.  Thanks.
 SamG10's gear list:SamG10's gear list
Nikon D40X Nikon D1X Nikon D4 Nikon D800 Nikon AF-S Nikkor 24-70mm f/2.8G ED +11 more
Iliah Borg Forum Pro • Posts: 19,578
Do you own one? -=nt=-
Reilly Diefenbach
Reilly Diefenbach Veteran Member • Posts: 9,953
Just look at it this way.
16
On it's worst day of shooting, every single frame taken by the Df will look better in every possible way than your EM5.
Horshack Veteran Member • Posts: 5,803
It's been the ultimate in shallow posting
Happy New Year!
sgoldswo
sgoldswo Senior Member • Posts: 5,590
Thank you for your insightful contribution...
 sgoldswo's gear list:sgoldswo's gear list
Leica Q Leica M Typ 240 Nikon Df Nikon D810 Nikon D750 +1 more
Rservello
Rservello Senior Member • Posts: 1,157
Good luck getting a pin point accurate focus with the green light or eyeballing it at f1.4 1/60
 Rservello's gear list:Rservello's gear list
Panasonic Lumix DMC-LX100 Nikon D600 Nikon AF Nikkor 50mm f/1.8D Voigtlander 58mm F1.4 Nokton SL II Rokinon 85mm F1.4 +4 more
(unknown member) Senior Member • Posts: 1,041
-raaj
SeekingLight.net
Good one Raj!
I also find the Df easy to manually focus.
Baba Bruce
Keep the fun real.
 Bruce Granofsky's gear list:Bruce Granofsky's gear list
Sony RX1 Leica M9 Nikon D4 Leica M Typ 240 Sony Alpha 7R +16 more
OfCounsel Regular Member • Posts: 117
Not sure what you are trying to express, but if this is typical for you, than you are going to earn another "ignore user" non-follower.
englishfil Regular Member • Posts: 153
Nikon has explained this. It seems they wanted to keep the viewfinder uncluttered -presumably because market research has shown that users prefer this. As several posts have correctly noted it is not possible to make screen aids, such as microprism collars, that work well across the full range of maximum apertures. Nikon has provided, with many of its DSLRs, the >o< viewfinder focus aid that works quite well for manual focusing and is not tied to the centre of the focusing screen. IMHO if that symbology could somehow be combined with the active focus point, rather than stuck below, then it would be perfect. The Df is a modern DSLR with retro touches, many users will use it mostly in AF and to hamper that functionality by harking back to the FM2 viewfinder would not have been wise.
No, they are way of setting values directly and easily assessing how those settings currently stand without reference to the viewfinder or an LCD window. Whether that appeals to you will be down to which cameras you owned previously and whether any of them needed that old fashioned media called film. Personally experience would dictate if I owned a Df I would favour white lettering on black dials, but actually I am now quite used to Nikon's modern interface.
Not mediocre, just not the best they make; still a long way from mediocre. This is specification choice is down to, probably, size, weight, power and lastly product differentiation - Nikon make a high speed, high performance camera with this sensor and its called the D4s(?). If the Df is aimed mostly at the slower, more considered photographer then blistering AF performance is not a high priority.
Now if you want to catch more fish can I suggest you slow the boat down and use smaller, more attractive bait?
 englishfil's gear list:englishfil's gear list
Fujifilm FinePix Real 3D W3 Nikon D200 Nikon D800 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Nikkor 50mm f/1.8D +5 more
chooflaki Regular Member • Posts: 397
Not as shallow as the ubiquitous tourists  with big Canon's,  D800's, 24-70 bazooka's plus lens hood for extra length  that I see getting off just about every tourist bus. These rigs are even too big to pack away and still see them hanging off peoples necks at airports where you cant take photos due to security.. I like to posture in comfort. Df  plus prime fits the bill.  If you find it too hard to manual focus with  the Df you will have worse problems with everything else. Focus  peaking sounds right for you.
 chooflaki's gear list:chooflaki's gear list
Fujifilm FinePix X100 Sigma DP2 Merrill Fujifilm FinePix S2 Pro Fujifilm FinePix S3 Pro Fujifilm FinePix S5 Pro +2 more
Thoughts R Us Senior Member • Posts: 1,404
Original Post: the ultimate in shallow posturing?
7
I think it is the post that started this thread that is the ultimate in shallow posturing.
It has become fashionable in certain circles to bash the Df, as if one knows what one is talking about, based on some simplistic criticisms based on specs alone, without having actually owned or used one extensively.
The OP typifies this.  The criticism adds nothing to useful analysis of the camera, and is a simplistic repeat of what others have said, without drawing from any personal experience with the camera.
In other words, it's useless posturing.
dread_tai Regular Member • Posts: 358
Re: Original Post: the ultimate in shallow posturing?
i'm neither pro nor con for the Df.......it's simply a matter of u like what u like for whatever reasons u like. the same can be said for "dislike".
however, if there's anything to be learned from this continued "Df flood of threads", it's certainly
DO NOT FEED THE TROLLS.
i get what u're saying, but IF people would cease even responding to the OP as if it was a sincere/legitimate post, these TROLLS would go away.
this one will likely limit out at 150, just as the poster intended. sorry to have to add my post to the overall number.
 dread_tai's gear list:dread_tai's gear list
Nikon D7000 Nikon D800E Nikon D810 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G ED VR II Nikon AF-S Nikkor 24-70mm f/2.8G ED +4 more
On the posturing front, I feel a lot less like a poseur with my Df than I do with my D800 round my neck, not that that bothers me of course1.2, but I find it amusing that people associate posing less with a pro looking camera than an amateur looking one.
I don't know about 1.4 but I can do it at 1.2 all day long.  In the image I posted, I can count the eyelashes.  Shot at 1.2.
-raaj
SeekingLight.net
RichRMA Senior Member • Posts: 4,073
Are there any manual focusing aids that actually work, or are they all just "ballpark" focusing aids?
eric guzman Contributing Member • Posts: 647
troll, N/T
No text.
John Gellings Senior Member • Posts: 1,689
In other words... I don't like it so how can anyone else?  Isn't that what you really are saying?  It's your hang-up, not the user of the Df's hangup.
 John Gellings's gear list:John Gellings's gear list
Fujifilm X100T Fujifilm X70 Fujifilm X-E2 Nikon Df Fujifilm X-Pro2 +6 more
