How robust is a D800?
Started Jan 1, 2014 | Discussions
golf1982
Contributing MemberPosts: 744
Jan 1, 2014
Came accoss this article http://www.bythom.com/photographic-travel/africa/botswana-2013-workshop-blog/the-measure-of-a-safari.html which surprised me because now the left focus issue is sorted it seems to be a very robust body And A google search shows up no such issues.
wondered if anyone here has had any issues?
Nikon D800
soloryb
Senior MemberPosts: 2,043Gear list
Re: How robust is a D800?
In reply to golf1982, Jan 1, 2014
No issues after 1.5-years. Built like a tank as far as I'm concerned.
soloryb
 soloryb's gear list:soloryb's gear list
Fujifilm FinePix X100 Nikon D800E Nikon AF Nikkor 50mm f/1.8D Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Nikkor 28mm f/2.8D +9 more
unknown member
(unknown member)
The D200/300/700 and 800 are all basically the same form factor with improvements in materials and methods along the way. It'll last a long, long time. The issues in the linked article (fell off a car dashboard and broke the LCD and fell with an unnamed 'large' lens and broke the mount) are unfortunate for the owner but don't sound like they're unreasonable. If you're using a telephoto lens the thing is going to hit the ground with a certain amount of force.
Wait for the bright flash so I can steal your soul. Smile!
 The Andy G's gear list:The Andy G's gear list
Nikon D800E Nikon AF-S Nikkor 35mm f/1.4G Nikon AF-S Nikkor 50mm f/1.4G Nikon AF Nikkor 20mm f/2.8D Nikon AF Nikkor 85mm f/1.8D
golf1982
In reply to The Andy G, Jan 1, 2014
My thoughts also. The d800, has a substantial frame, as shown in the article. A heavy lens dropped badly will put massive loadings on the camera frame. Thom's conclusions seem based on anecdote.
bigconig
Contributing MemberPosts: 640Gear list
I dropped my D700 twice with no damage the 800 once cracked the chassis in two places. This however is totally unscientific so who knows if it means anything other than I need to stop dropping my cameras.
The good news is 10 days in Mellville and my 800 was back to me in brand new condition for $300
 bigconig's gear list:bigconig's gear list
Nikon D800 Nikon D7100 Nikon Df Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S Nikkor 50mm f/1.8G +10 more
Robin Casady
Forum ProPosts: 12,898
No, my D800E is one of the few cameras I've ever dropped. No problems with it.
Note the number of D800 on that trip—13. That is more than double the count for any other model. As others have said, the events that damaged the D800's are likely to damage any camera.
Robin Casady
http://www.robincasady.com/Photo/index.html
"The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts."
— Bertrand Russell
okephoto
Regular MemberPosts: 182
In reply to bigconig, Jan 1, 2014
I just sent my D800 in to Nikon Canada after some issues and they have come back with impact damage and the chassis is cracked. I have been told that the camera is toast, buy a new one.
 Funny thing is, to my knowledge the camera has never been dropped or hit and I don't use long lenses.
Do you know if they replaced the chassis in your case?
Kevin Oke
Web Site - http://www.kevinokephotography.com
Stock Image Library - http://www.kevinoke.com
rubank
Contributing MemberPosts: 806Gear list
Not very
I tripped on my front porch and tha D800 took a hit on the wooden stairstep which resulted in a cracked bottom panel just beside the battery door.
On the other hand, once my D300 with lens fell from 1,5 meters onto a wooden indoors floor without anything happening to the camera body.
So I´d say some materials used in the D800 (like the bottom panel) seem quite fragile, even if in my case the cracked panel hasn´t affected the camera operation in any way. Maybe the rubber gasket around the battery door no longer is effective, but I don´t care enough to have it fixed (it´s just a tool).
golf1982
In reply to Robin Casady, Jan 1, 2014
Robin Casady
— Bertrand Russell
I suspect that nikon have sold more D800's than previous (pro) bodies, and so total number of any issue will be more even if percentages are really low . Considering the response here this dose not seem to be any worse than any other body.
golf1982
In reply to okephoto, Jan 1, 2014
Kevin Oke
As you know it is not impact damage then the frame must have been defective from the start. Well worth arguing the point.
MPA1
Veteran MemberPosts: 3,298Gear list
Two words. Camera insurance!
There simply has to be a reason for the price difference between the D800 and the D3s/x or D4 bodies. What is under the rubber skin is part of that reason.
CFynn
Veteran MemberPosts: 5,224Gear list
In reply to golf1982, Jan 3, 2014
I haven't had any issues like this with the D800 ~ but I never had with the D7000 either. Then again I've never dropped either camera with a heavy lens attached, and hopefully never will.
There may be something in it though, as I can't see why Thom would make this up. Anyway, I've always suspected the extra "robustness" the D800 is supposed to have over the D610 may be a little over rated. Sure the D800 uses more metal than they do, but we don't hear of many D600 / D610 bodies cracking or breaking. Weather sealing seems to be about the same too.
 CFynn's gear list:CFynn's gear list
Fujifilm X10 Nikon D800E Nikon AF Nikkor 50mm f/1.4D Nikon AF Nikkor 180mm f/2.8D ED-IF Nikon AF Nikkor 105mm f/2D DC +14 more
caspianm
Senior MemberPosts: 2,116Gear list
In reply to CFynn, Jan 3, 2014
Regardless of what you hear or not D800 is built tougher than D6xx and D4 is better than D800.
None of these cameras are drop proof. Once one is dropped the extent of damage or no damage depends on the circumstance of the accident and lens attached.
 caspianm's gear list:caspianm's gear list
Canon PowerShot G1 X Nikon D800E Panasonic Lumix DMC-FZ70 Nikon Coolpix S9900 Sony Alpha NEX-3N +18 more
larrywilson
Veteran MemberPosts: 4,453Gear list
In reply to caspianm, Jan 3, 2014
+1, I totally agree that the d610 is not as sturdy as the d800 and the d800 is not as sturdy as the d4.  Any camera dropped on pavement depending on the situation and attached lens may break.
Larry
 larrywilson's gear list:larrywilson's gear list
Nikon D810 Nikon D7200 Nikon AF-S Nikkor 85mm f/1.8G Carl Zeiss Makro-Planar T* 2/100 Nikon AF-S Nikkor 500mm f/4G ED VR +6 more
golf1982
In reply to larrywilson, Jan 3, 2014
Larry
I think the lack of  response of people suffering issues to this thread indicate there is no issue here. A google search doesn't throw up anything also
MPA1
If anyone doubts the underlying toughness of D3/4 series bodies, I recommend visiting this page...!
I'm not sure a D800 would survive that.
mactac
Regular MemberPosts: 287Gear list
In reply to MPA1, Jan 3, 2014
I left my D800 with 24-70 lens attached out in the rain overnight by accident.  In the morning, it was completely soaked, but worked perfectly.  Still works great to this day.
Robust?  Yes.
 mactac's gear list:mactac's gear list
Nikon D800 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +3 more
